It is currently Fri Jun 12, 2026 7:10 pm
PostPosted: Sat Mar 07, 2009 8:49 pm
First name: Jake
Last Name: Archer
City: Kokomo
State: Indiana
I have been reading Cumpiano's luthier book (an amazing piece of work, If you don't own it, I suggest it to any luthier) and another book on pearl/abalone inlay. Both books suggest buying whole chunks of abalone shell, resawing them to usable blanks, and then fitting them for guitar parts. This strikes me as perhaps a more economic approach to guitar inlay. I have researched online some, and am coming up short on any dealers of abalone shells. Could anyone perhaps point me in the right direction? Both of the above books include diagrams for cutting and duplicating pieces of rosettes and etc. And I am one of those Luthiers that likes to make ALL the pieces of the guitar from slabs/blanks (Kerfing, braces too), and would like to be able to cut my own abalone without paying an arm and a leg for one guitar. Any sites or information would be great - thanks!
Jake
~Make a joyful noise unto the Lord~
PostPosted: Sat Mar 07, 2009 8:58 pm
If you live on the West Coast, you might have or find a diving friend. I used to have a diving friend in California who dived (or is it dove?) for abalone. He threw the shells away. I rescued a couple for soap dishes before I was into luthiery and now I kick myself for not getting more when I had the chance.
A higher purpose for wood.
Rich Smith
Issaquah, WA
PostPosted: Sat Mar 07, 2009 8:59 pm
Jake,
You can buy pieces of whole shell from StewMac and others. You might need to check out Hawaiian or California seafood dealers for whole shell.
Just as a friendly comment, you might want to tone down your sig.
PostPosted: Sat Mar 07, 2009 9:46 pm
Jake, I too like to be the only hand in my guitar building like you.I even fell the tree my guitars are made of.I don't believe in buying any thing i can make myself to build a guitar.In fact, a don't even like buying fret wire and tuners for my guitars.I do make my own pearl blanks from shell for all my inlaying.Not living near the west coast where they are collected makes it hard to find, but i have been able to get alot of my shell from ebay.Sometimes i buy an ashtray and cut it up for blanks.I then use my lapidary equiptment to lap it flat and thickness to 1/16" For inlaying.You can get 10 or 12 nice blanks out of a good shell.Worm holes are your worse enemy buying shells,as sometimes you cant see what you are getting off the bay, but over all i have done well getting them that way.Good luck in your shell hunting. Mark
PostPosted: Sun Mar 08, 2009 2:08 am
First name: Blain
City: Leander
Here's a few links that I found.
I have not done business with any of these websites, so I can't comment on that.
This should give you something to look at for now.
Good luck.
http://www.usshell.com/abaloneseashell.aspx
http://deltonaseashells.com/abalone__seashells
http://www.incensewarehouse.com/search.asp?keyword=abalone
http://www.seashellco.com/abalone-c-458_389.html
http://www.universaltreasures.com/shell.htm
http://store.wanderingbull.com/abshandwost.html
Blain
http://www.ullrichguitar.com
PostPosted: Sun Mar 08, 2009 4:32 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
Man, abalone is so expensive. How is it that I see abalone purfling on inexpensive (like sub $200) guitars? did they just use abalone decal?
Typhoon Guitars
PostPosted: Sun Mar 08, 2009 3:57 pm
This is something I have a little experience with, I and a friend made an order of 600 shells a couple years back, it was expensive then, and the dealer said it would be smaller and smaller shell for more and more money as time wore on - on account of this resource dwindling dramatically -
Luckily my friend was experienced with importing rock and gems and handled the brokerage - otherwise it would have cost even more...
Ok then we had the shell - for a good amt of $$$$
have you ever worked with this stuff???
Nasty - in a word... Its easy for me to see why the price is commanded - its nasty dirty to work and expensive for raw material in the first place....
I have plenty of shell, but no I wouldnt part with any,,,, not because I dont think I could get more - although its somewhat of a concern...
But only because I dont want to go through the process of procuring more!!!
Good Luck if your dead set on getting some this way...
But Id pay for Abalam if i hadnt gotten my own, its worth it.
Charlie
PostPosted: Sun Mar 08, 2009 5:34 pm
I once found an abalone shell in my back yard so I just had to give it a go.
I sliced it with a cheap tile wet saw that I had.
Then I used the grinding wheel that came with my safety planer on my drill press to flatten the shell into blanks. I did this dry but this step is usually done wet to control dust. Fortunetly I was given a new respirator about the time I did this! It was easy to do and the dimensions of the finished pieces was accurate enough. I did have some warm hole issues but since the shell was free I can't complain. I don't think I'll ever do it again.
PostPosted: Sun Mar 08, 2009 11:13 pm
First name: Darrin
Last Name: Oilar
City: Cottonwood
Zip/Postal Code: 96022
You can actually buy abalone shells at Michael's, a craft supply store. If I remember correctly, they were about $12 apiece.
Darrin
PostPosted: Mon Mar 09, 2009 10:12 am
I used to just wander in the shell shop down at the beach, when I was fishing. Hurricane Ike blew that away!
I'm not saying you shouldn't try it, but buying raw shell and making blanks is nasty work.
PostPosted: Sat Mar 14, 2009 10:37 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
I found a few abalone shells at a local shell shop, they go for about 10 bucks a shell. I felt that given the amount of trouble it takes to process shells into usable pieces (assuming they are the right kind) I might as well buy inlay materials from "inlaidartist" on ebay because their prices are really good.
Typhoon Guitars
PostPosted: Sat Mar 14, 2009 8:57 pm
First name: Kenneth
Last Name: Casper
City: Northville
Country: U.S.A
I have a buddy in California I dive for abalone with. He used to have all our shells in 5 gallon buckets in garage. I could check with him and see if he still has them. I only have a few at the house with me.
Ken
http://www.casperguitar.com
Users browsing this forum: No registered users and 179 guests
