It is currently Mon Jul 21, 2025 12:01 pm
PostPosted: Sun Apr 10, 2011 2:48 pm
Filippo Morelli wrote:
(if you're using something specific can you please post a URL to the exact product your using ... seems like there are many flavors of sandpapers ... thanks)
Guys, I need to re-up my sandpaper supply for my Performax 22/44. Don't want to buy Performax $$$$ paper. Looked in the archives and a few people suggested Econ Abrasives. I also looked at Supergrit in PA that I've used before.
Econ: https://www.econabrasives.com/products.php?id=162&size=3%22X25Yards
Supergrit: http://www.supergrit.com/products/products_rolldrumsleeve-cloth.asp
So I'm thinking Aluminum Oxide 3" x 25 yd, 80 grit and 120 grit cloth back rolls. My question - does it matter whether I go with a J weight or X weight cloth back?
Any other opinions or suggestions are most appreciated. Thanks!
Filippo
Not sure about X vs. J, but I have found that quality matters. And that Klingspor is good.
PostPosted: Sun Apr 10, 2011 3:14 pm
First name: Woodrow
Last Name: Brackett
City: Grover
Zip/Postal Code: 28073
I use Klingspor Alumina-Zirconia from Klingspor woodworking shop. It's available in 18 or 50 meter rolls. They deliver to my shop. I'm not sure if their delivery area gets all the way up to your area, but they'll ship too. (actually the delivery truck mainly goes to automotive body shops)
http://www.woodworkingshop.com/cgi-bin/E1CDCD0A/mac/qryitems.mac/itemDisplay?qryType=STYLE&itemSt=PE41000&coreDsc=3%22X%2050%20METER%20ALUMINA%20ZIRCONIA%20BULK%20ROLLS
They've also got aluminum oxide, which is what I believe the Performax abrasives are.
http://www.woodworkingshop.com/cgi-bin/E1CDCD0A/mac/qryitems.mac/itemDisplay?qryType=STYLE&itemSt=PE003X50&coreDsc=3%22X%2050%20METER%20ALUMINUM%20OXIDE%20BULK%20ROLLS
My sander is a 10-20, but I believe the abrasives are the same. (except for length).
PostPosted: Sun Apr 10, 2011 3:21 pm
First name: Phillip
Last Name: Patton
City: Yoder
Zip/Postal Code: 46798
I'm pretty new to drum sanders, but this is what I bought:
http://www.woodmastertools.com/NS/acces ... cfm?PID=78
I can say that the X weight are stiffer than J weight, and for this I would think X weight would be better.
Regards,
Phillip Patton
http://www.pattonblades.com
The bitterness of poor quality lingers long after the sweetness of low price has faded.
https://hoosierbladesmith.wordpress.com
PostPosted: Sun Apr 10, 2011 3:51 pm
Filippo,
I have started shopping with 2sand.com. I have talked with the owner, RJ. He is pretty cool. He sells about everything. You can get rolls of paper for your Performax. You have to cut the ends which is no big deal. I make a wooden template and hit with a utility knife and or use a old roll to get the length right.
I also was able to get some 24" dia. disks for the radius dish. About $9 a piece. I got 80 grit and some 180 for the final hit prior to glue up. These aren't PSA but some 77 spray adhesive takes care of that. Check him out.
Link
PostPosted: Sun Apr 10, 2011 3:57 pm
The last rolls I got are from Econ, and I will say I prefer them to the Klingspor ones. They seem to last longer, clog less and leave a better surface.
Weight matters, you want thinner backing for higher grits, like 120, where you can really dial 1/2 thou at a time.
The blue zirconia is great in the coarse grits to remove material in a hurry, like 24. However, I think it doesn't leave as nice a surface with finer grits.
Laurent Brondel
West Paris, Maine - USA
PostPosted: Sun Apr 10, 2011 5:32 pm
When I had my 22-44 I bought rolls here. Good stuff
http://www.industrialabrasives.com/sanding-rolls-aluminum-oxide-polycotton-drum-sanding-rolls-3x52-yds-c-79_154.html.
and here
http://www.onlineindustrialsupply.com/?google-sandpaper&gclid=CJvxpdqBk6gCFYbb4AoddWkeCw
PostPosted: Sun Apr 10, 2011 5:43 pm
First name: Bobby
Last Name: Masten
City: The Woodlands
Zip/Postal Code: 77380
Not to hijack your thread, but the last 3 rolls of Performax paper I bought all tore within 5 minutes of use. I'm using a 16-32 and have used extreme caution doing the wraps, even so much as re-wrapping 5-6 times before being satisfied. Is this a paper issue, user error or the sander? Thoughts?
Bobby Masten
PostPosted: Sun Apr 10, 2011 6:26 pm
My last rolls were from Econ abrasives and I have to say that I am very pleased at the quality. Prices are hard to beat also.
Chuck
PostPosted: Sun Apr 10, 2011 7:43 pm
+2 for Online Industrial. Klingspor 3" x 50 yard cloth roll of 80 grit aluminum oxide will set you back about $65. And they're fast too.
http://www.onlineindustrialsupply.com/3indrsaro.html
Jim Womack
Will Rogers
PostPosted: Sun Apr 10, 2011 8:06 pm
Filippo, I've been pretty happy with this stuff http://woodworker.com/a-habrasives-3x91-zirc-36y-rdwrp-16-mssu-132-518.asp?search=sand&searchmode=2 It cuts really well, doesn't load up much, even on Cocobolo and It seem to have a very good life. I haven't tried the Klingspore stuff though.
PostPosted: Sun Apr 10, 2011 8:13 pm
Thanks, I was trying to figure out why it wasn't hot.
PostPosted: Sun Apr 10, 2011 8:40 pm
First name: Jim
Last Name: Kirby
Another vote for Online Industrial Supply, Bobc's second link. I've been happy with their paper's performance and longevity. I haven't gone through a complete roll of anything yet.
Jim
Jim Kirby
kirby@udel.edu
PostPosted: Sun Apr 10, 2011 8:45 pm
First name: Big
Last Name: Jim
There are several types of abrasives out there for the cost effectivness and longevity .
X wt Cloth is going to be stiffer and will sand better at your rougher grits , 40 / 60 / 80 /100 / 120 and will last longer . Simply put you can get everything up through 320 in an xwt material .
Jwt is a little easier to work with , however due to the flexability and thinnes it will get hot and stretch faster . ALL Cloth backed stuff will stretch some and may require re- tightening if your doing alot of sanding .
VSM abrasives is a good product , Klingspor is a good product , Econ may be , Im not to familiar with them . Carborundum is another one . The best cost savings is to make a pattern and cut your own strips , Purchase the 3" x 50Yd rolls and cut them yourself .
In regards to softer wood that will load up the material I would go with a cheaper brand / material since you will never get the full life as it loads up anyway . There are soaps available to clean them , however it is a mess and if the cloth back gets soaked it doesnt last long
PERSONALLY I use xwt cloth 3"x 50yd and cut them myself on both 80/120 grits and hand sand there after . Someone mentioned $65.00 a roll 3"x 50Yd that is good price if its a decent quality. I will be glad to quote anyone what dealer cost is if they would like to know an average to compair against what they pay .
PostPosted: Sun Apr 10, 2011 8:55 pm
First name: Big
Last Name: Jim
Additional thoughts .
There is material that is "Canada Sand" if I remember correctly that is a good product .
The main thing to realize is there are basically 4-6 MAJOR Bulk Sandpaper makers worldwide and they sell 52" wide rolls x 50yd long to various " Converters" who the cut it and make there own products . Sooooo you can have several diffrent brands that are basically the same stuff . The trick is to read the Back , there is a a brand mark on most stuff IE: KP911-120 is Vsm material really good stuff , Big $$ . Learning how to read and understand that will help .
I will see if I can come up with a " chart " that I could post that may be helpfull
On disc , your choices are " Cwt " and " Awt" Go Cwt , u will be happier .
PostPosted: Mon Apr 11, 2011 9:28 am
First name: Big
Last Name: Jim
Second Note ! The link listed to Woodworkers supply opens up to " Zirconia Abrasive" materials . This is good stuff , dont get me wrong . However its really a metal finishing paper! It is way overkill for wood . I am not saying you dont need it I am saying You will pay more and may not need to. Its also a Ywt Poly Backed Material so its thicker and stiffer . I do sell alot of that Material in " Wide Belts " but never in 3" wide for sanders .
PostPosted: Mon Apr 11, 2011 1:31 pm
The woodworker supply stuff maybe overkill, but it does last a long time helping to offset the cost.
Also, I may be crazy, but I'll give it a light spray with Pam cooking spray prior to sanding resinous woods. It's like adding extra horse power to the drum sander.
PostPosted: Mon Apr 11, 2011 3:11 pm
First name: Big
Last Name: Jim
Your creating a Lubricant that helps the buildup problem , as long as it doesnt affect the wood your ok . You can actually buy sandpaper that has a bulit in lubricant for working stainless steels .
PostPosted: Sun Apr 24, 2011 10:20 am
First name: Big
Last Name: Jim
Quote:
Initial follow up. The abrasives arrived. Very easy to cut based on an existing Performax roll. Thus far I've sanded macassar ebony, spanish cedar, spruce, Padauk and maple. I am very pleased with the performance of this paper, as well as the cost. Now we'll see how long it lasts. I suspect the longevity will be superior to the Performax paper I had been using.
Filippo
What is the spec information on the backing , I might be able to determine who's paper it is .
Performax is all about " Convenience " they dont make their own stuff , its private labled by a converter for them .
PostPosted: Wed Jun 29, 2011 9:41 am
First name: Kevin
Last Name: Looker
City: Worthington
State: OH
Zip/Postal Code: 43085
Just a little comment about Econabrasives -
I placed an order on June 15 and they didn't ship until June 24th -that's 7 business days. They emailed me an order confirmation on the day I ordered but nothing after that until I called them to ask where my order was.
Not exactly stellar customer service IMO - but then again, I was shopping based on price.
Kevin Looker
I'm not a luthier.
PostPosted: Wed Jun 29, 2011 8:13 pm
Last Name: Haney
City: Sugar Land (Houston)
Zip/Postal Code: 77479
I quickly scanned this, but did not read it throughout. So I may be repeating something that was already said.
I did not see it mentioned that you can avoid buying Klingspor at retail prices by establishing an account. (If it was, sorry for the repeat.) I recently submitted an application and established an account with Klingspor and bought their 25m rolls (oblivious longer than 25 yds) of 3" 80 grit PS29 and 120 grit PS20 paper at 65% of retail ($29.61/roll and $26.98 respectively final cost).
Avoiding the pre-marked paper saved about 30% according to Klingspor. I can easily cut the paper without paying +30% for cut lines. I glanced at the Econ pricing which appears to be higher than Klingspor unless they are offering discounts. I can't speak to the quality difference between the two since I've never owned Econ. I was told that Klingspor is the maker of the paper for Performax.
I am not making any recommendations, just passing on my experience in case it is of help.
Ed
Users browsing this forum: Ken Lewis and 20 guests
