It is currently Sat Aug 16, 2025 12:17 am
PostPosted: Tue Dec 01, 2015 3:46 am
Bending a 0.075" thick Ceylon satinwood (chloroxylon swietenia)? side and got a fair bit of springback.
Using SSII, very little water and a bending machine with blanket, temp was taken up quickly to 300/310 F for 15 minutes, then cooled for 1 1/2 hrs before temp taken up again to same 300/310 F for 5 minutes. Then left overnight to cool.
I think the temperature may have been a little low?
Anyone got any suggestions for a (safe) temperature limit for side bending with a non-oily wood? It's a light coloured wood and don't want to scorch it!
PostPosted: Tue Dec 01, 2015 7:59 am
Last Name: Colbert
City: Anacortes
340°F is my current max using parchment/masking paper on both sides. I then cook for 20 minutes at 280°F for twenty minutes and allow it to return to room temperature. For wood known for spring back, I repeat the last operation at least 3 times. Works for me..
M
PostPosted: Tue Dec 01, 2015 8:52 am
you can go to 375 hold for about 2 min then let the temp set at 250F for about 15 min. Once cool ( about 40 min ) you can take out and clamp to mold.
PostPosted: Wed Dec 02, 2015 8:14 am
375 - wow7-eyes
I take it that this won't darken the side significantly, even with light colored wood, with only 2 minutes at that temperature, just seems really hot.
I see you offered the same advice for the post about Bubinga, so it's not likely to be a typo.
Would this be a good method for maple, and do you use supersoft, or just this temperature works.?
PostPosted: Thu Dec 03, 2015 2:14 pm
The safe bending temperature will depend on when the lignin starts to discolor, and will vary with the species and sample. Test if you can.
These users thanked the author Alan Carruth for the post: Colin North (Fri Dec 04, 2015 3:12 pm)
PostPosted: Thu Dec 03, 2015 2:51 pm
We have side profile templates for all our models so I can mark the inner most waist curve and use that as our positioning aide throughout the construction process. An added benefit is that if need be, we have the cut off section of the side that can be used for test bending to establish heat and moisture requirements for each set of sides.
Ken Cierp
These users thanked the author kencierp for the post: Colin North (Thu Dec 03, 2015 3:09 pm)
PostPosted: Tue Dec 08, 2015 2:50 pm
Just for information, 375F, hold for about 2 min then let the temp set at 250F for about 15 min is ace for curing springback, but turns the Ceylon Satinwood (chloroxylon swietenia) from a golden shiny glow to a nice shade of Tan.
No panic, just a test on offcuts.
Back to the "drawing board".
PostPosted: Tue Dec 08, 2015 3:51 pm
Well, that is not surprising since that is the temperature (190C) that thermally modified wood is heated to. So just keep it there for an hour and it will be toasted all the way through, nice and brown :lol:
Actually 2 minutes should not really penetrate much and should sand off. Biggest problem is that no method of heating during bending is perfectly uniform, so you are bound to get more "toasted" spots.
Grant
PostPosted: Tue Dec 08, 2015 4:33 pm
Tried sanding off, no go!
But it is reasonably even....
PostPosted: Tue Dec 08, 2015 4:44 pm
Some woods require more initial moisture during the heating/bending process to keep their shape once bent.
So with the off cuts how did the higher temperature do as far as holding the shape goes? Don't think you mentioned that, just that you got some "roasting".
PostPosted: Tue Dec 08, 2015 4:57 pm
By "ace for curing springback" I meant there was virtually none at all.
I am using SSII because of the interlocking grain, but was avoiding more water (just a quick wipe with a wrung out damp cloth) because the sides were rift to flat sawn, and the last set I built with cupped quite badly due to too much of the damp stuff.
I have another set which is pretty much perfectly quarter sawn, and I can probably use more moisture with that one.
Thanks for the tip Rod.
PostPosted: Thu Dec 10, 2015 3:55 am
You don't always get to see the results of requests for advice, so...
Did some more testing with offcuts, and decided after Rod's reminder to go with a new set, sides properly quarter sawn.
Tested the side offcuts from that.
SSII overnight, dry off, spray down, rub in, wipe off (basically more water)
Blanket on top, light bulbs underneath.
310/320 for 5 mins, down to 260/270 for 15 mins.
Cool off (2 hrs)
"Shock" quickly to 310/320, immediately back to 260/270 for 15 mins.
Cool overnight, straight to the mold, job done.
Thanks Rod, I got a bit blinkered after my previous cupping problems with the Ebay set.
PostPosted: Sat Dec 12, 2015 12:56 pm
Last Name: Beaver
City: Lake Forest
Colin, great looking bend. You did nail it!!!
Joe Beaver
Maker of Sawdust
These users thanked the author Joe Beaver for the post: Colin North (Sat Dec 12, 2015 3:22 pm)
PostPosted: Sat Dec 12, 2015 3:58 pm
Collin, I like the connectors on your mold. Simple, very solid looking and unobstructed area for clamping! (Or should I say mould? I know ya'll invented the language!)
These users thanked the author Pmaj7 for the post: Colin North (Sat Dec 12, 2015 6:32 pm)
PostPosted: Sat Dec 12, 2015 6:43 pm
Shhhh!............
You'll give all my secrets away! gaah
laughing6-hehe
