cgal_1 wrote:
Thanks for the prompt reply Michael.
It was my intention to try to build it as per the plans. I bought the John Mayes dvd,s and noted that his method also uses the extention piece. My first two guitars used the 'normal' block method.
I assume that the extention piece remains a flat plane so that the fingerboard extension lies flat on it at the same angle as the slope.
Am I then correct in thinking that once in the mold you don't bowl sand the top of the rim, but do radius the top by using curved braces then pull it to conform to the rim?
Charles.
You are correct. There are those that will set theit lingings proud of the top of the rim by 1/8" of just less and sand a slight angle into them. I have had no issues pulling the arched top down to flat linings. I have also in the past not planed a taper in the tong. but cam back later after the blocks and linings were installded and sanded a tapered plane into the upper bout starting 3" back from the joint till ther was a 1.5 degree slope. Lots of ways to skin the cat.
