It is currently Sat Jul 26, 2025 3:34 pm
PostPosted: Thu Dec 02, 2021 2:13 pm
I’ve thought of making Pickguards in the past but I guess for whatever reason just never have. Any of you guys or girls making custom guards if so show them off! I’ve always been curious how they get the designs in them like the hummingbirds & SJ’s.
PostPosted: Thu Dec 02, 2021 3:12 pm
I have never done the designs before. I am building some 45-style OM's now but I think we decided not to do the desings. None the less I had to give it some thought. I wonder if they just rout and inlay? Not sure.
But I always make my pick guards. Simple ones. These are prewar OM designs.
PostPosted: Thu Dec 02, 2021 3:26 pm
I cut mine out of sheet stock but don’t actually pour the plastic.
PostPosted: Thu Dec 02, 2021 3:50 pm
Same here, make a wooden router template, double stick tape the sheet stock to it, rough cut on the band saw and finish with the router. Polish out with micro mesh and the buffing wheel.
LMI used to have downloadable full sized templates for various designs on their website as I recall.
PostPosted: Thu Dec 02, 2021 4:02 pm
If your thinking of doing a 45 style inlay in a pickgaurd you could place the inlay in the mold and then pour over it. I haven't done it but it should work out.
PostPosted: Thu Dec 02, 2021 4:37 pm
Gosh I never thought of actually making them from scratch :D
I just buy the celluloid sheets and trace the pattern out and cut it with sharp scissors then sand the bevel in the edge.
PostPosted: Thu Dec 02, 2021 5:20 pm
Excellent Pickguards and beautiful guitar. What’s the finish?
PostPosted: Thu Dec 02, 2021 5:56 pm
City: Tyler
I make my own. Used to buy the Greven ones from LMI but selection dropped and I didn’t like the choices. It is really quite easy to do. A couple ounces of Epoxy and the stewmac tint. Here’s one on number 25.
PostPosted: Thu Dec 02, 2021 6:55 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
Looks nice! What epoxy are you using? How thick are you pouring them? Any tips?
Bryan Bear PMoMC
PostPosted: Thu Dec 02, 2021 11:34 pm
City: Tyler
Hi Brian, I use system three finishing resin. I pour it out, drip in some tint, swirl it a bit, and blow the bubbles with a hot air gun which also spreads it out thinner. Do it in a clean area without an ac vent blowing or you’ll get a bit too much dust. It’s really a simple process. You will probably have to experiment with it but it works. There are several videos on YouTube showing the set up with glass and heat shrink film.
PostPosted: Fri Dec 03, 2021 4:15 am
Mario was making them some years back, don't know if he still is but his were the best that I have ever seen and I would be interested in those for sure if I was still building.
PostPosted: Fri Dec 03, 2021 8:38 am
Wow! That's really nice. So do you build a mold for the shape or just let it run thin and then cut it out with scissors or something?
French polish shellac.
PostPosted: Fri Dec 03, 2021 4:36 pm
City: Tyler
Hi JF, I don’t use a mold, just a sheet of window pane glass covered with shrink film (epoxy won’t stick to it at all). I put a paper cutout of my guard shape on the back to make sure I like what I’m getting. I mix up about 1 to 1 1/2 ounce epoxy with raw umber and maybe a touch of yellow. I pour that as my background and blow it with a hot air gun. Then I mix dark brown or tobacco brown in another batch and drip/swirl it in some semi-pattern. I sometime tilt the glass and have the colors mix that way. Blow with hot air again to rid of bubbles and let it dry. I always loved the Greven guards and try to replicate the look: haven’t got there yet but trying.
Yea cut with scissors and bevel the edge with a razor blade. Buff on the buffer.
These users thanked the author Glen H for the post (total 2): jfmckenna (Fri Dec 03, 2021 6:20 pm) • Bryan Bear (Fri Dec 03, 2021 4:42 pm)
PostPosted: Fri Dec 03, 2021 9:42 pm
Nice looking pick guard material. Where did you find the celluloid sheets?
PostPosted: Wed Dec 15, 2021 9:38 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
I made an OM pickguard from a D pickguard before... At first I tried cutting it by hand as best as I can do it... but it wasn't good enough (anyone could tell that it looked like a kid did it), so I used my laser and a pattern I found online. Then it looks perfect.
Typhoon Guitars
Users browsing this forum: Bing [Bot], Kbore and 16 guests
