It is currently Fri Aug 15, 2025 5:02 am
PostPosted: Thu Feb 14, 2013 8:02 pm
First name: Larry
Last Name: Hawes
Up-spiral; down-spiral; straight cut? Other? Both front and rear head stock veneers will be attached and want to use the proper bit to avoid tear-out and other such ugliness.
Thank You and Best To All
PostPosted: Thu Feb 14, 2013 9:01 pm
I use a bearing guided straight cut. But I don't see why a spiral cut wouldn't work.
Alain Moisan
(Now building just for fun!)
PostPosted: Thu Feb 14, 2013 11:07 pm
State: ON
I general use a down cut spiral. However last time I grabbed an up cut spiral and it worked fine as well. I haven't had any issues with tear-out. I start by using a slightly oversize template guide and I cut the depth of the slots in 3-4 passes, increasing the depth with each pass. Once the slots are through the headstock, I use a smaller teplate guitar and do a full depth pass to clean up the slots.
I am using a luthiertool.com slotting setup. http://luthiertool.com/slot%20head%20fixture.html
Josh
Josh House
Canadian Luthier Supply
http://www.houseguitars.com
