It is currently Wed Jul 23, 2025 12:43 am
PostPosted: Tue May 12, 2009 12:41 pm
Last Name: Neal
City: Arcadia
State: ok
Zip/Postal Code: 73007
Whitch SW lacquer is best for guitars
PostPosted: Tue May 12, 2009 2:04 pm
Last Name: Watkins
City: Lake Zurich
State: IL
GEM-LAC
John Watkins
CNC Guitar Parts
PostPosted: Tue May 12, 2009 3:21 pm
Gem-Lac is a Gemini Coating's product...I no longer use their products because they seem to think that one can use an air dry vinyl sealer under their pre-cat systems....sure...and a year later the finish starts failing gaah ...I had a discussion with the VP about it and walked away less than satisfied over the whole experience so I refuse to use their stuff any longer...
anyway, SW offers a traditional nitrocellulose lacquer and a pre-cat lacquer system....their air dry Hi-Bild system looks very comparable to Behlen's stringed instrument lacquer (at least on paper)...their pre-cat HI-Bild system has a lot higher solids % than the Behlen's does and I would think have a detrimental effect on the clarity and depth of the finish...on the flip side the pre-cat system builds dft (dry film thickness) quickly and is a pretty durable finish though I can't say how it would sound on an instrument...also, because it is a catalyzed system, the use of retarder doesn't affect the overall curing time nearly as badly as it can with an air dry system...
sorry, I can't answer your direct question about which is 'best'...
I can say though that you will most likely have problems finding a one gallon container of either system as most of their stores (at least in my area and from what I've heard certain other areas) only stock the 5 gallon units, which for a pre-cat system can be very wasteful as the shelf life is 6 months or less once catalyzed in the container....
PostPosted: Tue May 12, 2009 4:29 pm
Last Name: Neal
City: Arcadia
State: ok
Their Promor hi build is what I've used on other projects. I was just curious who was useing SW and which products. Was thinking about Cab acrylic ,any thoughts on That?
PostPosted: Tue May 12, 2009 4:56 pm
I haven't heard of the pro mar line though I have heard of of their CAB system but haven't tried it...sounds like its a more modern lacquer with plasticizers in it which will mean that while it is more flexible it is also probably softer...there was a debate a while back on the difference the hardness of various finishes had on the sound of an acoustic...
