It is currently Fri Aug 15, 2025 12:19 am
PostPosted: Fri Nov 13, 2015 5:52 pm
Hi
Soon be at the bridge positioning stage on my build and wondered what you guys use to position it
I used the stewmac calculator and a ruler last time but somehow ended up a bit of a sharp intonation on my last kit build.
Was looking through youtube and seen this guys jig and wondered if it was worth making
PostPosted: Fri Nov 13, 2015 6:16 pm
I have not used one of these, but I know one guy who did and ended up with his intonation way flat.
Why?
Well he had the action too high
I you use this device or the other alternatives like the stewmac adjustable saddles, you really need to
-get the neck relief correct
-cut the nut slots to final depth
-set the saddle height to get your desired 12th fret action
Then and only then check intonation and adjust bridge position.
These users thanked the author Jeff Highland for the post: cablepuller1 (Sat Nov 14, 2015 3:33 am)
PostPosted: Fri Nov 13, 2015 6:25 pm
Online
First name: Jay
Last Name: De Rocher
City: Bothell
State: Washington
I can't tell from the photo how that jig helps to position the saddle.
I've used a long ruler with fine divisions on the scale which worked fine, but required a lot of careful attention to get position right on the mark. I have positioned three bridges using the StewMac Saddlematic tool and it worked perfectly each time. In fact, I'm using it this afternoon to position the bridge on my current in-progress guitar.
http://www.stewmac.com/Luthier_Tools/Tools_by_Job/Bridges/Saddlematic.html
These users thanked the author J De Rocher for the post: cablepuller1 (Sat Nov 14, 2015 3:41 am)
PostPosted: Fri Nov 13, 2015 8:45 pm
First name: Greg
Last Name: Maxwell
City: Mount Vernon
State: Ohio
+1 for the Stew Mac Saddlematic. No math, no mistakes, no fuss. Works every time, on everything from new builds to checking vintage repair jobs.
It will probably be alright.
These users thanked the author Greg Maxwell for the post: cablepuller1 (Sat Nov 14, 2015 3:41 am)
PostPosted: Sat Nov 14, 2015 3:55 am
Thanks the saddlematic sounds great will see if they do it in the uk.
Just for my own reference heres pictures of the difference in tuning when open then fretted at 12th on my first kit build
I have been going back to my previous build and tweeking it just to try to learn about setting up my next build
I set the relief yesterday then lowered the saddle then the nut and it plays lovely now but would that of made the intonation worse or better
Also would this be adjustable at the saddle (filing a new one ) or is it to far out.
PostPosted: Sat Nov 14, 2015 5:45 am
Doing all those things will have reduced the 12th fret sharpness and improved the intonation.
Recheck it before getting too concerned.
These users thanked the author Jeff Highland for the post: cablepuller1 (Sat Nov 14, 2015 1:06 pm)
PostPosted: Sat Nov 14, 2015 7:38 am
Food for thought:
Instead of trying to position your bridges with the saddle slot already cut consider positioning the bridge, gluing it on, and then cutting the saddle slot exactly where it needs to be ON the guitar with the bridge already glued on.
This is how we do it and this is one of the intended used of the Collins Saddle Mill. It also gives you the ability to correct a poor saddle placement by plugging the recutting.
http://www.annarborguitars.com/styled-5/index.html
This has been a shameless self-promotion..... :D :roll: gaah :D
These users thanked the author Hesh for the post: cablepuller1 (Sat Nov 14, 2015 1:06 pm)
PostPosted: Sat Nov 14, 2015 8:04 am
First name: Casey
Last Name: Cochran
City: Gainesville
State: GA
Zip/Postal Code: 30501
Hesh wrote:
Food for thought:
Dear Santa...
Good judgement comes from experience. Experience comes from poor judgement.
These users thanked the author Casey Cochran for the post: Hesh (Sat Nov 14, 2015 9:36 am)
PostPosted: Sat Nov 14, 2015 9:21 am
All do respect -- as a tool designer I find the gizmo in the OP a little goofy and likely will lead to inaccurate results in actual operation. ie. Its compressing the sound board rather than pulling it into a dome.
Like Hesh shameless as well ---- KMG offers scale specific "Bridge Setter" fixtures at a very reasonable price.
Ken Cierp
These users thanked the author kencierp for the post (total 2): cablepuller1 (Sat Nov 14, 2015 1:07 pm) • Hesh (Sat Nov 14, 2015 9:36 am)
PostPosted: Sat Nov 14, 2015 9:42 am
First name: Greg
Last Name: Maxwell
City: Mount Vernon
State: Ohio
I also route the saddle slot after the bridge is glued on. That way I can locate the slot with micro accuracy rather than trying to micro-locate the bridge during bridge glue up. It certainly can be done either way (and I have done it both ways) but routing afterwords is much better for me.
These users thanked the author Greg Maxwell for the post: cablepuller1 (Sat Nov 14, 2015 1:07 pm)
PostPosted: Sat Nov 14, 2015 11:02 am
State: Tennessee
Hesh wrote:
Food for thought:
Got one on your bench :mrgreen:
Users browsing this forum: J De Rocher and 12 guests
