It is currently Sat Aug 09, 2025 3:04 am
 Post subject: Rear plate pattern
PostPosted: Thu Oct 27, 2016 10:02 am
Hi just after opinions on whether to leave colouring in on this rear plate or not
Many thanks
It's not symmetric and there's no light colouring on reverse side on one of the boards
 Post subject: Re: Rear plate pattern
PostPosted: Thu Oct 27, 2016 10:13 am
FYI image size is way to big -- about a half page.
I would trim it out, especially since it is not a good book match. $.02
Ken Cierp
PostPosted: Thu Oct 27, 2016 10:15 am
OK thanks Ken
Image is ok on my phone ..weird I don't know why it's gone supersize
PostPosted: Thu Oct 27, 2016 11:36 am
First name: Willard
Last Name: Guthrie
City: Cumberland
State: Maryland 21502
Zip/Postal Code: 21502
Country: United State
It seems to me that sap wood is a little like a well shaped fedora...it's certainly not for everyone. Much of the plantation-grown East Indian Rosewood we see is so nondescript that any hint of an interesting color or pattern variation seems like something to cherish. For a factory guitar clone, perhaps do as Mr. Cierpilowski suggests and trim it out, but for something with a bit more panache, the minor asymmetry might lend an interesting grace note to an otherwise unremarkable composition.
- Beth Brower
These users thanked the author Woodie G for the post: cablepuller1 (Thu Oct 27, 2016 11:54 am)
PostPosted: Thu Oct 27, 2016 11:42 am
First name: Jay
Last Name: De Rocher
City: Bothell
State: Washington
I would remove it too, if it leaves you enough width for the back. Does that outline drawn on the back show the guitar you're going to build?
PostPosted: Thu Oct 27, 2016 11:46 am
Last Name: Parker
City: Charleston
State: West Virginia
Zip/Postal Code: 25314
Just on the size of the photo: If you use an iPhone, the size of the image is always too big for this forum. When I post photos here, I always have to take them on my phone, e-mail them to myself, download onto a PC, then resize to small. Then I can attach them here without an issue. A bit of a hassle, but it is what it is.
On the back: Maybe try trimming the left side enough to get closer to symmetry. If that won't work, then cut the distinctive pattern out altogether. But, something I always have to worry about is whether the back is big enough. I like a 16" wide lower bout, so I watch the amount of scrap on the outside edge very closely.
These users thanked the author doncaparker for the post: cablepuller1 (Thu Oct 27, 2016 11:57 am)
PostPosted: Thu Oct 27, 2016 11:57 am
No it won't show much on the back and the other edges butted up look OK also ..
Just not sure about the coloured bit
PostPosted: Thu Oct 27, 2016 11:59 am
If you take the image with an IPhone just use Tapatalk to post it and the size will be fine, plus it is easy. I often post the images with Tapatalk then edit the post on the computer where it's easier to add the text.
As far as the back goes, I am generally a fan of some sapwood in the middle but in this case,and especially with the herringbone strip, I think it is more of a distraction and I would trim it out. However, it is wood so whatever you decide will probably be just fine.
These users thanked the author SteveSmith for the post: cablepuller1 (Thu Oct 27, 2016 12:16 pm)
PostPosted: Thu Oct 27, 2016 12:16 pm
I would definitely keep it! But only if you get rid of the center strip. However, I would cut down the left side just a little to make it a little closer. If you really want the center strip, then get rid of this app. Or, if you just use a simple black center strip or maybe a bwb or maybe something the same as the binding.
These users thanked the author Pmaj7 for the post: cablepuller1 (Thu Oct 27, 2016 12:17 pm)
PostPosted: Thu Oct 27, 2016 12:34 pm
Last Name: Parker
City: Charleston
I agree that you should choose between the distinctive sapwood pattern and the center purfling strip. One or the other, but not both.
I have moved away from using center purfling strips, for the most part. I like how the big, uninterrupted field of rosewood (or whatever) looks, even without an interesting grain pattern in the middle.
These users thanked the author doncaparker for the post: cablepuller1 (Thu Oct 27, 2016 12:47 pm)
PostPosted: Thu Oct 27, 2016 12:46 pm
Are you able to create an invisible joint in the rosewood donca?
PostPosted: Thu Oct 27, 2016 1:00 pm
First name: Jay
City: Bothell
State: Washington
I go back and forth on center strips depending on the type of wood, the grain pattern, the size of the body, and the overall look of the guitar. I agree about not combining the sapwood and a backstrip.
Cablepuller - If you decide to go ahead and trim the plates as much as you can and still keep them wide enough, but find that a bit of the sapwood remains, an inlaid backstrip plus purfling might be wide enough to cover it.
These users thanked the author J De Rocher for the post: cablepuller1 (Thu Oct 27, 2016 1:13 pm)
PostPosted: Thu Oct 27, 2016 1:17 pm
First name: Rob
Last Name: Lak
State: Massachusetts
If it was me... by time I got the joint straight, it would be gone anyway... laughing6-hehe
These users thanked the author Robert Lak for the post (total 2): Bryan Bear (Fri Oct 28, 2016 10:50 am) • cablepuller1 (Thu Oct 27, 2016 1:34 pm)
PostPosted: Thu Oct 27, 2016 1:42 pm
State: Tennessee
Leave it, I like the asymmetry, it's small enough it won't dominate the back and adds some interest
These users thanked the author Clinchriver for the post: cablepuller1 (Thu Oct 27, 2016 1:47 pm)
PostPosted: Thu Oct 27, 2016 2:49 pm
Last Name: Parker
City: Charleston
Yes, especially in rosewood. It is pretty dark. In fact, after I glue the halves together, scrape the glue off, thickness sand the whole thing, and cut it to the rough shape of the guitar, I sometimes have a hard time finding the center line again. Cutting a little notch in the scrap portion on both ends can help avoid that, but I have forgotten to do that, and I have to really look hard to find the line afterward. Once the whole guitar is together, it is a really nice look.
Lighter woods might not be as forgiving. But, then again, we don't put center purfling strips on a maple electric guitar top, and I don't think I normally see them on archtop backs. The bookmatched maple looks cool on its own.
I've used center strips, and they are fine. I have just moved toward not using them.
These users thanked the author doncaparker for the post: cablepuller1 (Thu Oct 27, 2016 2:53 pm)
PostPosted: Thu Oct 27, 2016 3:26 pm
If you decide to trim it out and have a width issue then it looks like this set might look just fine if you matched the other edges and left the sapwood on the outside of the upper bout.
These users thanked the author SteveSmith for the post (total 2): Bryan Bear (Fri Oct 28, 2016 10:51 am) • cablepuller1 (Thu Oct 27, 2016 3:27 pm)
PostPosted: Thu Oct 27, 2016 4:29 pm
Last Name: Lewis
City: Newnan
State: Georgia
Zip/Postal Code: 30265
I would lose the center strip entirely and cut out the sapwood like shown, then join. Turn the joined plate upside down to gain more room for the lower bout - place the upper bout on the end the sapwood was cut out. Just my $.02.
Like most folks are saying either get rid of the herringbone or the sapwood. Don't keep both and I would personally get rid of both. However you join this back, it's going to be pretty.
John Lewis
These users thanked the author John Lewis for the post: cablepuller1 (Fri Oct 28, 2016 2:37 am)
PostPosted: Thu Oct 27, 2016 4:36 pm
Last Name: Beaver
City: Lake Forest
I'm leaning the same way as Steve suggested, but I would start by opening he bookmatch the other way right from the start. (Sapwood on the outside). If the sapwood section was more uniform and wide enough that it showed properly after the joint is cleaned up, I would consider using it. But its not.
And, what John showed works for me if the boards are wide enough
Joe Beaver
Maker of Sawdust
These users thanked the author Joe Beaver for the post: cablepuller1 (Fri Oct 28, 2016 2:37 am)
PostPosted: Thu Oct 27, 2016 5:30 pm
First name: Willard
Last Name: Guthrie
City: Cumberland
I assumed the herringbone was a fix for width in the event the sapwood was trimmed out - my mistake! As Mr. Macaluso suggested, using both the herringbone and sapwood would make for a very busy appearance, while sapwood without the purfling seems to me to be interesting, and removing the sapwood just begs for something like some purfling to add a bit of visual interest.
- Beth Brower
These users thanked the author Woodie G for the post: cablepuller1 (Fri Oct 28, 2016 2:38 am)
PostPosted: Thu Oct 27, 2016 6:47 pm
I should have noted that I do like the look of the herringbone or some other center strip if the sapwood is moved out of the pattern.
These users thanked the author SteveSmith for the post: cablepuller1 (Fri Oct 28, 2016 2:38 am)
PostPosted: Fri Oct 28, 2016 2:40 am
Thanks John . Appreciate the picture
PostPosted: Fri Oct 28, 2016 10:04 am
My logic is by trimming out the sap wood your assembly you will once again have universal/normal appeal -- future observers will never know and the question of artsy, or weird is non existent.
I like with or without center strip -- depends on how interesting the grain convergence looks.
Ken Cierp
These users thanked the author kencierp for the post: cablepuller1 (Fri Oct 28, 2016 10:13 am)
PostPosted: Sun Oct 30, 2016 5:43 am
Steve beat me to it. What does it look like with the sapwood on the exterior?
PostPosted: Sun Oct 30, 2016 6:45 am
First name: Willard
Last Name: Guthrie
City: Cumberland
There are currently three build and one build/repair student in the shop, so we have some interesting discussions when everyone is crowded in to the 1600 square foot main shop. One of the things the boss mentions frequently is the issue of intent, as in whether or not a builder has a clear path to a specific goal when making decisions. In other words, changes which move away from conventional or widely accepted standards must not only be made with clear intent, but they must also appear to have been made in a purposeful manner to others.
An example might be seen in Mr. Desforge's sapwood use on the back and sides of his avatar instrument - it is very clearly intentional on his part, and no reasonable person would conclude that Mr. Desforge selected a back and side set too narrow for the job, or somehow lacked clear intent. While not to everyone's taste - after all, someone bought all those beige Fords back in the 1970s - is is just the sort of instrument that I would expect to be featured in a marque image on the home page of a skilled custom builder.
I believe that some of the reservations expressed earlier in the thread re: sapwood are likely a manifestation of ensuring this element of intent is addressed when playing with accepted design elements. In looking at the photo of the plate again, I can see why there is concern - the sapwood area is small, is lacking in symmetry, and likely is not hinted at elsewhere in the composition, which is to say that it risks looking like something done with less than clear intent.
- Beth Brower
These users thanked the author Woodie G for the post (total 2): cablepuller1 (Sun Oct 30, 2016 5:19 pm) • J De Rocher (Sun Oct 30, 2016 12:17 pm)
PostPosted: Sun Oct 30, 2016 5:14 pm
Yes it would be outside the template
Users browsing this forum: No registered users and 42 guests
