It is currently Mon Aug 18, 2025 12:56 am
 Post subject: Cursed
PostPosted: Sun Jul 20, 2014 12:10 am
First name: Joey
Last Name: Holliday
City: Palmetto
Zip/Postal Code: 34221
Everything was going so well...Image
Looking at this I realized.... Oops!
 Post subject: Re: Cursed
PostPosted: Sun Jul 20, 2014 12:13 am
First name: Joey
Last Name: Holliday
City: Palmetto
The good news- Image
This is about to become a very "modern" looking mistake....I mean guitar :P
PostPosted: Sun Jul 20, 2014 12:18 am
Last Name: Russell
State: Michigan USA
Ummmm....
So you decided to make it a double cutaway... gaah
Should look very cool when it's done.
As they say there are no mistakes, just opportunities.
Bob
PostPosted: Sun Jul 20, 2014 12:55 am
Ha ha ha!
I mean, ummm...oops!
Ok then, matched pair, lefty righty. At least you're not so far along in the build, and nothing is actually wrecked. Just means you're well under way for your first lefty....
PostPosted: Sun Jul 20, 2014 1:17 am
First name: Joey
Last Name: Holliday
City: Palmetto
Well I really need a guitar for myself, so the lefty cutaway is becoming an inlay
First name: Joey
Last Name: Holliday
City: Palmetto
PostPosted: Sun Jul 20, 2014 1:42 am
First name: Heath
Last Name: Blair
City: Visalia
Bummer, dude. If it were me, I'd probably remove the braces, flip the top over and redo the rosette.
sweat the small stuff.
PostPosted: Sun Jul 20, 2014 1:56 am
First name: Joey
Last Name: Holliday
City: Palmetto
I thought about that too, but I really like the rosette and its really just a cosmetic flaw that I am trying to come up with a creative way to hide. Plus there are numerous flaws on the inside face.
The reinforcement is already glued. I just need to come up with a creative inlay to hide it.
PostPosted: Sun Jul 20, 2014 2:21 am
First name: Peter
Last Name: Fenske
City: Leeds
State: Yorkshire
Country: Uk
A nice curly vine draped around it? :D
I'm paranoid about doing that one day! I always check about a million times before actually starting to cut
Sent from my GT-S5830 using Tapatalk 2
Pablo Picasso
PostPosted: Sun Jul 20, 2014 2:45 am
First name: Joey
Last Name: Holliday
City: Palmetto
PostPosted: Sun Jul 20, 2014 5:27 am
First name: sam
Last Name: guidry
State: michigan
Country: us
I did that once but it was two guitars I was working on foe a guitar show deadline. Now I don't cut out the cut away until the guitar is boxed
PostPosted: Sun Jul 20, 2014 8:39 am
First name: wes
Last Name: Lewis
City: Garland
State: Tx.
Zip/Postal Code: 75044
I had a top that , lets say just wasn't right [headinwall] , that I used to practice shooting a burst on.. idunno beehive
MK5acoustics.com
PostPosted: Sun Jul 20, 2014 9:05 am
Last Name: Parchem
City: Seattle
State: Wa
Zip/Postal Code: 98177
That is a real bummer. I would consider cutting out the rosette removing most of the top from the backside and routing out the rosette on the purfling lines. You could install it in a new top with a new set of purflings.
Given that the shape you need to hide is so close to the cutaway shape on the other side you may need some symmetry with the cutaway side to not call attention to it. An idea you might consider is to use a purfling scheme for the entire top and follow the mistaken cut with the purfling leaving the the area above the mistaken cut without a purfling, binding only.
PostPosted: Sun Jul 20, 2014 11:08 am
Last Name: Sollod
If it's any consolation... That's a beautiful rosette...
www.swiftcreekguitars.com
PostPosted: Sun Jul 20, 2014 11:38 am
First name: EddieLee
Last Name: Brown
gaah I can see how that can happen. So easy to get things turned around.
_____________
EddieLee
PostPosted: Sun Jul 20, 2014 6:16 pm
Last Name: Kincheloe
Not necessarily. The whole shoulder area could be routed half way through and overlaid with more spruce or some other species, to change the shape of the "transition line". Maybe use a wood pickguard, and use the same species for the shoulder area so it creates some diagonal symmetry across the soundhole? Work in some similar curves or pointy shapes to the outline of the pickguard and the transition line between spruce and shoulder inlay, so it ties the design together.
PostPosted: Sun Jul 20, 2014 6:23 pm
First name: Joey
Last Name: Holliday
City: Palmetto
I was thinking about making a larger rosette with opposite (macassar border/Maple inside)
PostPosted: Sun Jul 20, 2014 6:55 pm
First name: Lonnie
Last Name: Barber
City: Manchester
State: Tennessee
Zip/Postal Code: 37355
Well I can fully understand you feelings. I've just spent some time making a nice bridge. I screwed it up right at the end. Well it's just a bridge not a whole top. I'm going to re-make it. Good luck with it. I know you feel terrible as I would.
PostPosted: Sun Jul 20, 2014 8:42 pm
First name: Joey
Last Name: Holliday
City: Palmetto
I ended up routing it out. That top was a little thin and floppy for a baritone anyway. It's going into some much stiffer sitka now. Just a waste of money as I won't lose much time going this route. I also have a BRW bridge plate and the X-Brace is laminated with BRW as well for aroma, as well as stiffness. Might as well do it right cuz that stuff ain't cheap!
PostPosted: Sun Jul 20, 2014 10:46 pm
First name: Lonnie
Last Name: Barber
City: Manchester
State: Tennessee
Good thinking fingerstyle1978
PostPosted: Tue Jul 22, 2014 9:56 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
I made that mistake before, so now I profile the boards as though it has no cutaway until the box is closed.
Typhoon Guitars
PostPosted: Thu Jul 24, 2014 2:08 pm
Last Name: Minch
City: Chestertown
Zip/Postal Code: 21620
I was gong to suggest duplicating the purfling and binding of the cutaway along that symmetrical line. Too late -eh, probably the right thing to do.
Ed
Users browsing this forum: TimAllen and 34 guests
