It is currently Sat Aug 16, 2025 8:54 am
Post new topic Reply to topic  [ 34 posts ]  Go to page Previous  1, 2
PostPosted: Thu Jan 29, 2015 9:15 pm
First name: Charlton
Last Name: Wang
Thanks, Tai Fu. That's too bad. I guess the slower grinder has much more modest air requirements. Maybe I'll get that instead.
Charlton
PostPosted: Fri Jan 30, 2015 9:03 am
I see that they did change the air requirement . The souix uses less air. I will change the listing thanks
As for run out , these have very little as compared dremel tools. The die grinder uses a roller bearing and not a bushing.
PostPosted: Fri Jan 30, 2015 9:31 am
Last Name: Wang
I thought the 70k one in the link was the Sioux. It's the one that presumably needs 5.5cfm.
Charlton
PostPosted: Fri Jan 30, 2015 10:02 am
I did correct that. I think there was a typo on the site.
I apologized for that.
there was a 5.4 at 90 psi rating it is adjustable. You can turn the speed up and down.
PostPosted: Fri Jan 30, 2015 10:06 am
Last Name: Wang
Thanks, John.
PostPosted: Fri Jan 30, 2015 10:35 am
you are most welcome
we are here to help
PostPosted: Fri Jan 30, 2015 11:01 am
John, What about oil mist?
PostPosted: Sat Jan 31, 2015 8:53 pm
if you check out the video I use a paper towel that is folded over the end of the exhaust hose and taped to it . You only need a drop of oil . if you over oil that can be an issue. The higher speed and the bearings make it a cleaner cut. These are used at CF Martin and Custom pearl Inlay among others.
PostPosted: Sat Jan 31, 2015 8:56 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
I found that with proper oiling I can hear a difference in the sound. When oil gets where it needs to go the RPM increases quite a bit...
Typhoon Guitars
Users browsing this forum: doncaparker, Ken Lewis and 26 guests
