It is currently Fri Aug 15, 2025 3:54 am
 Post subject: Position markers again
PostPosted: Sat Oct 31, 2015 7:21 am
State: Tennessee
Question I have a bunch of MOP supposedly 2mm side side dots that measure .094 so do you all use a 3/32 or a #41?
Or just beat them in with a hammer :mrgreen:
Did a search and WF Fulton Company make brad point bits in wire and fractional sizes and you can get them here, www.woodshopbits.co
I have a couple #41 &#42 bits on the way :mrgreen:
PostPosted: Sat Oct 31, 2015 8:21 am
First name: Tim
Last Name: Mullin
City: Shefford
State: QC
Zip/Postal Code: J2M 1R5
0.094 looks like 3/32 to me, but far bigger than 2 mm!
PostPosted: Sat Oct 31, 2015 9:19 am
Yep, 3/32" should work. If it is too tight, there is an old machinist's trick where you can make the bevel on one side of the drill bit a little longer than the other side, which effectively moves the point to an off-center position. This will cause the drill bit make a larger hole.
PostPosted: Sun Nov 08, 2015 9:07 am
State: Tennessee
Did a search and WF Fulton Company make brad point bits in wire and fractional sizes and you can get them here, http://www.woodshopbits.co
#41 is a nice fit
Users browsing this forum: Bing [Bot] and 16 guests
cron
