It is currently Thu Jul 31, 2025 12:48 pm
 Post subject: No backstrip?
PostPosted: Wed Jul 15, 2009 2:07 pm
Country: Romania
I know this has been discussed before, but searching not working for this topic.
So, any thoughts on leaving off the backstrip? I'm talking about backs without marquetry strips. If they are perfectly jointed and glued/clamped, then the join line is not a likely crack line. It might actually be the safest line in the whole width.
I will soon close a box with this 3 piece back. The white fillet is maple and I am rather certain the joint is strong. Plates planed and candled, and the center panel hammer-wedged in. I like the potential look through the soundhole and I was wondering if I should omit the backstrip....
Thanks!
Build log
 Post subject: Re: No backstrip?
PostPosted: Wed Jul 15, 2009 2:14 pm
Last Name: Beaver
City: Lake Forest
Back strips are not necessary but then are traditional. Some like them, some don't.
I use them mainly because the open up the opportunity to do mitered purflings. I like that look.
Joe
Joe Beaver
Maker of Sawdust
PostPosted: Wed Jul 15, 2009 2:58 pm
Last Name: Beaver
City: Lake Forest
Wait !!! Hold the phone!!!
You are talking about the back joint reinforcing strip aren't you?
Leaving it off is probably not a good idea but .... if you have ladder bracing every 4 inches or so and everything is glued nice and snug, you most likely will be fine although I have no experience in how well it will hold up.
Joe
Joe Beaver
Maker of Sawdust
PostPosted: Wed Jul 15, 2009 3:06 pm
Larrivee dos'nt use them. Reinforcement strip...or back strip.
I put them on there though.
PostPosted: Wed Jul 15, 2009 3:09 pm
Country: Romania
Yes, that's the one!
I'm sure I've seen it missing on a guitar of an OLF member, or two. And I have Torres' example, the backs of his cheaper guitars had...music paper strips instead of wood. I many cases, in the course of the 150 years of so, the paper fell off, but the guitar didn't fell apart.
And then we have the example of the guitar top. Joints do open up, but if we compare the number of these accidents to the number of random dryness cracks...
But for a marquetry inlaid / multiple purfling lines joint I definitely agree a reinforcement strip is necessary.
Build log
PostPosted: Wed Jul 15, 2009 3:38 pm
Country: Romania
Found an old similar topic:
viewtopic.php?f=10101&t=21410&p=296863&hilit=larrivee+backstrip#p296863
Build log
PostPosted: Wed Jul 15, 2009 7:12 pm
Online
Alexandru, I have a 1974-ish Epiphone that has a 3 piece back and no back reinforcement strips. It's held up just fine as far that goes. That guitar took the abuse of my youth also.
PostPosted: Thu Jul 16, 2009 4:44 pm
I have a bubinga back that the bookmatch and figure would be diminished visually with a back strip or reinforcement strip. I'm going to go without them. It's an OM style. I think it will be fine.
I'm also using laminated ladder bracing (walnut with a middle bloodwood strip) instead of spruce. Looks good and taps good but I we'll see.
Danny R. Little
Users browsing this forum: Jim Watts and 16 guests
