It is currently Wed Jul 30, 2025 12:31 am
 Post subject: Rift cut wood
PostPosted: Fri Apr 17, 2020 6:27 pm
First name: Nathan
Last Name: Peirson
I must admit I can be a wood hoarder. I have carried around pieces and scraps for years. At the time I always told myself I would build something useful, like furniture or cabinets. As I get older my thoughts have turned to building instruments, so recently I have started going through my stockpile looking for quarter sawn pieces....not much there, but I have a lot of mahogany that is rift cut or flat sawn. Not sure about the rift cut stuff for instruments though. Has anyone had any success with it?
 Post subject: Re: Rift cut wood
PostPosted: Fri Apr 17, 2020 7:57 pm
A lot of the back sets being used today have some off quarter "rift cut" sections. Mahogany is one of the most stable of woods , so I would consider using it even if rift cut.
PostPosted: Fri Apr 17, 2020 8:58 pm
Yeah and depending on the thickness, a flatsawn board can be used for necks...
PostPosted: Sat Apr 18, 2020 5:30 pm
First name: Josh
I will use riftsawn for necks if the species is a stable one. Mahogany qualifies.
PostPosted: Sat Apr 18, 2020 5:42 pm
Mahogany and Spanish Cedar both are extremely stable once dried. Luthiers in Spain have used both for many years regardless of grain orientation.
PostPosted: Sat Apr 18, 2020 5:43 pm
I have some large boards that need to be resawn of mahogany that I bought locally on Craig's List. I normally would not use flat sawn wood but this is some of the most highly figured mahogany I've ever seen. So I will be using it. Mahogany as was mentioned is very stable and studies show that QS wood is no stronger then flat. It's more stable though but mahogany is almost dimensionally stable. I regularly use flat sawn mahogany for necks too. The stock I have is 75 years old now, very stable even flat sawn.
PostPosted: Sat Apr 18, 2020 6:22 pm
First name: Josh
Flatsawn boards can also be laminated on their broad faces into a ‘faux quartersawn’ neck blank.
First name: Josh
(Sorry, double post)
PostPosted: Fri Apr 24, 2020 10:49 am
Last Name: Arnold
City: Newport
Zip/Postal Code: 37821
There is no good reason to insist on quartered (vertical grain) mahogany for necks. It is not stiffer, and is more prone to headstock and heel breaks than rift or slab. I try to avoid slab cut wood for sides, due to the rippling that can occur during bending. IMHO, rift cut mahogany is just fine.
PostPosted: Fri Apr 24, 2020 11:04 am
Last Name: Ball
For laminated necks with a center stripe laminate, I like to use rift sawn wood, as close to 45 degrees off quarter as possible, with the end grain angling outwards from the center laminate--looks like an inverted V /|\ when viewed from the end. Sort of a faux bookmatch. Done this way, when the neck is carved, it has medullary rays showing all around the neck shaft.
