It is currently Mon Jul 28, 2025 10:51 pm
PostPosted: Sat May 09, 2009 10:27 am
First name: Pete
Last Name: Liccardello
City: Eden Prairie
State: Minnesota
I haven't been posting lately because I have really had my head down and tail up in the shop working to get the three guitars I have on the bench to a point where I can get them closed up and begin with binding, purfling and prep for finish.... (get ready Joe ... for at least one of them.. ) Here is a sneak peek before I get the backs on.
The OM has a really nice Lutz top from Shane and B/S set of nicely figured Curly Spanish Cedar from Uncle Bob... Backing for the soundport has layering of Bloodwood/B/W/Bloodwood.
The classical is another nice Cedar top from Uncle Bob with B/S of Aussie Blackwood nicely figured and with a lot of depth.
The flamenca blanca - Spanish Cypress & Lutz) is a birthday / retirement gift for my brother-in-law and I hope to surprise him with it next month.
With a little luck and no serious setbacks I hope I can get these finished up soon.
Peter
PostPosted: Sat May 09, 2009 10:43 am
First name: Woodrow
Last Name: Brackett
City: Grover
Zip/Postal Code: 28073
They look great Peter. I especially like the neck and tail blocks. How are you going to fasten the "bolt cover"? The soundport is super nice too.
PostPosted: Sat May 09, 2009 11:06 am
Last Name: Hodge
Beautiful work Peter. Can't wait to see the finished products, thanks! [clap]
Bill Hodge
PostPosted: Sat May 09, 2009 11:11 am
Hey Peter,
The guitars look great! I tried to make three at once one time and got all confused as to where I was with each. Is the Flamenca based on the Reyes plan? I would sure like to know how it sounds with the Lutz top when you're done.
Best wishes,
Max
Max Bishop
Brighton, Michigan
PostPosted: Sat May 09, 2009 11:18 am
By the way, where did you get your Cypress?
Max
Max Bishop
Brighton, Michigan
PostPosted: Sat May 09, 2009 3:00 pm
First name: Mitch
Last Name: Johnson
City: Little Falls
State: Minnesota
Zip/Postal Code: 56345
They all look, stunning! I like the head and tailblock inlays! Do you coat the rim with shellac? Everything seems to really pop out in the pictures.
PostPosted: Sat May 09, 2009 4:39 pm
First name: Pete
City: Eden Prairie
State: Minnesota
Thanks for the votes of confidence....
Thanks Woody. The cover plate will be fastened to the neck block with some double-sided tape. After the neck block and plate (including the back side of it) are shellacked and sanded smooth, the tape works very well and can be removed with a small spatula to access the fasteners.
Hello Max! I hope to see you at the next get-together. Yes the flamenca uses the Reyes plan and plantilla although I have shortened the scale length from 656 to the std. 650 and made the necessary changes to accommodate it. The cypress came from Darren Hippner @ Luthierwoodsales.
Mitch, yes the inside of the rims on both the classical and OM are shellacked primarily to seal the side tapes. The finish does add a nice touch and pops the grain and since I don't use any side bracing I don't have to be concerned about the future consequences of having to re-glue anything over finish. On the flamenca blanca, I apply super-blonde shellac over the side tapes only, leaving the rims natural and unfinished.
Peter
PostPosted: Sat May 09, 2009 6:25 pm
Good stuff man. Let me know if you want to shoot some EM6000 on one over at my place.
Users browsing this forum: Dmaxwell, meddlingfool and 16 guests
