It is currently Tue Aug 05, 2025 5:47 pm
PostPosted: Thu Jun 05, 2014 5:10 pm
First name: Jeremy
Last Name: Wood
City: Galveston
Zip/Postal Code: 77554
Hey guys check out the link for a neck angle calculator.
http://www.tundraman.com/Guitars/NeckAngle/
It sure would have made getting the neck angle right easier on my last guitar knowing this existed. Takes the guess work out determining the right angle for flat top and radiused guitars. And there's a good explanation of why you need the angle.
In order to make an apple pie from scratch you must first invent the universe.
- Carl Sagan
Check out F.O.F. Custom guitars on Facebook.
Www.fofcustomguitar.weebly.com
PostPosted: Thu Jun 05, 2014 6:47 pm
I ran some numbers on this and it appears it is assuming you don't have any angle built into the top. It won't work for me
PostPosted: Thu Jun 05, 2014 7:10 pm
First name: Jeremy
Last Name: Wood
City: Galveston
Really?? It has a box to input the hieght of the top at the bridge. It's set .5 or a half inch when you load the page. So far it has worked for me. I make flat tops so entering 0 helped me get the angle just right.
- Carl Sagan
These users thanked the author Duhjoker for the post: Bri (Sat Aug 23, 2014 3:51 pm)
PostPosted: Thu Jun 05, 2014 8:07 pm
Last Name: Beaver
City: Lake Forest
I can see where it would work. My only problem is knowing the increase in top height before the thing is assembled. I suppose you could just lay the top on a flat surface and measure. That would assume your rims are flat on top. I'll give it a try on my next build and see where it takes me
Joe Beaver
Maker of Sawdust
PostPosted: Fri Jun 06, 2014 2:21 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
It's not as big of a deal on an electric guitar since the neck angle can be increased (if necessary) on a bolt on neck strat by shimming the neck pocket, but on a neck through guitar it's essential to get it right the first time.
It does allow for dome in the soundboard by entering the change in height from neck to bridge.
Typhoon Guitars
PostPosted: Fri Jun 06, 2014 10:49 am
First name: D
Last Name: S
pretty handy. Saves me the time trying to find my calculator. I always double check with a mockup on the guitar.
wah
Wah-wah-wah-wah
Wah
PostPosted: Sat Jun 07, 2014 1:14 am
First name: Jeremy
Last Name: Wood
City: Galveston
I was wondering if you wouldn't mind sharing your math on how to calculate it yourself.
Also is there a way to calculate how much the string pull will bring the neck back up?
- Carl Sagan
PostPosted: Sun Jun 08, 2014 4:38 pm
Tai Fu wrote:
Tai Fu, as you are (or were) a self pronounced cat lover, your signature puzzles me? idunno
Is it some kind of death metal posturing?
PostPosted: Sun Jun 08, 2014 8:24 pm
Last Name: Beaver
City: Lake Forest
I'm a little more than a little rusty with trig. I would have to dig the books out. I did notice his fret spacing doesn't jive with mine. Not sure why that is. Mine do pretty well match the Stew Mac calculator
Joe Beaver
Maker of Sawdust
PostPosted: Sun Jun 08, 2014 9:35 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
It's a parody of some kind... it's just funny. Everyone knows catgut isn't really made from cat guts.
Typhoon Guitars
