It is currently Wed Jul 23, 2025 6:36 pm
PostPosted: Tue Jan 13, 2009 4:02 pm
2 pulls each size, to get from .022 to .028. I ground the cutting crescent with a Dremel drum sander.
Obviously canted more towards repair than building, as that is my bent...
https://soundcloud.com/jeffreylsuits/he ... -runnin-13
PostPosted: Tue Jan 13, 2009 4:37 pm
I assume that's the technical term! :D
PostPosted: Tue Jan 13, 2009 6:45 pm
Press 1, for English...one should not post, pre-coffee, one is also pre-verbal.
PostPosted: Tue Jan 13, 2009 6:53 pm
Neat tool! I need one of those right now for the D-35 I'm working on.
Brad Tucker
 Post subject: Re: Neat tool!
PostPosted: Tue Jan 13, 2009 8:04 pm
Those are feeler gauges, with the ends ground flat, and the cutting edges ground w/ the dremel drum sander. I've ground them up to .035 on my set. For the minimal amount of time I spent cobbling them up, I get great bang for the buck, or, I suppose, scrape for the second. For my taste, beats hell out of messing around with the fret tang, though I've done plenty o' that, too.
The refret I did last night, the wire just laid right down, wicked superglue in (pipette w/narrowed tip), wiped w/ acetone, hit w/kicker from another pipette.
Not to be confused with "nutfiles" made from feeler gauges...see Hesh's post about the REAL real nutfiles!
PostPosted: Tue Jan 13, 2009 9:25 pm
Great idea Jeff!
Thanks for sharing,
Joe
PostPosted: Tue Jan 13, 2009 11:19 pm
I got hooked on a powercrafter for cleaning slots and other small details. It's a great tool.
http://www.sculptingstudio.com/index.ph ... gory_id=18
Mike Brittain
Mike Brittain
gmbrittain@gmail.com
myspace.com/mikebrittain
