It is currently Sat Aug 16, 2025 8:55 am
 Post subject: Paper for labels?
PostPosted: Sun Jan 04, 2015 11:01 pm
So, what paper are you guys using for labels? I've been using handmade paper and guitars have gotten quite a bit more responsive with incredible projection, drowned out three banjos! :mrgreen: Seriously though I do use handmade paper but due to the uneven quality of the paper the glue can wet it out and create dark spots on the label, and it seems a waste of time putting a label in and have to redo it.
I know this seems like a trivial question, but what has a quality look to it and worked well for you?
 Post subject: Re: Paper for labels?
PostPosted: Sun Jan 04, 2015 11:31 pm
First name: Doug
Last Name: Balzer
City: Calgary
State: Alberta
I have found some interesting paper at Michael's craft stores; lots of colour, texture, patina, etc.
Doug
PostPosted: Sun Jan 04, 2015 11:50 pm
First name: Rob
Last Name: McDougall
City: Cochrane
State: Alberta
Southworth 100% cotton 24lb. resume paper.
Oh yes, and I hit it with with shellac before cutting out the label and installing...
PostPosted: Mon Jan 05, 2015 3:31 am
As above, 100% cotton. I then dip the printed label in Seedlac. Gives it a slightly mottled appearance, immediate age to it.
PostPosted: Mon Jan 05, 2015 7:35 am
Resumé paper as well, thicker is better IMO and the highest linen content that I can find.
If printing your labels on an i*k j*t printer a very light mist coat of lacquer or two helps fix the colors hopefully for a very long time...
A light mist of 3M spray adhesive and some careful positioning even though our arms are in the way... and I'm good to go.
PostPosted: Mon Jan 05, 2015 8:57 am
High quality resume paper too. I like the parchment color/pattern. I put mine on with Titebond and then coat them with Titebond. I've good luck with that method for putting paper on wood for about 20 years.
PostPosted: Mon Jan 05, 2015 7:21 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
I never really used a label since I can't seem to find anything better than regular office paper, at least ones I could print on. I figure I could make a run of professional looking labels if I had volume.
Typhoon Guitars
PostPosted: Tue Jan 06, 2015 12:39 pm
First name: Tim
Last Name: Lynch
City: Santa Cruz
Zip/Postal Code: 95060
Southwell 24lb Parchment paper from Office Max.
These users thanked the author Tim L for the post: jack (Tue Jan 06, 2015 4:34 pm)
PostPosted: Tue Jan 06, 2015 4:22 pm
I'm not sure what kind I use since I bought a bunch of it years ago but as mentioned it was very high quality thick paper. I print of a whole bunch with blanks in to fill by hand like the date and signature. I like to burn the edges of the paper with a lighter for an interesting I guess weathered look IDK. I don't remember where I got the idea for that but I like it.
PostPosted: Wed Jan 07, 2015 12:33 am
Last Name: Beaver
City: Lake Forest
I just use a nice grade of 25 lb bond paper. And I use goldenrod (that's a color, not a thing) It is pleasing to my eye.
Joe Beaver
Maker of Sawdust
PostPosted: Wed Jan 07, 2015 5:30 pm
Acid free paper is reputed to be longer lasting. I found some at the art store.
PostPosted: Thu Jan 08, 2015 12:32 am
Some good suggestion here, thanks. I'll have to check out an office supply store.
I have also been wondering about the stock they print wine labels on, some of that seems pretty nice. Anyone have an opinion on that?
Thanks!
PostPosted: Thu Jan 08, 2015 2:08 am
Last Name: Beaver
City: Lake Forest
Yes in deed. I do like my wine with proper labels. To my palate it just taste better.
Joe Beaver
Maker of Sawdust
PostPosted: Thu Jan 08, 2015 2:17 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
How do you feed heavy paper through a printer, and how do you make sure the print is durable as well (inkjets are terrible, the ink washes out and fades over time)?
Typhoon Guitars
PostPosted: Thu Jan 08, 2015 4:36 am
I feed mine down through the back, one at a time.
Even used card without problems. Come to think of it, it's common to print photographs for example.
Laser Printer if you're worried about it, I actually did some as a trial on a home monochrome laser.
PostPosted: Thu Jan 08, 2015 5:18 am
Inkjets and their ink have improved over the years. You can obtain Archival/Pigment ink that should last a mighty long time. Put a finish with a little UV protection over it and it should last even longer, which is partly why I shellac over my labels. You can test the ink by placing a test label on a window that receives a lot of sunlight.
PostPosted: Thu Jan 08, 2015 10:52 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
If you reload ink cartridges, then yes you can get various inks to do various things, but if you stick with factory inks like many people, then no way. Also I got sick of inkjets a while ago... the thing clogs if you stop printing something for 2 hours! And once it clogs, you waste 2 gallons of ink trying to clean the thing so that it works, if at all. Also printer manufacturers hate people reloading ink cartridges so they put in features that would dissuade people from doing it, from chipped cartridges to secret ink counters that cause the printer to stop working as soon as it thinks it has printed enough pages (or dumped enough ink from cleaning)
Also archival ink, at least the ones Epson uses, will not clean out once it clogs.
Typhoon Guitars
PostPosted: Thu Jan 08, 2015 11:17 am
Not been my experience. My ink-jet labels from 2003 are just fine. They were done on an old Desk-Jet. I have found that not all ink-jet printers are created equal. As I said earlier, I put them on with TiteBond and also brush TiteBond over the top of them. Don't know what they'll look like in another 20 years. Basically a kind of a simple decoupage.
PostPosted: Thu Jan 08, 2015 11:20 am
First name: Wayne
Last Name: Brown
City: Huntersville
Zip/Postal Code: 28078
Resume paper! After signing and dating, I spray/seal with a product called "Fixatif" before gluing it into my instrument. Fixatif can be found in the art dept of your local craft store.
Users browsing this forum: William Bustard and 22 guests
