It is currently Fri Aug 15, 2025 12:08 pm
 Post subject: Bolt on neck memo
PostPosted: Sat May 16, 2015 7:55 am
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
To; All builders using bolt on necks,
It has come to our attention that there are quite a few of you who are gluing in your M&T joints on your bolt on necks. Please refrain from doing this. Not only is this completely unnecessary, it negates the only main virtue of bolt on construction (necks that can be reset quickly and easily). This problem is compounded by the fact that most have never given proper consideration to headspacing the joint properly to allow for removal of one fret and the injection of steam to soften the glue. If you wish to glue your necks please learn to fashion and fit a proper dovetail, otherwise just bolt it on.
Thank you, The repair dept.
Brian
These users thanked the author B. Howard for the post (total 2): Cablepuller (Sun May 17, 2015 2:42 pm) • jack (Sat May 16, 2015 8:59 am)
 Post subject: Re: Bolt on neck memo
PostPosted: Sat May 16, 2015 9:53 am
Yup. Like tightening up the lug nuts on your wheels, then welding them all in place just to be sure.
PostPosted: Sat May 16, 2015 10:08 am
First name: Kevin
Last Name: Looker
City: Worthington
State: OH
Zip/Postal Code: 43085
Doesn't Martin glue their, IMO, oddball single screw version of a bolt on?
Kevin Looker
I'm not a luthier.
PostPosted: Sat May 16, 2015 11:22 am
Kevin Looker
Maybe the bolt is acting as a clamp for the glueup so they can just move em on down the assembly line?
PostPosted: Sat May 16, 2015 11:46 am
This became more difficult when I switched over to Aluminum wheels, but with the right equipment and a bunch of practice I finally got it!
PostPosted: Sat May 16, 2015 1:40 pm
First name: Tom
Last Name: West
State: Nova Scotia
To: The repair Dept.
RE: Glueing bolt on necks.
You may or may not be pleased to know that this station does not use ANY glue when bolting on a neck. None on the mortise and tenon and none on the fingerboard extension. Awaiting further instruction.
Build station
TOM
HLA
EDN
PostPosted: Sat May 16, 2015 3:45 pm
City: Lawrence
Zip/Postal Code: 66047
If I understand it Martin uses one bolt as a clamp and leave it in rather than removing the bolt/clamp.
This station uses 2 bolts no glue, we have used glue on the finger board extensions.
We will discontinue this practice as directed.
PostPosted: Sat May 16, 2015 4:38 pm
I don't get it.
Surely if bolted on is good, bolted and glued must be better?
PostPosted: Sat May 16, 2015 5:18 pm
First name: Murray
Last Name: MacLeod
City: Edinburgh
Country: UK
meddlingfool wrote:
I don't get it.
You forgot the smiley at the end , Ed.
Without it, some people might think you are being serious ...
PostPosted: Sun May 17, 2015 12:25 am
PostPosted: Sun May 17, 2015 1:54 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Are ya'll saying I shouldn't be using bolts with my glued dovetail?
PostPosted: Sun May 17, 2015 2:47 pm
While on the subject what bolts do you use (im doing one soon)
Whats the female bit called ,i know if i google "female screw wood" it will probably provide me with numerous adult sites
PostPosted: Sun May 17, 2015 3:32 pm
First name: Craig
Last Name: Gordon
Zip/Postal Code: 14216
Threaded inserts?
These users thanked the author CraigG for the post: Cablepuller (Sun May 17, 2015 3:33 pm)
PostPosted: Sun May 17, 2015 3:55 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
http://www.mcmaster.com/#standard-threa ... ts/=x82zod
BTW, what are those threaded inserts that would go into the tenon transverse-wise, with a threaded hole in the side?
PostPosted: Sun May 17, 2015 4:12 pm
First name: Rob
Last Name: McDougall
City: Cochrane
State: Alberta
Cross-Dowel?
http://www.leevalley.com/US/hardware/page.aspx?p=44238&cat=3,43576,45375,44238
PostPosted: Sun May 17, 2015 4:23 pm
We here in this factory will never use glue for the neck joint except for actual dovetail joints.
And we don't do dovetail joints.
PostPosted: Sun May 17, 2015 6:50 pm
First name: Wayne
Last Name: Brown
City: Huntersville
Zip/Postal Code: 28078
Mike,
I think they are called barrel nuts!
PostPosted: Sun May 17, 2015 10:21 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Thanks Robbie!! That's it. Thought they were externally threaded. Wayne, I thought that too. Search McMaster for barrel nuts. Nothing like the concept.
PostPosted: Mon May 18, 2015 12:09 pm
Last Name: Shanklin
City: Windsor
State: ON
Mike,
http://www.lowes.com/pd_137362-37672-88 ... Id=3012559
Bob
PostPosted: Mon May 18, 2015 8:38 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Well shut my mouth. [uncle]
PostPosted: Tue May 19, 2015 3:16 pm
First name: Zeke
Last Name: McKee
City: Goodlettsville
Zip/Postal Code: 37070
Sometimes I glue the strings to the saddle. Just to be sure they stay in place.....
PostPosted: Tue May 19, 2015 4:17 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
I hope you are using HHG for this because it is obviously superior for tone in string to saddle joints. I have a slightly different approach. I glue in my bridge pins to keep the strings on at the bridge. I weld them onto the tuner posts but I'm sure that is what everyone does. I do go the extra mile and weld the gears once I get it tuned to pitch that way I never have to mess with tuning again! bliss
Bryan Bear PMoMC
PostPosted: Tue May 19, 2015 11:26 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
I've eschewed the mechanical weld of tuned strings for liquid nails. Occasionally, I have found that the tuning drifts. So it's nice knowing that solvents and a heat gun can help me adjust when guitars come back for work.
PostPosted: Wed May 20, 2015 6:27 am
Last Name: Howard
City: Magnolia
State: Delaware
In a related note I had a customer bring in a guitar for a string change. Turns out his bridge pins were a little loose, so he had glued them in.........
Brian
These users thanked the author B. Howard for the post: Robbie_McD (Wed May 20, 2015 8:43 pm)
PostPosted: Wed May 20, 2015 6:54 am
Last Name: O'Melia
City: Huntsville
State: Alabama
No way. laughing6-hehe
Users browsing this forum: jfrench, Powdrell1 and 14 guests
