It is currently Mon May 11, 2026 12:44 pm
 Post subject: super soft
PostPosted: Wed Jul 15, 2009 10:20 am
First name: Ken
City: Markham
Zip/Postal Code: L3S4A8
Without sounding too stunned, what is super soft , and where can it be purchased
 Post subject: Re: super soft
PostPosted: Wed Jul 15, 2009 10:26 am
First name: Christian
Last Name: Schmid
City: Edmonton
State: AB
Zip/Postal Code: T6E 1P9
pretty much all answers can be found here:
http://www.veneersupplies.com/product_info.php?products_id=616
I guess you can buy it anywhere you can buy veneer...maybe even in your local Home Depot
Christian
PostPosted: Wed Jul 15, 2009 10:38 am
First name: Ken
City: Markham
Thanx Christian for the info , can't believe I didn't know about this stuff, haven't seen it in...ha ha guess I've been building too long in the dungeon,
PostPosted: Wed Jul 15, 2009 12:22 pm
First name: Matthew
Last Name: Dollinger
City: Beaverton
State: Oregon
Zip/Postal Code: 97005
Question...what is the thickest piece anyone has successfully used this on? Would it be useful for doing laminated sides?
-Matthew
PostPosted: Wed Jul 15, 2009 1:09 pm
Last Name: Schmid
City: Edmonton
State: AB
Hi Matthew,
now this is only a very vague memory on my part, and I may very well be wrong, but I think classical builders in the Australian/Smallman tradition use 5 or 7 sheets of high-quality veneer for their sides, and I think I remember, that some don't use side benders but just bend the veneers (probably with Super Soft) and laminate them in the mold.
Again, this is a vague memory, so please don't take it as a fact...
I have no idea whether it would work with thicker pieces...
Christian
PostPosted: Wed Jul 15, 2009 1:12 pm
First name: Ken
City: Markham
Good question...what about using it on sides that are thicknessed, to 90-95 thou, like Bubinga ? do you have to saturate the wood to soften the sides throughly? Never had any real problems bending, just interested in this wood softener stuff.
PostPosted: Wed Jul 15, 2009 1:36 pm
I've used it on many difficult sides @ .090" and never broke one in 3 years.
Spray it on lightly. Allow to sit for 24 hours. Bend as normal using minimal water. I heat Bubinga to 300*.
Good luck!
PostPosted: Wed Jul 15, 2009 1:43 pm
First name: Ken
City: Markham
cool...will have to try it...thanx for the info J.J.
PostPosted: Wed Jul 15, 2009 2:03 pm
Would this stuff help if you're bending sides with a heating iron?
Ken Mitchell
Durham, NC
PostPosted: Wed Jul 15, 2009 2:07 pm
Ken Mitchell
Durham, NC
PostPosted: Wed Jul 15, 2009 2:23 pm
Not sure Ken, but it probably would help...others may have better info on hand bending. I've only ever used it on the Fox bender.
PostPosted: Wed Jul 15, 2009 2:49 pm
Last Name: Ressler
City: Sandwich
State: IL
Zip/Postal Code: 60548
Be careful if you are using SS on maple. It will stain maple
John Ressler
PostPosted: Thu Jul 16, 2009 9:39 am
I have only used it on Australian Lace Wood, but it worked fine on a hand bender. I did as JJ said. Spray it on, let it dry, overnight, spritz and bend.
PostPosted: Fri Jul 17, 2009 10:41 am
First name: George
Last Name: Thomas
The SS supplier says a spritz on both sides then dry overnight. This is the instruction for a veneer. I am wondering if more than a light spritz would be needed to fully penetrate a side in the .085 to .095 thickness range. I have tried it both ways and seem to have good results with more but this could just be euphoric recall.
GEO
perpetual beginner
PostPosted: Fri Jul 17, 2009 10:52 am
Good stuff for figures woods but it will bleach Koa. Beware.
PostPosted: Fri Jul 17, 2009 3:35 pm
Last Name: Beaver
City: Lake Forest
Yes, it does take the color out of some woods. I used it on pau ferro binding. I soaked it in supersoft, dried it then bent. Those pieces never again matched the backstrip I had cut from the same stock.
Joe Beaver
Maker of Sawdust
Users browsing this forum: No registered users and 173 guests
