It is currently Sat Aug 02, 2025 6:59 pm
Post new topic Reply to topic  [ 29 posts ]  Go to page Previous  1, 2
 Post subject: Re: Making shellac...
PostPosted: Tue Apr 12, 2011 2:09 pm
FWIW, I was able to make the iso work. I just had to add the flakes a little but at a time, so a batch took three days to make.
PostPosted: Wed Apr 13, 2011 9:23 am
First name: John "jd"
City: Santa Barbara
Pure IPA (2-Proponol) works fine for dissolving Shellac. It is what I used to use.
When I mix shellac I use a stirrer plate to help dissolve things faster.
I quit using IPA because while it sprays fine, it doesn't not french polish well. The alcohol evaporates off too fast, but the surface stays gummy for a long time. Makes it so you have to use a fairly wet pad to get the right trail, but then also lots of oil to keep the wet pad from sticking.
Ethanol or DeNatured Alchohol is much easier to work with as you get good trails with a much drier pad.
DNA is a mix of stuff (EtOH, MeOH, Methyl Hydrate) that is not always the same. Use appropriate safety gear and test each mix to get a feel for how it works.
-jd
PostPosted: Wed Apr 13, 2011 3:03 pm
-jd
Mmmmm, IPA. I don't drink it until after work, though.
PostPosted: Wed Apr 13, 2011 5:56 pm
City: Santa Barbara
-jd
India Pale Ale is my beer of choice, but too much can result in getting shellaced !
-jd
Users browsing this forum: DennisK, J De Rocher and 59 guests
