It is currently Tue Aug 19, 2025 1:46 pm
Post new topic Reply to topic  [ 29 posts ]  Go to page Previous  1, 2
PostPosted: Sun May 25, 2014 10:50 pm
Charlie, Mike, got a result.
Might be of some use to you.
Saved this from a post a couple of years ago, http://www.luthiersforum.com/forum/viewtopic.php?f=10101&t=33692&p=443908&hilit=Brook+use+the+Enduro+Var#p443908
Quote:
Brook use the Enduro Var. It is more like an oil urethane and can be recoated in 2 hours. This product will give you excellent depth and is extremely durable. Water base products do not have burn in like the lac but they attach on. So you are better letting it dry out for a good two hours between coats. We recommend letting it dry dry good for 2 weeks
I also have a couple guys that do this for a living and here is a suggested system they used for a project they did with our Enduro Var...
yep, he did the back to back thing, to create a uniform 1 coat for the final rub
Subject: FW: Schedule for EV
Try this schedule. It takes 3 coats 1 day and 3 coats the next day.
________________________________________
Sent: Tuesday, April 13, 2010 4:47 PM
To: 'Tom Monahan'
Subject: Schedule for EV
1. Prep wood to 220
2. Spray full wet coat of EV gloss - wait 2 hours
3. Level sand 320 - spray 2 nd full wet coat wait 2 hours - light sand 320
4. Full wet coat --- wait over night
5. Level sand with 320 - wipe with water and 5% DNA
6. Wet coat 2-3 mils dry 1 hr and repeat twice for a total of 3 coats only 1 hr in -between
Let dry 1 week
Level sand dry with P800 Mirka.
Sand dry with P1200 Mirka
Sand with 2000 grit Abralon dry
(Note - do NOT use lubricants of any type to level sand)
Then - 3M Finesse-it Finishing Material on foam buffing pad to gloss.
Have a great day!
Sheryl Monahan
General Finishes
1-800-783-6050 begin_of_the_skype_highlighting 1-800-783-6050 end_of_the_skype_highlighting
2462 Corporate Circle
East Troy, WI. 53120
http://www.generalfinishes.com
PostPosted: Sun May 25, 2014 11:26 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
I just want to be 100% sure. You are all talking about EndurVar water based urathane, gloss. Thanks for the schedule above! I am assuming sanding sealers are not needed with epoxy.
I wonder why they don't reccomend sanding lubricants?
PostPosted: Mon May 26, 2014 12:19 am
No problem Mike, that's the one.
Correct with an epoxy fill not needing sanding sealer, although I like to use shellac as a precaution to help with adhesion of a finish over epoxy.
I am assuming they don't recommend lubrication because the finish surface could be compromised in some way.
I found sanding dry went really easy with quality wet 'n' dry and it does not clog up nearly quickly as with some finishes.
I sanded successive grits diagonally (makes it easy to see when the last grade's scratches are removed) until the final one, when I sanded with the grain.
PostPosted: Mon May 26, 2014 10:59 am
Thanks for the process / schedule info, Colin! [:Y:]
cron
