It is currently Sat Aug 16, 2025 11:41 pm
 Post subject: Removing a burst
PostPosted: Sun Oct 13, 2013 9:55 am
Last Name: Ensor
City: Springfield
State: Missouri
My first burst didn't turn out perfectly. Is there a way to remove it without having to sand it off? I sprayed three coats of em6000 under the burst. Any ideas?
http://elevatelutherie.com
http://ensorguitars.com
 Post subject: Re: Removing a burst
PostPosted: Sun Oct 13, 2013 10:49 am
First name: Danny
Last Name: Vincent
I've been there more than once Chris. Paint stripper works well for nitro. Not sure about 6000. I used electical tape and masked off about 1/8" into the top and then covered the rest of the guitar. Once you peel the tape off I sanded the thin strip around the edge back to wood. I've also stripped back and sides and left the top. It works well.
Good Luck
PostPosted: Sun Oct 13, 2013 11:46 am
First name: wes
Last Name: Lewis
City: Garland
State: Tx.
Zip/Postal Code: 75044
done it a couple of times with em6000...best method I have found...ROS 100 and 150 grit followed by finer grits.... 1 hour worth of work ....strippers are nasty
MK5acoustics.com
PostPosted: Sun Oct 13, 2013 12:43 pm
First name: Danny
Last Name: Vincent
weslewis wrote:
strippers are nasty
Sure no question about that Wes. The plus side is they don't change the top thickness. Not an issue if you have some to spare.
PostPosted: Mon Oct 14, 2013 4:34 am
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
I have been having luck with some of the newer water based strippers for my re-finish work on all types of factory finishes, including poly. They take longer than the old chemical stuff and you still need gloves but no fumes.
Brian
PostPosted: Mon Oct 14, 2013 6:30 am
They're just hard working girls trying to make an honest living...
Ken Jones
Mountain Song Guitars
Mountain Song Guitars www.mountainsongguitars.com
PostPosted: Mon Oct 14, 2013 2:38 pm
First name: Rob
Last Name: McDougall
City: Cochrane
State: Alberta
I have used the soy-based stuff from LV with success removing EM6000 from a solid maple top.
PostPosted: Mon Oct 14, 2013 2:58 pm
Last Name: Howard
City: Magnolia
State: Delaware
Ken Jones
laughing6-hehe
Brian
PostPosted: Mon Oct 14, 2013 4:56 pm
First name: wes
Last Name: Lewis
City: Garland
State: Tx.
[:Y:] [:Y:]
MK5acoustics.com
PostPosted: Mon Oct 14, 2013 7:31 pm
Last Name: Ensor
City: Springfield
State: Missouri
I ended up sanding the burst off, adding a couple new clear coats under it, and respraying the burst. Much happier this time around.
PostPosted: Tue Oct 15, 2013 8:22 am
First name: Tony
Last Name: C
City: Brooklyn
Ken Jones
Trying to work their way through college. No harm in that. The clientele is usually much nastier.
http://www.CostaGuitars.com
PMoMC
PostPosted: Tue Oct 15, 2013 11:27 am
Last Name: Sollod
Chris,
Can you let us see how the burst came out?
www.swiftcreekguitars.com
PostPosted: Tue Oct 15, 2013 3:06 pm
Last Name: Ensor
City: Springfield
State: Missouri
Attempt 1- lesson learned: going to fast will not yield a symmetric pattern (at least not for me)
Attempt 2- lesson learned: don't remove dust/particles from a still wet colored finish. It will ruin an otherwise great looking burst.
I just resanded and resparyed for attempt 3. It looks good so far, but we will see if I can get it all the way through finish without sanding through. I would really like to not mess this one up. I will post a photo at some point.
PostPosted: Tue Oct 15, 2013 9:49 pm
First name: Rob
City: Cochrane
State: Alberta
I think every burst I have done has at least 3 tries. Over 5/8"maple. A little more forgiving....
Stick with it - 3 is the charm!
PostPosted: Thu Oct 17, 2013 1:13 pm
Last Name: Ensor
City: Springfield
State: Missouri
Here it is:
PostPosted: Thu Oct 17, 2013 4:33 pm
Looks good now!
PostPosted: Sun Oct 20, 2013 8:05 pm
First name: Tony
Last Name: C
City: Brooklyn
Yup. Looks good!
PMoMC
Users browsing this forum: Bing [Bot] and 11 guests
