It is currently Sun Jul 27, 2025 2:00 pm
 Post subject: What fret wire size?
PostPosted: Wed Mar 25, 2009 8:07 pm
Is there a preferred fret wire size for fretting a new acoustic guitar? Why are there so many choices? Are there attributes to certain sizes. Thanks for any help,this is my first guitar build.
Chance
 Post subject: Re: What fret wire size?
PostPosted: Wed Mar 25, 2009 9:04 pm
Any "medium" size fretwire, like stewmac medium high or medium higher will do just fine. If you start paying attention to the frets on guitars that feel good to you, you will start to form an opinion, until then, medium is popular for good reason.
Aside from tone and feel, the main benefit to using semi high fretwire is that they last longer before needing a refret.
Jordan Aceto
Ithaca, NY
PostPosted: Fri Mar 27, 2009 4:49 am
Thanks for the reply jordan. So does crown height or width have no affect on sound or playability? I just wondered why there are so many choices.
Chance
PostPosted: Fri Mar 27, 2009 5:13 am
well I am not an expert , but the way I see it is the higher the crown of the fret, the more chance there is to get some 'sharping " when the strng is fretted. I just did mine with the smalest available guitar wire, and I am happy with it . the next smaller wire would have been for a banjo. for what its worth . Jody
PostPosted: Fri Mar 27, 2009 5:25 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
Fret size is very subjective. Some people prefer small frets so they can feel the fretboard, others prefer very tall frets so the finger does not touch the fretboard. Some players will even scallop the fingerboard to make sure they never touch the fretboard. Bigger frets last longer before refrets, so if you like small frets it might be better to use a longer lasting fretwire like stainless steel. In general most acoustic rhythm only players will want smaller frets and speed metal players will want huge frets. If you're building a guitar for someone else then you'd ask them what size do they prefer, if it's for yourself then use whatever you're comfortable with.
Typhoon Guitars
PostPosted: Fri Mar 27, 2009 5:38 am
First name: Woodrow
Last Name: Brackett
City: Grover
Zip/Postal Code: 28073
My normal fretwire has a crown width of .080" and a height to .043". I don't mention fret size with my customers unless they ask. I've done a couple with different sizes by customer request but I've never had any complaints about my standard size.
PostPosted: Sat Mar 28, 2009 6:27 pm
Thanks for all the replies. Much appreciated.
Chance
PostPosted: Sat Mar 28, 2009 7:11 pm
I use med. /med..084 wide,.039 crown,and.055 tang. It's what most popular guitars use and most people are use to them.Too high and or too low can have it's disadvanges.So i find these to be a good choice overall.
PostPosted: Sat Mar 28, 2009 9:12 pm
First name: Chuck
Last Name: Hutchison
City: Houston
Chance,
One of the reasons Stew-Mac and LMI offer so many different size fret wire is for refretting. One might have a slightly wider fret slot which would cause you to need a fret wire with a wider tang or smaller which ever the case. Also in refretting you might run across an area on the fretboard where you would need a high crown fret to match up with the existing frets.
Just one reason they sell different wire. For you first, just go with the standard medium and you'll be fine.
PostPosted: Sat Mar 28, 2009 11:33 pm
my standard ire is Stew Mac's 148 for acoustics and 152 for electrics
PostPosted: Sun Mar 29, 2009 9:24 am
I'm only on number one, but on the guitars I play actions set almost identical I find the ones with jumbo wire easiest to play, and by that I mean a crown width 2.8mm and height 1.1mm don't know quite how that compares.
Formerly JJH
Users browsing this forum: TimAllen and 24 guests
