It is currently Sun Aug 03, 2025 3:29 pm
PostPosted: Sat Sep 14, 2013 2:34 pm
First name: Jim
Last Name: Kirby
I've been using cocobola bindings on my rosewood guitars (classical, with w/b/w mitred purflings on sides, back, end strip and back strips). I'm starting my first using Macassar Ebony (with cedar top) and I'm up in the air about binding choice. I'm afraid the slightly green/tan hue of the ebony together with the reddish hue of the cocobola will look like a Christmas ornament. Does the sort-of greenish hue of the Ebony stay that way under finish? (I know, I need to do some testing.) What have you used in the past? Not looking for a lot of contrast in the bindings. I could always self-bind, but looking for a little something extra.
Jim Kirby
kirby@udel.edu
PostPosted: Sat Sep 14, 2013 2:57 pm
I'd rather stick with off cuts of the sides for that classy tuxedo look or I'd go with curly koa or similar.
PostPosted: Sat Sep 14, 2013 3:14 pm
Last Name: Kincheloe
How about pau ferro? Or black ebony. Or walnut. Maybe curly?
PostPosted: Sat Sep 14, 2013 3:37 pm
+2 for curly koa.... Am biased though as this was my first build ;) Macassar with koa bindings
PostPosted: Sat Sep 14, 2013 4:32 pm
First name: Jim
Last Name: Kirby
That's pretty indeed, but not what I'm after for the stately, low-key, de riguer classical look. Although, the ebony looks like it warms up enough under finish that my original concern may be moot. Time to test!
Jim Kirby
kirby@udel.edu
PostPosted: Sat Sep 14, 2013 5:17 pm
I'd go with off cuts than.....
PostPosted: Sun Sep 15, 2013 1:58 am
Last Name: Beaver
City: Lake Forest
Franks curly koa looks very sharp, but then the macassar he used is on the none typical side of outstanding. Have to see your sides but I would go with something dark, gaboon ebony or dark indian rosewood or BRW if you can find it
Joe Beaver
Maker of Sawdust
PostPosted: Sun Sep 15, 2013 7:35 am
First name: Jim
Last Name: Kirby
My set tends more towards Frank's rather than Filippo's. I looked at it under naptha last night and I think it may well warm up enough under finish to not cause the problem I was worried about.
The snakewood is nice. Any of that lurking around anywhere?
Jim Kirby
kirby@udel.edu
PostPosted: Sun Sep 15, 2013 7:54 am
Good find! I was so lucky when I just found that set in 2007 - for only £160 which was the around $200 - slight flame on the back as well and have not seen anything close since - with even very average wood being in excess of £280
Snakeroot would be great IMHO, but again tricky to find... The Koa binding was from Bobc, not sure if he has any left with that tight curl, but saw he has some figured mahogany that could work.
Must admit, using side cut offs with say a 0.3mm pear or maple 'coach' lining would look early classy on a classical
PostPosted: Mon Sep 16, 2013 4:14 am
If the wood already has a lot of contrast, my first choice would be side off-cuts, or something of similar or darker hue. Too much contrast, with figured, curly etc. woods can quickly make for a very busy and incoherent visual package (IMO). Generally, I think its not just a matter of which woods and colors "match", because lots of things can look great, but still not appropriate for all instrument. Its better to pick on a theme for the design concept, and chose the woods and appointments accordingly.
Users browsing this forum: Bing [Bot], Terence Kennedy and 39 guests
