It is currently Sun Aug 10, 2025 12:36 am
PostPosted: Sat Aug 13, 2016 4:47 pm
Woodie G wrote:
. . . everything - including using the Keurig- is done that way here.
Tell the boss it's time to edit the list. He needs to add another step.
"- Donate Keurig to a good cause. But a Nespresso." [FACE WITH STUCK-OUT TONGUE AND WINKING EYE]
In a moment of needing something to do, I took the chisel to it yesterday and got things within 1/32" all around. I was surprised by how well it worked. When I cut it to shape on the bandsaw, the saw pulled fibers out like crazy. The chisel left nice, clean lines, particularly on the end grain where most of the havoc had been wreaked previously. I'll be able to get into the shop to finish up with the router tomorrow.
Thinking this process through has made me realize I don't need to leave as much overhang (roughly 1/4 to 3/8"). David Farmer mentioned undersizing the top. I'm not willing to go that far, but 1/16" to an 1/8th overhang is certainly reasonable.
PostPosted: Sat Aug 13, 2016 5:01 pm
Last Name: Farmer
City: Durango
State: CO
Don't you just love it when the best tool for a job turns out to be a nice sharp chisel or plane? bliss
It's easy to work down hill with a chisel. The only place you have to be carful about is right where the grain switches direction at the waist.
These users thanked the author david farmer for the post: Pmaj7 (Sun Aug 14, 2016 6:13 pm)
PostPosted: Sat Aug 13, 2016 6:26 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
I use one of those diamond cutoff blades for Dremel, and drum sander to finish. If everything is glued down solid, likelihood of tear out is lower when using proper router cuts. Spiral downcut good too if most overhang trimmed away. So far, no disasters with drum sanding approach. I don't eschew router approach, just too much setup work for my liking.
PostPosted: Sun Aug 14, 2016 4:35 am
[quote="James Orr"] ........... took the chisel to it yesterday and got things within 1/32" all around ...... The chisel left nice, clean lines, particularly on the end grain where most of the havoc had been wreaked previously........
[Sent from my iPhone using Tapatalk/quote]
[:Y:]
PostPosted: Sun Aug 14, 2016 8:48 am
I didn't read all the posts so forgive me if I am redundant... I used to trim the plates just inside the side perimeter so that when I'm sanding sides I'm not fighting the back and top plates and end grain in some locations. Made it much easier to do.
This took two passes. The first with a flush cut bit and the second with the binding bit set with the bearing that gave me the shallowest cut possible beyond flush. Climb cuts in both instances as well.
These users thanked the author Hesh for the post: James Orr (Sun Aug 14, 2016 3:12 pm)
PostPosted: Sun Aug 14, 2016 3:37 pm
1/4" downcut carbide spiral bit with flush cutting bearing on the tip for me. Very quick, and zero trouble
