It is currently Mon Jul 28, 2025 11:37 pm
PostPosted: Thu May 07, 2009 6:49 pm
First name: David
Last Name: Lewis
State: Maine
At the boat yard where I work we have a collection of hunks of lead used for various projects. One that is comfortable to hold in my left hand weighs just a little over 5 pounds. Is that enough weight to support underneath the fingerboard inside the guitar as I hammer in the upper frets?
thanks,
David
PostPosted: Thu May 07, 2009 7:05 pm
Well, plenty of guitars have been fretted with no backing block, so zero pounds is "enough". If that one comfortably fits through the soundhole, try it out. Even better would be to rig it up so that you don't have to hold it, like the taylor fret buck. If you have the stew mac scissor jack maybe that would work to prop the weight up against the underside of the top, just a thought. In summary, your five pound weight should be the bomb.
Jordan Aceto
Ithaca, NY
PostPosted: Thu May 07, 2009 9:07 pm
First name: David
Last Name: Lewis
State: Maine
Thank you!
PostPosted: Fri May 08, 2009 12:15 am
I think I read here where Lance (or maybe it was Frank over on Frets.com) uses a 1 lb. hunka lead...5 lbs. would not only be enough but would give you SRV fingers as well! :D
PostPosted: Fri May 08, 2009 8:16 am
I really don't see why you guys don't cut a piece of your radius sanding block off and use it for a press caul and put a caul inside the guitar and use a C clamp to press the frets in. :?:
PostPosted: Fri May 08, 2009 8:26 am
Because i have jaws II for that! Sometimes it is just faster to get out a hammer and bash away, and sometimes the last couple of frets are hard to get at with jaws II or a C clamp arrangement. There are always a couple of frets that i end up hammering, i like the fret buck (or hunk o' lead) a lot for those ones.
Jordan Aceto
Ithaca, NY
PostPosted: Fri May 08, 2009 2:37 pm
I use some birdshot in a ziploc, then duct tape it securely into a rectangle about 3.5"x2"x1". Don't know the weight. I find that it absorbs the hammer inertia nicely. I used to use a chunk of steel. The pliabity of the birdshot prevents the hammer shock from going through to your fingers, which can be quite annoying if you do lot's of guitars. Also, it can 'wrap' around the thumbeam, and won't eat your soundhole edge if you accidentaly bump it.
PostPosted: Fri May 08, 2009 2:52 pm
Location: Between Bordeaux and the Atlantic. S.W.France
Some well-respected luthiers install the frets before glueing the fingerboard to the neck. beehive
PostPosted: Fri May 08, 2009 3:35 pm
Sure, but it doesn't sound like the OP is going to, and lots of us are going to refret guitars on occasion. (you did end with the pokey stick beehive guy :lol: )
Jordan Aceto
Ithaca, NY
PostPosted: Fri May 08, 2009 3:43 pm
Last Name: Shaw
City: Philadelphia
I tap the ends in and just stick my hand in the soundhole and apply some pressure to the area I'm fretting for support. Never had a problem yet.
PostPosted: Fri May 08, 2009 3:55 pm
Last Name: Hodge
And then of course there are those who use bolt-on necks to even further resolve this problem. beehive :lol:
Bill Hodge
PostPosted: Fri May 08, 2009 8:44 pm
isnt lead toxic to handle? Jody
PostPosted: Fri May 08, 2009 10:49 pm
No, Just don't chew on it or breath the dust.
PostPosted: Sat May 09, 2009 12:58 am
Last Name: Shaw
City: Philadelphia
I'm sure there can be some absorbtion through the hand.
PostPosted: Sat May 09, 2009 3:29 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
Metallic lead isn't too toxic because it and lead oxide doesn't dissolve in water too well, so it just stays harmlessly outside of your body. But I wouldn't eat it because your digestive juice will most likely dissolve it. What's bad is soluble lead like lead nitrate...
Typhoon Guitars
PostPosted: Sat May 09, 2009 2:31 pm
This wouldn't work on a compound radius.
PostPosted: Sun May 10, 2009 1:05 pm
Last Name: Cox
Lead safety is pretty easy.
Those of us who don't work in a plant that manufactures lead products have only 1 thing to blame for lead exposure...... Hygiene -- Nothing else.
For us... it all boils down to: Don't eat it....
The main way we eat it is on our dirty hands.... then handling food, cigarettes, chewing tobacco, gum, chewing fingernails, whatever. If you have lead on your hands, and your hands go in your mouth.... you just ate it.
Wash your hands after handling lead.
Don't eat, smoke, or chew while handling lead.
Keep your hands out of your mouth.
If you can -- keep it outside.... and away from your indoor carpeting.
Easy stuff.
