It is currently Sat Aug 09, 2025 8:43 am
Post new topic Reply to topic  [ 35 posts ]  Go to page Previous  1, 2
 Post subject: Re: Shop flooring
PostPosted: Fri Sep 23, 2016 9:11 am
Last Name: Minch
City: Chestertown
Zip/Postal Code: 21620
I just stick my foot out to break the tool's fall. Works especially well with chisels and when I am wearing sandals.
Ed
I have experience with 3/4" plywood, sanded one side, on top of 5/4 X 4" salt treated sleepers and it works well.
These users thanked the author Ruby50 for the post: Colin North (Sun Sep 25, 2016 2:55 am)
PostPosted: Fri Sep 23, 2016 10:31 am
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
david farmer wrote:
one thing not to forget is traction on the top surface.
A lot of surfaces have traction when the'r clean but a little dust turns them into skating rinks.
I've worked in some shops that were death traps when sawdust was on the floor. One was finished wood. The other was linoleum. Even smooth concrete has had me doing unplanned chorus line kicks to stay upright. Not good around the 7-10hp shapers in that place. :o
MY current shop has paint that I mixed silica (I think) sand into . There are a couple of small patches that don't quite have enough. I should have added more.
Make sure what ever you end up with passes the wood dust traction test.
That is a very good point, I have experienced the saw dust slide too. I neglected to mention that I added grit to my oil base paint on my floor. I don't remember what I added though.
Bryan Bear PMoMC
PostPosted: Fri Sep 23, 2016 10:41 am
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
Ed
Ha! It is funny how we have the natural reaction to slow the fall of dropped objects with our feet but are somehow instantly able to decide that is a bad idea with something sharp. Any time a knife or chisel or something sharp rolls, is knocked off a counter or dropped my natural reaction to try to stop it is thwarted and I let it fall. I also bend one knee to lift the closest foot off the floor (reducing the odds of one of my feet getting stabbed). I don't know where I learned this but I do it every time. The strange thing is that it is specific to sharp objects. I'll still try to catch a falling object even if it is something like a bowl of yogurt that will make a mess all over my clothes rather than just the floor.
Bryan Bear PMoMC
PostPosted: Fri Sep 23, 2016 4:12 pm
Last Name: Shanklin
City: Windsor
State: ON
Hesh wrote:
AND you can lift them up to clean under them...:)
Don't you mean "sweep" under them, Hesh. laughing6-hehe
Bob
PostPosted: Fri Sep 23, 2016 7:16 pm
Last Name: Farmer
City: Durango
State: CO
Unfortunately we don't all have a CPU that works that fast Bryan.
At a job-site I tugged an extension cord with my foot that started a biscuit joiner toppling off a bench. I reached out but missed the catch with my hand, but not before bumping the paddle trigger starting the blade spinning. I reflexively stuck my foot out like an idiot to keep it from getting damaged on the concrete. oops_sign Even though the blade was fully enclosed in the housing, I watched it fall perfectly nose first onto my foot. Inertia slid the plunge mechanism and the blade went through my leather shoe and into my toe. :o
Mercifully, just a few stitches were required, not a #0 biscuit plug.
PostPosted: Fri Sep 23, 2016 7:59 pm
City: Escondido
Zip/Postal Code: 92029
I use a thick soft layer of sawdust and wood chips. It took me years of work, but I'm satisfied with the results.
These users thanked the author rlrhett for the post (total 3): Bryan Bear (Sat Sep 24, 2016 8:18 am) • david farmer (Fri Sep 23, 2016 11:24 pm) • bionta (Fri Sep 23, 2016 8:05 pm)
PostPosted: Fri Sep 23, 2016 9:35 pm
Last Name: Parker
City: Charleston
State: West Virginia
Zip/Postal Code: 25314
David--
I offer this story to help you feel less embarrassed, compared to my buddy. He was recently using a serious, gas powered pressure washer. He had the nozzle in his left hand. He went to move the base unit with his right hand and accidentally grabbed the muffler. Since that burned his right hand, he instinctively wanted to cool the burn. He thought: squirt it with water. He pointed the nozzle at his burned right hand and pulled the trigger. The pressure was so strong he cut a 3/4" gash on one of his fingers; almost severed the nerves, according to the doc. Turns out he just needed stitches, but it could have been a lot worse.
My new nickname for him is lefty.
These users thanked the author doncaparker for the post: david farmer (Fri Sep 23, 2016 11:22 pm)
PostPosted: Sat Sep 24, 2016 7:09 am
First name: Gregor
Last Name: Crothers
I haven't put flooring down in my basement yet, but I have got the subfloor in.
1" rigidfoam (lapped) covered with 5/8 T&G plywood. The floor is very rigid and warm and was a cheap alternative to the premade stuff. There were a fair amount of Tapcons used (1300sq/ft) and my slab and walls were sound. Very happy with it.
Wake up and smell the rosewood!
PostPosted: Sat Sep 24, 2016 8:20 am
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
Yikes David! I hope you're back up and running (literally) now!
Bryan Bear PMoMC
PostPosted: Sat Sep 24, 2016 10:16 am
City: Alton
State: IL
Tile in the area I use my hand tools, my power tools currently have just concert. We are looking at buying a new place, and more thought will be put into the new place's flooring. Actually, it wasn't so much lack of thought as lack of funds in this house.
I dropped a brand new brad point 11mm last week, right on the tip. That sucked.
Speaking of reflexes, I once dropped a trim router and decided to catch that. Right before I caught it I remember thinking that it was a bad idea. Just lost a chunk of skin on one finger, and a little bit of nail. It's all grown back. I'm much better at letting tools fall now.
cron
