It is currently Sat Aug 16, 2025 10:36 pm
PostPosted: Sun Oct 26, 2014 2:18 pm
First name: Craig
Last Name: Gordon
Zip/Postal Code: 14216
I just picked up a nice Delta 28-200 with a 1 1/2 hp motor that I would like to set up for resawing.
Delta no longer sells the riser block kit for this saw and those available from other parties are ridiculously expensive.
Does anyone know of another manufacturer's riser kit that fits without modification?
Grizzly? Jet? Any others?
Thanks, Craig
PostPosted: Sun Oct 26, 2014 3:21 pm
You can make one from a block of hardwood, a long bolt and an inexpensive steel rod. I used a bandsaw with a wooden riser block and it worked perfectly fine.
