It is currently Sat Aug 02, 2025 10:46 pm
 Post subject: Cheese it! The fuzz!
PostPosted: Sun Sep 13, 2009 6:50 pm
First name: Adam
Last Name: Yavner
City: Wylie
Zip/Postal Code: 75098
Hi all,
I am rounding the corner on this OM build, starting to prep for finish. I sanded the top to 220 with a backing block and gently wiped it with a damp cloth to raise the grain. After that dried, i sanded it again and it looked utterly beautiful and silky smooth.
I sprayed a washcoat of lacquer over it, just a thin mist to seal it and I notice now that the entire surface has little grains standing up, as they say here in the South, "like they're fixin to meet the Lord". Looks like it needs a shave!
Is this normal? I assume now with the sealer coat, after i give it overnight to dry, that all the grain should now be brittle and should sand right off and no further should come up? Or am I going to be fighting this between every coat? Did I do something wrong, or am I just being paranoid?
Thanks!
Adam
"Everyone wants to BE something, but nobody wants to BECOME something" - William Cumpiano
 Post subject: Re: Cheese it! The fuzz!
PostPosted: Sun Sep 13, 2009 6:55 pm
ayavner wrote:
. . . . . Or am I going to be fighting this between every coat? Did I do something wrong, or am I just being paranoid?
Thanks!
Adam
Sand lightly and recoat, repeat if necessary, but it probably won't be.
Just because you can't hear the voices doesn't mean they're not there. :D
PostPosted: Tue Sep 15, 2009 4:11 pm
First name: Adam
Last Name: Yavner
City: Wylie
Yup, looks like that did the trick. Thanks!
