If you're sure the saddle is actually resting on the pickup (and it's not submerged in the sub-slot), the problem is electrical. Even if the slot were too deep, you would be able to get at least some signal coming through. You would just have to do progressive trouble shooting. Check signal path, check voltage path, check signal direct from the transducer out of the preamp circuit, then as needed check it leaving the preamp, or at the jack tabs, etc. There's no hard formula, it's all just tracing the lines and problem solving, assuming a basic level of knowledge in electronics.
If your customer needs this right away and you're not familiar enough with pickup systems to know how to trouble shoot, you should consider referring them to an experienced professional who can handle it. It will likely be a rush fee if they need same or next day turn around, but if they need it this may be the safest route.
_________________ Eschew obfuscation, espouse elucidation.
