It is currently Mon Jul 21, 2025 12:45 pm
 Post subject: Resawing?
PostPosted: Wed Dec 03, 2008 5:14 pm
Country: Romania
I pulled this ultra-super-amazingly nice mastergrade $$$ German spruce top from my stash, and besides being stiff as a wall, bell sounding and riddled with silk - OK I think I got you guys drooling already, I noticed it is very thick, one half is 7mm and the other 8mm, which is about 0.3 inch.
I was wondering if I would have any chance finding a high tech saw that could splice these in 2 for a fee, perhaps worth asking at some furniture factory?
Or how about making a sort jig using a big Japanese saw. I think I saw some that were longer enough than the 22cm of a top half. They cut extremely fast and the kerf is less than 1mm.
Build log
 Post subject: Re: Resawing?
PostPosted: Wed Dec 03, 2008 5:19 pm
Are the surfaces finished or rough? If they're rough, clean them up, re-measure, then re-aks yourself if you think it's possible.
PostPosted: Wed Dec 03, 2008 5:39 pm
Country: Romania
Yes I smoothed both sides to perfection :), still more than 7mm thick all over.
Build log
PostPosted: Wed Dec 03, 2008 5:43 pm
I don't know, Alex. It sure isn't much room for error. You might end up with two 2.5mm pieces if you are lucky, but I believe you would have to be really lucky.
PostPosted: Wed Dec 03, 2008 5:44 pm
Don't do it. If you're shooting for a 3mm top, you've got .5 to work with including the kerf.
In my (25+years) of experience trying to run thin stock on edge through a bandsaw never works. It vibrates, etc and you'll lose all of it.
Plus, I'd get it down to thickness before I passed judgement on it's tone and stiffness. Things happen between 7 & 3 mm.
Just my opinion(s)
-C
Freeborn Guitars
and home of BeauGuard©
PostPosted: Wed Dec 03, 2008 6:04 pm
Country: Romania
I already worked a top from the same billet and it ended up at 2mm. Say I shoot for 2 tops each of 2.5, I am left with 2mm+ of kerf meat. Sounds like it is enough ? idunno
I'm not really into making 150$, but more like into avoiding waste. It's really nice wood.
So here is the plan:
-Get a big Kataba =backless Japanese saw. 270mm long blade.
-Trim the spruce width to the min, which is 185mm for a classical.
-make the jig: MDF board, glue two rails say of 2.7 mm thickness, 185mm distance
It might help if someone else would press the end of the blade flat on the rail, while I press on my end.
Build log
PostPosted: Wed Dec 03, 2008 7:17 pm
Sounds like you're determined to give it a go.
IMO the waste (already) occurred when they cut them as they are now. The bigger waste would be to have the re-saw fail and you lose it all.
Again, my opinion only. Let us know how it works out.
-C
Freeborn Guitars
PostPosted: Wed Dec 03, 2008 8:06 pm
I tink eet eez de debil temptin you, dat is bot I tink. :twisted:
Debil-beware my friend...
PostPosted: Wed Dec 03, 2008 8:46 pm
Alex, I am with Charles on this one. You are setting up for a very low success rate. I once tried to get "that extra set" out of some wood for a customer and the result was not impressive.....If you are determined you have a couple of options. I recently saw a Laguna 16"HD at a guitar makers shop and it had their 1.25 inch very thin kerf carbide band on it, with that saw I would be tempted to try it. Actually, that is really your only option in my books. Cutting by hand with a ryobi or other japanese saw in my experience is not very effective. No matter what you do, try it on another piece of lower grade spruce, trying on another species of wood won't tell you how well it will work with spruce.
Good luck and let us know what you did if you find a successful way to do this.
PostPosted: Wed Dec 03, 2008 9:43 pm
Last Name: Garrish
It's doable...but I wouldn't try it without some really sweet gear and an ideal setup. You will need to attach the piece of spruce to a backer board to stop it from warping mid-cut and ruining everything, and then you'll need to release it from that afterward. And, in the middle, you'll need to make a really clean cut with a thin kerf blade on a perfectly set-up saw.
I've done cuts like that, but the cost of setting up the cut isn't worth it on anything but Brazilian. It's about two hours of setup plus cutting time for one cut.
Bob Garrish
PostPosted: Wed Dec 03, 2008 10:38 pm
Math and statistics of success are against you. If the force is strong in the operator, perhaps, but that's a heck of a cut. Getting a .100" out of that on both sides after sanding wow, those odds are greatly against in my opinion. Now my dad could have pulled it off in his tool and die workshop, but typical high end woodworking...I don't know. [uncle]
PostPosted: Wed Dec 03, 2008 10:54 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
What about those wide blade veneering saws?
Ask a veneer specialist. Maybe someone at SawmillCreek can help you.
Hey! We can send a man to the moon..
PostPosted: Wed Dec 03, 2008 11:10 pm
Country: Romania
Well, you guys have been far from encouraging pfft but unfortunately I tend to be stubborn. I might be buying one of those saws soon. I was shopping for a more conveniently sized one anyway, but the long one is OK too. If I get it I'll build the "jig" and run a few tests cuts in packing grade spruce. If it won't work I'll still post here, say sorry for wasting your time with a stupid ideea etc etc :D
Build log
PostPosted: Wed Dec 03, 2008 11:18 pm
De debil ees strong wid dis one.... :evil:
PostPosted: Thu Dec 04, 2008 12:41 am
Check out Dave. http://www.borsonresaw.com/
Ken Franklin
clumsy yet persistent
PostPosted: Thu Dec 04, 2008 3:26 am
PostPosted: Thu Dec 04, 2008 8:03 am
Alex, I tried this once, I lost two tops but they were wrc. If the board is roughly 210 mm X 480, you resaw with your blade across the 210 dimension then you have to keep the kerf from deviating less than .3 degree while sawing along the entire 480 dimension to maintain less than 1mm changes in thickness (if I calculated it right). Maybe with a special made jig that will hold the blade very straight over the entire dimension.
Also you still have to joint the top halves, unless you get them perfectly lined up you likely will loose about 1/2 mm.
Good luck, if you succeed tell us how you did it because I have a lot of honduran rosewood that I end up with a thick third unmatched piece each time I resaw it.
PostPosted: Thu Dec 04, 2008 8:17 am
Country: Romania
Tony, that is maybe a bit harsh. I already mentioned it's for classical guitar. For the small width and bracing style I use, thinning heavy and stiff tops down tot 2 mm is nothing unusual. And precisely because I wouldn't want to ruin 300y old spruce I posted this thread, to get advice. With all the negatives, it's turning unlikely I will try it even on packing grade material.
Build log
PostPosted: Thu Dec 04, 2008 8:34 am
Hmm Alexandru,
Me tink dat meybe Frei hee eez onto someting. I look at u avata and me see dat that debil, him already has been putting dat ebill saw in to your hand ready to do hees wok no? :twisted:
Cheese
Keeem
PostPosted: Thu Dec 04, 2008 9:33 am
I have a laguna 24 with a 300.oo blade on it I've cut thou. of tops and back and sides I WOULDNT do it Joe
PostPosted: Thu Dec 04, 2008 5:25 pm
Don't do it !
PostPosted: Thu Dec 04, 2008 6:39 pm
Kim wrote:
Hmm Alexandru,
Cheese
Keeem
laughing6-hehe
Maybee if eet don work out, you can make de double top... 8-)
:shock:
PostPosted: Thu Dec 04, 2008 7:55 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Ken Franklin wrote:
Why does that guy remind me of some eccentric person I have seen on tv?
However, got to admit he appears to have it down. Send the wood to him. It only costs you shipping and if he cannot do it, then no harm done.
I book marked that page.
PostPosted: Fri Dec 05, 2008 8:09 am
Alex my friend I have one set of BRW that is .300 thick and I have been temped, very tempted, to consider the possibility of resawing it for the same reasons that you are tempted to resaw your German top. Other OLFers have even suggested that I do so too.
But with my need to join plates at about .140 - .150 and having had a father that used to tell me that it is better to do one thing well than to do two things (insert colorful word here.....) I plan on keeping this set as one set..... :D
But I understand the temptation fully.
PostPosted: Fri Dec 05, 2008 10:35 am
Last Name: O'Melia
City: Huntsville
State: Alabama
Have you studied Mr Borson's site? Spoke with him? I have. He is a very nice guy. And smart too. I intend to build a resaw setup based on his ideas (and Iturra's too). But I doubt even if I had it, I would try this myself. I just think David has an awsome setup that anyone wanting to do any resawing should have (albiet on a smaller scale for me). Me personally, I would send the pice to David and ask his advice. He glues the billet to a stiff block. Obviously that means some loss there. But it appears absolutely essential. It is the stability of the billet that matters most.
Users browsing this forum: Darrel Friesen and 23 guests
