It is currently Thu Aug 14, 2025 9:20 am
 Post subject: Soundport
PostPosted: Thu Dec 10, 2015 12:51 pm
First name: Danny
Last Name: Vincent
I have to put a soundport into an upcoming build and am looking for any pointers. Can anyone direct me to a toot on the procedure. I checked the archives here and did see the routing method of Chris.
I have seen some sexy ones with contrasting layered backer that shows up nice if you bevel the edge.
Couple of questions that come to mind. What would the minimum thickness of the backer be? I guess there really wouldn't be a maximum, within reason, if going for a look with layers showing on the bevel.
What is the grain orientation of the backer?
I'm guessing one would make up a gluing caul for the inside and just clamp it in the mold?
If anyone would like to post a photo of theirs please do!
Cheers,
Danny
 Post subject: Re: Soundport
PostPosted: Thu Dec 10, 2015 1:04 pm
One veneer at cross grain, 2nd veneer grain same as side. If you're super lucky you can use matching off cuts. Put them in after the sides are bent and the linings are in. Using veneers means you don't have to heat bent the backups.
I find that sound ports make such a subtle difference even at he best of times to not be worth the fuss.
.02
These users thanked the author meddlingfool for the post: Robbie_McD (Thu Dec 10, 2015 11:36 pm)
PostPosted: Thu Dec 10, 2015 1:08 pm
This one's bound but are is 2 layers inside, contrasting cross-grain against the side, and matching same direction inside. both about 1 mm IIRC
Bend them on a hot pipe and clamped with a flexible caul to glue when sides were in the mold.
And I quite like them.
PostPosted: Thu Dec 10, 2015 2:03 pm
First name: Danny
Last Name: Vincent
I
Good thinking. I've never done one and I get to practice on a Brazilian/Carpathian commission. eek
PostPosted: Thu Dec 10, 2015 2:05 pm
First name: Danny
Last Name: Vincent
Thanks Colin. Nice! What's going on in the middle? Is that a decorative feature?
PostPosted: Thu Dec 10, 2015 2:57 pm
It's easy peezy.
PostPosted: Thu Dec 10, 2015 4:53 pm
Thank you.
Well, its an attempt to make one, but not originally planned.
I was attempting to tune body resonances "a la" Gore and it was a little too big originally
Took soundhole binding first, then soundport binding was second attempt, but it took the disc in the middle to finally nail it.
These users thanked the author Colin North for the post: DannyV (Fri Dec 11, 2015 12:57 am)
PostPosted: Thu Dec 10, 2015 9:03 pm
1/64 plywood available at many hobby stores works well for reinforcement.
These users thanked the author Jim Watts for the post: DannyV (Fri Dec 11, 2015 12:56 am)
PostPosted: Fri Dec 11, 2015 4:10 pm
Last Name: Collins
City: Argyle
State: New York
Zip/Postal Code: 12809
nice Colin
The binding & sides look great also.
Mike Collins
Users browsing this forum: Ken Lewis and 27 guests
