It is currently Sun Jul 27, 2025 9:46 am
 Post subject: Stained wood
PostPosted: Sun Nov 25, 2018 10:41 am
City: Lawrence
Zip/Postal Code: 66047
I left a clamp laying against a piece of wet Black Limba and it left a stain.
Aside from kicking myself for being a "Dumb Dave" is there some way to get rid of the stain.
The wood is about .05 thick.
 Post subject: Re: Stained wood
PostPosted: Sun Nov 25, 2018 11:11 am
First name: Brad
Last Name: Hall
City: Windsor
State: Ca.
Zip/Postal Code: 95492
My inclination would be to try oxcylic acid. Works great on stained redwood and cedar. Try a small test sample first. Available at most lumber yards.
Brad Hall
Mystic Dawg Guitars
These users thanked the author BradHall for the post: Dave Rickard (Sun Nov 25, 2018 12:03 pm)
PostPosted: Sun Nov 25, 2018 11:50 am
That's 2 votes for oxalic acid, Dave. Buy it in powered crystals and mix up a little bit. Make sure you rinse the wood after to remove the acid before sealing and finishing.
These users thanked the author Chris Pile for the post: Dave Rickard (Sun Nov 25, 2018 12:03 pm)
PostPosted: Sun Nov 25, 2018 1:27 pm
Make sure you keep the crystals and any solutions in a safe place. Oxalic acid is a poison if ingested.
These users thanked the author Clay S. for the post: Dave Rickard (Sun Nov 25, 2018 2:07 pm)
PostPosted: Sun Nov 25, 2018 4:43 pm
Last Name: Minch
City: Chestertown
Zip/Postal Code: 21620
I had to use OA on a piece of furniture maple - just a local spot. I mixed it weak and it still left a spot that is much lighter than the surrounding light wood. I would definitely try it on a scrap piece first.
Ed
PostPosted: Mon Nov 26, 2018 8:16 am
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
That may be a permanent feature on a wood like limba. If you use wood bleach like mentioned you will need to do all the pieces completely to keep it matching in color. Having had a similar situation on white oak when I was doing custom staircases I doubt you will have a high level of success.
Brian
These users thanked the author B. Howard for the post: Dave Rickard (Mon Nov 26, 2018 8:27 am)
PostPosted: Mon Nov 26, 2018 11:15 am
Last Name: Beaver
City: Lake Forest
What does the other side look like? If the discoloration went all the way through then there would be no saving it. Otherwise maybe you could scrape it off? At .05" it is already to thin for most parts of a guitar except maybe a head plate or as part of a laminate, so I am wondering what you were planning for it?
Joe Beaver
Maker of Sawdust
PostPosted: Mon Nov 26, 2018 5:12 pm
First name: Willard
Last Name: Guthrie
City: Cumberland
State: Maryland 21502
Zip/Postal Code: 21502
Country: United State
In general, you want to brush on the oxalic acid over the entire area, rather than work a small spot to get as even a color as possible. When the mixture dries, the unreacted acid will have to be neutralized with a basic solution - baking soda or borax (washing soda) works, followed by a distilled water wash. If dry oxalic acid is not readily available, deck brighter (used to brighter decking and other outdoor bare wood) contains dilute oxalic acid, and is quite handy in the shop and a bit less ferocious (sorry for the pun).
- Beth Brower
PostPosted: Mon Nov 26, 2018 6:41 pm
Last Name: shelton
City: Alsea
State: Oregon
Zip/Postal Code: 97324
from my experience with the same thing, Brian is correct. It's pretty much hopeless.
These users thanked the author jshelton for the post: Ken Lewis (Mon Nov 26, 2018 9:14 pm)
PostPosted: Mon Nov 26, 2018 9:15 pm
First name: Ken
Last Name: Lewis
City: Mt. Pearl
State: NL
I would try sanding as a first measure as the stain may not be very deep. This won't worsen the situation so nothing to loose.
I see it's only .05 thick so maybe not:)
PostPosted: Tue Nov 27, 2018 8:12 am
Last Name: Howard
City: Magnolia
State: Delaware
Scraping will be hard..... this stain did not come from the metal of the clamp, it is not rust on the surface, in fact the metal likely had little to do with it.... What we are seeing is how the water wicked the tannin out of the wood, these stains go fairly deep typically.
Brian
PostPosted: Tue Nov 27, 2018 8:33 pm
City: Lawrence
Thanks for the tips. Oxalic acid is the primary active ingredient in bar keepers friend.
I have some cut offs to try it on. I'll try to replicate the stain and then see what happens.
I'll report back when I get home.
PostPosted: Tue Nov 27, 2018 11:16 pm
Last Name: Smith
City: Graton
Zip/Postal Code: 95444
I have heard Petrolium Jelly works. You know that pink stuff. I have never tried it.
Michael F Smith
Goat Rock Ukulele
http://goatrockukulele.com
PostPosted: Wed Nov 28, 2018 3:15 pm
"I have heard Petrolium Jelly works. You know that pink stuff. I have never tried it."
Naval Jelly?
PostPosted: Sat Dec 08, 2018 8:57 am
City: Lawrence
We made it home, finely.
I've been trying to stain a piece of cut off and having no luck.
Wood from the same board same distilled water same clamp leaning against it.
Let it set for 4 days,the other was 2 days.
No stain!
OMG I'm even a failure at ruining wood!
PostPosted: Sat Dec 22, 2018 11:25 am
City: Lawrence
Back home and in my shop.
I picked up some Savogran oxalic acid and practiced on some off cuts that I stained.
I also tried Bar Keepers Friend it's active ingredient is oxalic acid.
Both worked about the same so I used the Savogran.
I used a toothbrush to scrub and then wiped it clean with a wet paper towel and then dried it with a dry paper towel.
Three treatments about a hour between each I happy with the out come.
Thanks to everyone for the help.
PostPosted: Sat Dec 22, 2018 11:35 am
It looks like you eliminated most of the stain. If you find it becomes more noticeable under finish, you could tone the top coats.
