It is currently Fri Aug 08, 2025 1:30 pm
PostPosted: Sat Dec 22, 2012 3:09 pm
First name: Wendy
Last Name: W
State: Arizona
I've only used this to cut binding channels in 2 guitars, so it hasn't had much use. This morning, whenever I turned it off, the bit would stop spinning and then after it sounded like it was off it sounds like a fan comes on. Even if I unplug it, it continues to run for a while. It did it right away, so it wasn't even warmed up from cutting yet. I decided to go ahead and use it anyway, and after using it to cut most of the top binding and purfling channels it quit doing it. It's too new for brushes to be worn, and besides, this was coming on after it was off. And if it were brushes, wouldn't the bit be coasting to a stop instead of stopping right away. Really weird.
Wendy
PostPosted: Sat Dec 22, 2012 4:29 pm
If I had any router that came on after I turned it off, it would be; "Scotty, get us out of here" time. And I would'nt get it near a guitar. Can you take it back?
PostPosted: Sat Dec 22, 2012 5:27 pm
First name: Tom
Last Name: Rein
City: Saline
I am fairly sure Ridgid tools have a lifetime warranty.
Stay with the happy people.
--Reynolds Large
PostPosted: Sat Dec 22, 2012 6:00 pm
Double check that it is not just the bearing continuing to spin after the bit has stopped. I had the same concern and that was the problem...
PostPosted: Sat Dec 22, 2012 6:01 pm
First name: Fred
Last Name: Tellier
City: Windsor
Zip/Postal Code: N8T2C6
I had an experience with the warranty on a shop vac. it is not too great if you have to use it.
Fred Tellier
PostPosted: Sat Dec 22, 2012 7:02 pm
First name: Trevor
Last Name: Gore
City: Sydney
Sounds like the guide bearing spinning on. Try it with a plain bit (or no bit) and see what happens.
http://www.goreguitars.com.au
PostPosted: Sat Dec 22, 2012 7:18 pm
First name: Wendy
Last Name: W
State: Arizona
The router was not actually on, the bit had stopped spinning, the bearing was not spinning. After everything had stopped it was like a little fan motor came on. It almost sounds like when my laptop gets hot and the little cooling fan comes on. I hadn't even made more than a small test cut, so it could not have been hot. The strangest thing is that it continues after I unplug it. Anyway, it has stopped doing it and there never seemed to be any danger. It was mounted in my Williams style binding jig so it wasn't going to take off across the table or anything. It worked perfectly the rest of the morning. I think I'll call Ridgid next week and ask them about it just out of curiosity. I'll ask them about the warranty too. I take it nobody else here has had this experience with the Ridgid trimmer?
PostPosted: Sat Dec 22, 2012 7:20 pm
First name: Wendy
Last Name: W
State: Arizona
Thanks Todd. I got it at Home Depot. I'll take it in after everyone is done with their holiday shopping madness. I'm not going near the place now. They're usually pretty good about exchanges, but I got it at least 1 1/2 years ago so I don't know. At least it is working fine now.
PostPosted: Sat Dec 22, 2012 7:48 pm
Last Name: Gramann
City: Fredericksburg
State: VA
Zip/Postal Code: 22408
I have two of the Ridgid laminate trimmers. It is my favorite router. I have had nothing like you describe happen with either. I had a warranty issue with my Ridgid drill. Aside from having to take it to a service center 50 miles away and go back in ten days to get it, the warranty service was no problem.
PostPosted: Sat Dec 22, 2012 8:11 pm
If the forum can't help you,maybe you should call Father John....
Old growth, shmold growth!
PostPosted: Sun Dec 23, 2012 10:18 am
First name: wes
Last Name: Lewis
City: Garland
State: Tx.
Zip/Postal Code: 75044
The first rigid laminate trimmer I bought would just shut itself off, bad switch, must have skipped the Chinese QC department!! laughing6-hehe
took it back to Home Depot and got another which I have used for 2 years with no problems...
MK5acoustics.com
PostPosted: Sun Dec 23, 2012 9:38 pm
Todd Stock wrote:
You mean there is NOT supposed to be a minor demon bound to our service within each portable power tool?
Maybe yours can have one, I can see that. :twisted:
PostPosted: Sun Dec 23, 2012 9:44 pm
First name: Big
Last Name: Jim
Colorado Koolaid ? laughing6-hehe
I have a rigid , never had any issues . Really Like it.
PostPosted: Sun Dec 23, 2012 10:32 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
They have a "Life Time Service Agreement". And you had better have registered it.
Users browsing this forum: Bing [Bot] and 33 guests
