It is currently Sun Sep 21, 2025 7:18 pm
Post new topic Reply to topic  [ 38 posts ]  Go to page Previous  1, 2
PostPosted: Tue Nov 20, 2018 10:02 am
Last Name: Minch
City: Chestertown
Zip/Postal Code: 21620
kfish
Just above that press on the page are a couple of 1 ton units at a lower price - is it the magnet you are after?
Ed
PostPosted: Tue Nov 20, 2018 10:17 am
First name: Brad
Last Name: Combs
SnowManSnow wrote:
kfish wrote:
According to the answered questions, this Palmgren is drilled on one end of the ram. 3/8", 3/4 inch deep with a magnet to hold the bits.
https://www.amazon.com/gp/product/B0006 ... NI0B&psc=1
Is that depth enough to accept the stewmac caul?
The SM caul is 3/8" shank so you are good there. I just measured and the shank is 1" long, so you would be good I would think. FWIW, the SM arbor is drilled to 1 1/4" depth.
Brad
PostPosted: Tue Nov 20, 2018 11:53 am
Online
Ruby50 wrote:
kfish
Ed
It’s the already drilled hole in the shank that accepts the “bits”
PostPosted: Sat Nov 24, 2018 3:57 pm
First name: Kent
Last Name: Fishburn
City: Woodstock
State: Illinois
I wasn't the one looking for a press but was responding to the OP.
An update to the conversation, Stewmac has theirs on sale for $77.82
Kent
PostPosted: Sat Nov 24, 2018 7:05 pm
Online
Kent
I saw that:) thanks
PostPosted: Sun Nov 25, 2018 1:04 am
First name: David
Last Name: Ingalls
City: Ashland
State: OR
Zip/Postal Code: 97520
I think I paid about $50 for my arbor press from Harbor Freight, before modifications. I'd have been glad to pay an extra $27.82 not to have to get off all the grease it was packed in and correct the little fit flaws between the mismatched components.
Or get this one. It's already got a 3/8" ram bore. And anything Jet has a good chance of being better than anything HF.
https://www.amazon.com/JET-AP-0-Ton-Arb ... B001BAE2YS.
PostPosted: Sun Nov 25, 2018 7:40 pm
Online
I went ahead w the stewmac . It is $50 off right now, so I figure why not
PostPosted: Wed Nov 28, 2018 12:32 am
That sounds like a pretty good deal! I have just pressed them in on my drill press once and was pretty happy with the results. One thing that was cool is that I used my spindle lock on the drill press to hold the Fret in after I glued it. Does the stewmac arbor press have a lock down?
New username, same ole Pat Macaluso!
PostPosted: Wed Nov 28, 2018 7:59 am
Online
Yes sir it does lock down. For the already made modifications and the discount I felt it was worth the investment.
These users thanked the author SnowManSnow for the post: Pmaj7 (Wed Nov 28, 2018 1:54 pm)
PostPosted: Fri Dec 07, 2018 2:07 pm
cobble!cobble! cobble!
This turkey worked surprisingly well.
Here is the first iteration of my bottle capper fret press. I pulled the cotter pin and turned the rod upside down and made a home made fret caul out of a scrap of richlite. A large rubber band retracts the press. I think the idea merits making some additional refinements although it works as is. I think I will refine the handle by adding some wood to lengthen it and redo the way the rubberband attaches to the rod. By keeping the fret caul removable I can still reverse the rod and use it as a bottle capper when necessary.
PostPosted: Fri Dec 07, 2018 2:53 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
Clay, how did you cut the richlite radius. Is there a groove for the fretwire or is it just a flat* radius?
*I recognize that flat radius is not correct but you know what I mean <G>
Bryan Bear PMoMC
PostPosted: Fri Dec 07, 2018 5:29 pm
Hi Bryan,
To cut the radius I started with a square piece of richlite and using the end of a pre-radiused fingerboard marked the radius on the block. I projected the line a bit farther on both sides and used the top edge of the thick pencil line to reduce the radius to what the fret top might have. I bandsawed close, then sanded to the line. I drilled the mounting hole with a drill press, and trimmed the sides on the tablesaw.
It is just a "flat radius". Some time ago I bought a couple of Stew Mac fret press inserts and was going to cut a groove to insert them, but they have gone missing, and maybe just as well. The wider surface gives me a greater margin of error for centering the fret.
As far as pressing the fret, it works as well as the 1/2 ton HF arbor press I used to have. It will require a bit more setup to make it as handy. When I bought the arbor press I caught it on a 1/2 price sale for $20. After it disappeared I kept hoping to find another one on sale, but no luck. Now I only see the one ton presses for sale.
Old cast iron bottle cappers like the one I have can be found on ebay for about $10. So if you don't mind cobbling things together it can be a cheap alternative.
PostPosted: Sun Dec 09, 2018 6:59 pm
Finished the press up to my usual low standards of bodging - it works well enough and hopefully is too ugly to steal. laughing6-hehe
Users browsing this forum: bftobin and 42 guests
