It is currently Mon Jul 28, 2025 2:18 am
PostPosted: Fri Dec 03, 2010 7:05 pm
http://www.goldmine-elec-products.com/p ... dium=email
https://soundcloud.com/jeffreylsuits/he ... -runnin-13
PostPosted: Sat Dec 04, 2010 5:04 am
Online
I have enough trouble lining up slats and side in the bender without juggling with 12 blankets...... laughing6-hehe
PostPosted: Sat Dec 04, 2010 11:31 am
Bridge and fretboard removal?
PostPosted: Mon Dec 06, 2010 10:53 pm
not sure but I dont think 29 watts is enough .. Jody
PostPosted: Tue Dec 07, 2010 9:31 am
The wattage should be fine. They are about 2watts per square inch. My bending blanket is 2.5w/sq.in. and it works fine. I'm wondering about the voltage. I guess you could put 110 volts into it rather than 48volts.
PostPosted: Tue Dec 07, 2010 3:11 pm
The ad is kind of ambiguous.It says it has two separate circuits of 79 ohms each.If you put 48 volts across each of those resistances you get about 4 watts per sq. in.
PostPosted: Tue Dec 07, 2010 8:46 pm
2 1/2 watts is low for a heavy thermal load . This blanket if you turn 120 V to it you will fry it like a fish fillet . Also the blanket isn't rated to 300 degrees I don't think.
PostPosted: Thu Dec 09, 2010 1:28 pm
"elements are wafer thin (about 0.01" thick) "
Yow! One thou!
Users browsing this forum: Colin North and 6 guests
