It is currently Mon Jul 28, 2025 2:49 pm
 Post subject: Siliconing trussrod
PostPosted: Sat Apr 18, 2009 4:36 am
Last Name: Neal
City: Arcadia
State: ok
Zip/Postal Code: 73007
Should I silicone my double action trussrod and how do I install it. Its a lmi rod.
 Post subject: Re: Siliconing trussrod
PostPosted: Sat Apr 18, 2009 6:18 am
yup
PostPosted: Sat Apr 18, 2009 7:51 am
First name: Woodrow
Last Name: Brackett
City: Grover
Zip/Postal Code: 28073
I recommend some silicone but be careful to keep it in the slot. Silicone will cause finishing nightmares if you get any on the outside of the neck. I'd also recommend watching this video.
http://www.luthiersforum.com/forum/viewtopic.php?f=10101&t=21818
PostPosted: Sat Apr 18, 2009 4:40 pm
Location: Between Bordeaux and the Atlantic. S.W.France
I've heard a lot of well respected luthiers say that you shouldn't bring silicone anywhere near a guitar you're building. Silicone migrates and can cause no end of glueing and finishing problems. There are non-silicone non-hardening caulking products that will ensure that your truss rod doesn't rattle.
PostPosted: Sat Apr 18, 2009 5:34 pm
Without question, the best way to install two-way truss-rods is by adding a spline above the rod. The spline removes all slack from the center of the rod and also ensures a perfect surface for gluing the fretboard. If installed this way, the rod will not rattle even when it is in the neutral position.
PostPosted: Sat Apr 18, 2009 6:28 pm
I have found silicone in the truss rod slot is the suggest method , you can also use a lather of white glue. If you don't put in some kind of buffer some truss rods will rattle. The ones that are open IE Stewart Mac Donald need a filler. Sealed ones like what Martin is using can be placed in dry.
Not all 2 ways are designed to use a filler . Martin doesn't use one with the wrapped 2 way rod. Be sure to understand the manufacturers method of installation. You may be causing a problem if not installed properly.
john hall
PostPosted: Sat Apr 18, 2009 9:56 pm
First name: Jim
Last Name: Hansen
It might be worth mentioning that there are non-silicone based materials that could be used in place of silicone caulking. Would Acrylic Latex be safer to use for those worried about compromising finish or glue joints?
Also, how much of this stuff are we talking about here? I would think that a couple of strategically placed very small dabs of the stuff would be sufficient?
Jim Hansen
PostPosted: Sun Apr 19, 2009 6:43 am
we are talking a small amount. You are buttering the sides , this isn't flooding the channel. I don't glue in the rod all I am using the glue or silicone for is to be a dampener. It is there to keep the metal rod of the truss rod for touching the sides of the channel.
One day you may have a guitar in your shop that has a rattle that you can't ID. Chances are the truss rod may have been set in dry. I have seen 2 of them so far. Not fun
john hall
PostPosted: Sun Apr 19, 2009 6:50 am
Jim I would not use anything that dries hard , it may break up later , the idea behind the spline Simon mentions is three drops of medium ca on the top( one on each end and one in the middle) of the rod before glueing the spline in place should cure any future rattle. jody
PostPosted: Sun Apr 19, 2009 10:56 am
If you are confronted with a rattle on an LMI rod put in dry (as I have been), you can drill a small hole around the 2nd and 10 frets and inject rubber cement with a needle. It works. You can plug the hole with sliver of ebony + CA and dust and it's invisible. (Thanks Frank Ford). I use mostly caulk but I've tried wax from a toilet bowl seating ring after a post here. That seemed fine as well. That said, the spline is probably the best idea.
Terry
