It is currently Tue Jul 29, 2025 9:36 am
PostPosted: Wed Jun 03, 2009 2:10 pm
Does anybody know the actual height at the neck and tail of a martin 12 fret dread?
LK
PostPosted: Wed Jun 03, 2009 2:16 pm
First name: Woodrow
Last Name: Brackett
City: Grover
Zip/Postal Code: 28073
I've got an old one I can measure tonight.(1973 D18S) Is there any other measurements you need? The newer ones are different, but the depth may be the same.
PostPosted: Wed Jun 03, 2009 2:18 pm
Thanks Woody!
Nope, just at the neck joint and end graft.
PostPosted: Wed Jun 03, 2009 2:25 pm
I've used 5" and 4" but I'll be interested in hearing the "official spec".
PostPosted: Wed Jun 03, 2009 2:28 pm
First name: Glenn
Last Name: LaSalle
City: Saint Petersburg
A quick question that is related i think. Lets assume for arguments sake that woody comes back with 4 inches total height at neck block, and 4.5 inches total at the heal. How tall do you make the Neck block and heel block, accounting for top/back and finish etc?
Thx!
Glenn
PostPosted: Wed Jun 03, 2009 2:54 pm
Thx!
Glenn
My backs usually come in at around .90 and my tops right around .1
I start out with taller than needed blocks and after the top and back are done, I bowl sand
the rims to the thickness needed.
PostPosted: Wed Jun 03, 2009 3:03 pm
I have found that if you start with blocks that are the desired heights, and using 18 and 28 foot bowls, then after sanding and putting the top and back on, I get pretty much the same number back .. close enough anyway. But then again, I dont really copy other guitars exactly, except maybe for shape more or less.
PostPosted: Wed Jun 03, 2009 3:17 pm
4 3/4 and 3 7/8.....
long
PostPosted: Wed Jun 03, 2009 5:12 pm
First name: Woodrow
Last Name: Brackett
City: Grover
Todd Stock wrote:
4-3/4" and 3-15/16" is the Martin spec for a 12 fret dreadnought per MG:TR
4 7/8" and 3 7/8" on a 1973 D18S. The new "Standard Series" Martins are different in shape and length. It makes sense they'd be a different depth too. Here's a picture of it. You can tell the shoulder are more rounded than the newer ones.
PostPosted: Wed Jun 03, 2009 5:33 pm
Thank'yee fellas! [:Y:]
