It is currently Tue Aug 19, 2025 8:48 pm
PostPosted: Sun Mar 09, 2014 11:11 am
Online
City: Tyler
Hello , I've built 20 guitars, 19 of which have had bound fretboards, mostly to hide the gap on the fret ends. My new build, I have decided, is going to be unbound. I use ebony boards. What is the best method you guys have found to fill that little spaces? Black ca? Ebony dust mixed with glue?
Thanks in advance
Glen
PostPosted: Sun Mar 09, 2014 11:33 am
Last Name: Collins
City: Argyle
State: New York
Zip/Postal Code: 12809
Shellac stick
Black CA
Black pore filler.
Epoxy.
Protect the top when using these.
Unless you neck is built off of the guitar.
Mike Collins
PostPosted: Sun Mar 09, 2014 12:19 pm
Last Name: Russell
State: Michigan USA
I usually just dab a little Titebond in them with a toothpick and lightly sand the neck to get some dust in. I then poke that in with the same toothpick and do it again to make sure it is deep enough that it won't pop out later on. That is the only way I have ever done it and have never had a problem.
Cheers,
Bob
PostPosted: Sun Mar 09, 2014 1:09 pm
Last Name: Beaver
City: Lake Forest
Black CA but if the gap is small clear CA seems to work fine
Joe Beaver
Maker of Sawdust
PostPosted: Sun Mar 09, 2014 1:26 pm
First name: Patrick
Last Name: Hanna
State: Missouri
Robert O'Brien demonstrates the glue and sanding dust method in a nice, brief video. As a matter of fact, on his youtube channel, he demonstrates practically every process of guitar building and tool use. You should bookmark his channel.
In this video, he's using CA glue, but you could use yellow glue, as previously mentioned:
http://www.youtube.com/watch?v=p7ANHge-shE
PostPosted: Sun Mar 09, 2014 1:37 pm
Last Name: Giltzow
City: Boise
State: Idaho
Zip/Postal Code: 83709
Ebony dust and CA
guitarsbygiltzow.com
PostPosted: Sun Mar 09, 2014 2:59 pm
First name: George
City: Seattle
I've had success with the method Robbie O'Brien demonstrates, using both CA and LMI white glues. I imagine Titebond would work just as well. If using thin CA, I have to be careful that it doesn't stream down beneath the tang and leak out under the opposite end of the fret. I find it's better to do two or three light passes than one heavy application.
George :-)
PostPosted: Sun Mar 09, 2014 3:15 pm
http://youtu.be/THnNsLXJlzo
enjoy! :D
PostPosted: Sun Mar 09, 2014 4:40 pm
Hesh wrote:
Yuk!
PostPosted: Sun Mar 09, 2014 4:58 pm
That must be the crap that's boiling out when I heat them up with the soldering iron. It smells, too. Eww!!
Old growth, shmold growth!
PostPosted: Sun Mar 09, 2014 6:00 pm
Last Name: Beaver
City: Lake Forest
I was wondering what happened to my toothpaste !!!
Joe Beaver
Maker of Sawdust
PostPosted: Sun Mar 09, 2014 6:22 pm
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
Hesh wrote:
Sometimes you shouldn't open the tupperware in the back of the fridge, as well. wow7-eyes Thanks for the link Hesh, but my quesedias aren't sitting so well all of a sudden. [xx(]
Alex
PostPosted: Sun Mar 09, 2014 8:57 pm
Medium CA, nothing else. it will take on the black of its surroundings, with no need for ebony dust. dont use accelerator, or you risk it turning white if you overdo it
PostPosted: Thu Mar 13, 2014 1:06 am
If not wanting a bound look, tend to just save the edges of the ebony board when trimming for width and bind with this after fret slots are cut... Completely disappears when board is profiled and smoothed and hides fret ends in bound way.
I know some are now laser cutting fret slots so they have no ends... Not for me that modern malarkey ;-)
Users browsing this forum: dgimcmillan and 42 guests
