It is currently Wed Aug 20, 2025 7:32 am
 Post subject: Fretboard woods
PostPosted: Fri Mar 07, 2014 6:25 am
First name: Jon
Last Name: Shurtleff
City: Huizen
Zip/Postal Code: 1273aw
Country: Nederland
It seems that glued-on fretboards are made primarily from either rosewood or ebony. I'm wondering what the pros and cons of these are or is it just cosmetic. Are there are other suitable woods that can be used. Are there also different kinds of rosewood or ebony that have significantly different characteristics.
Are there books that discuss these issues and other questions I've asked so I don't keep bugging you guys with questions that are documented somewhere?
Jon.
 Post subject: Re: Fretboard woods
PostPosted: Fri Mar 07, 2014 7:05 am
A fretboard has to withstand the wear caused by the strings. That's about it. It has to be hard. Virtually everything else is secondary.
Dark coloured woods tend to be used because it doesn't show the dirt and grime readily.
Traditionally Gut strung instruments were often of a fairly light coloured wood. Often Pear wood or of Boxwood. Then the Baroque came in and fancy exotic species were in demand. It's kind of been that way ever since, so it's Ebony or a Rosewood. It was not for tonal or wood stability reasons. They were seen as exotic and therefore expensive.
Throughout the 19th and 20 th century stained Beech was used on countless thousands of Guitars at the cheaper end of the market. But basically any hard, hardwood is suitable. A couple of 'odd' types that I've used have been Laburnum and Oak.
PostPosted: Fri Mar 07, 2014 8:53 am
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
There are lots of Maple fretborads out there. They of course need a finish to keep them looking their best but quite common on electric guitars.
Brian
PostPosted: Fri Mar 07, 2014 12:40 pm
First name: Rodger
Last Name: Knox
City: Baltimore
Zip/Postal Code: 21234
It's also important to hold frets, but there's the option of glue if it doesn't. I've used cocobola, bloodwood, mesquite, maple, and ebony. Weight can be a concern, but since ebony is about as dense as anything, it's not usually a factor.
PostPosted: Fri Mar 07, 2014 12:51 pm
The hardest 'traditional' wood to find a good substitute for is ebony for fretboards. Nothing else is as hard, fine grained, and dark. It's not too difficult to get two out of three, though.
I've used persimmon, which is the North American member of the Ebony family, pretty frequently. It's not dark, and has to be stained, but otherwise it works well. One of the wood suppliers is working on a method of dying it black all the way through. I've used one of those, and it worked very well. He's having some quality control issues: some pieces don't dye as well, or the color rubs off on some people's hands, but hopefully he'll get that nailed fairly soon.
PostPosted: Fri Mar 07, 2014 12:53 pm
First name: Stuart
Last Name: Gort
Many woods are suitable. Google "Janka" to get a reference chart for various hardwoods. Purple Heart is about the softest wood I'd want to use for a fretboard...and many might say it's too soft...I wouldn't argue.
I'd look for woods that are harder than Purple Heart, not too splintery, dense, relatively pore free, and polish-able. Darker woods are easier to manage. Lighter woods may need a finish...which I personally don't like doing...or playing.
In addition to Ebony and Rosewood I've used Cocobolo, Maple, Bloodwood, Argentinian Ebony (beautiful light tan but won't absorb grime).
StuMusic
PostPosted: Fri Mar 07, 2014 1:04 pm
First name: D
Last Name: S
I like Mesquite. Hard and pretty.
wah
Wah-wah-wah-wah
Wah
PostPosted: Fri Mar 07, 2014 1:18 pm
First name: Zeke
Last Name: McKee
City: Goodlettsville
Zip/Postal Code: 37070
My personal favorite fretboard is African black wood. It's hard as a rock which can add some difficulty in shaping but it doesn't wear very easily. It's dark colored but at the same time has some grain to it which makes it look fantastic. Plus it polishes out beautifully
PostPosted: Fri Mar 07, 2014 6:36 pm
First name: Martin
Last Name: Taylor
City: Central Coast
I mainly use Australian woods. Mulga wood is excellent, Gidgee is even better. I have also used Jarrah and River Red Gum. All of them are hard, workable and finish beautifully.
Martin Taylor
http://martintaylorguitars.com.au
PostPosted: Fri Mar 07, 2014 6:43 pm
Rodger, that neck is fabulous.
These users thanked the author wbergman for the post: Rodger Knox (Mon Mar 10, 2014 2:41 pm)
PostPosted: Sat Mar 08, 2014 1:10 pm
Last Name: Russell
State: Michigan USA
Just curious if anyone has tried to use Corian?
It seems to me that would be a perfect substitute for wood. It is hard and frets can be glued in with CA glue or Acetone. And it comes in almost any color you want.
It may be a bit heavy but would probably be comparable to Ebony.
Bob
PostPosted: Sat Mar 08, 2014 10:15 pm
martin used a product called Mycarta that is very much like corian , you will find that if it is non wood product ,many people consider it a lower end guitar. Martin has since switched from Mycarta to richlite a more guitar friendly product.
PostPosted: Sat Mar 08, 2014 11:18 pm
Richlite is very similar to micarta. It is phenolic impregnated paper based product. It can be sawn and routed like wood but that creates a fine dust that seems to go everywhere - about like ebony, but maybe a little worse. It comes in different thicknesses and colors. I have some scraps that are black, blue and tan.
PostPosted: Tue Mar 11, 2014 8:08 am
First name: Jon
City: Huizen
Country: Nederland
Thanks everyone for the good information.
Sent from my iPad using Tapatalk HD
PostPosted: Tue Mar 11, 2014 2:36 pm
First name: Randolph
Last Name: Morris
Just curious. Anyone tried to use desert ironwood? Too heavy?
PostPosted: Tue Mar 11, 2014 9:47 pm
First name: Kent
Last Name: Wilkinson
City: New Carlisle
State: Ohio
Zip/Postal Code: 45344
Does maple have to be finished on a fret board? Or can they be left unfinished?
PostPosted: Wed Mar 12, 2014 3:19 am
I think getting dirty would be the problem. Has anyone ever used something like true oil on maple boards?
PostPosted: Wed Mar 12, 2014 11:08 am
Last Name: Arnold
City: Newport
Zip/Postal Code: 37821
I have considered it, but it is a bit heavy, and clean pieces are expensive and hard to find. I also suspect it would be hard to glue because it has a waxy feel. It is a protected species, so the souce is mainly dead stumps with lots of voids and cracks and the yield is poor. A similar wood that is not quite as dense is Texas ebony (Ebenopsis ebano). It is also rare to find clean fingerboard-size pieces, but it does fit the three requirements that Alan outlined. It grows in the southern tip of Texas, and into Mexico.
Both woods are remarkably stable, considering their high density.
Here is an unusually large, clear piece of quartered Texas ebony. It is about 4-5" wide (3-4" without the sapwood) and about 40" long.
PostPosted: Wed Mar 12, 2014 11:18 am
First name: Rodger
Last Name: Knox
City: Baltimore
I've used shellac and TruOil on maple boards, I believe the one I posted above has a TruOil filish on the maple, bloodwood, and ebony. I can't say how durable it is, my guitars don't get much playing time. I've got several and don't play that much anymore.
PostPosted: Wed Mar 12, 2014 12:03 pm
First name: D
Last Name: S
I've used wipe-on poly on Pecan fret boards. Seems to be fine. I sprayed one with lacquer and it was a mess cleaning the frets.
wah
Wah-wah-wah-wah
Wah
PostPosted: Wed Mar 12, 2014 2:33 pm
Last Name: Arnold
City: Newport
Quote:
.....it was a mess cleaning the frets.
Fender would just sand the tops of the frets, using a block.
PostPosted: Wed Mar 12, 2014 2:40 pm
Last Name: Kincheloe
Nice hunk of Texas ebony, John! It is indeed hard to come by in guitar size, but not so much in smaller pieces. I used it on this harp ukulele, and like it.
My piece had a waxy feel, much like desert ironwood. Seems to glue just fine though (hide glue). But it's really difficult to plane. Has to be freshly razor sharpened or the blade slides helplessly over the surface.
And here's the one good desert ironwood guitar FB blank I've run across, from Arizona Ironwood:
It's a little thin, but I always bind fingerboards anyway, so I can glue a layer of something else to the underside if necessary. Grain is a bit more wavy than I'd normally use for a fingerboard, but ironwood seems to be pretty similar to mesquite in terms of humidity movement (i.e. practically nothing), so I don't think it will be a problem even in extreme humidity situations.
PostPosted: Wed Mar 12, 2014 6:19 pm
First name: Greg
Last Name: B
City: Los Angeles
FWIW, I used rock maple for a fingerboard once, and it finished with super ultra thin superglue, as much as I could get to soak in. After a year of playing everyday, was still clean. Perhaps I should say: the finger grime was not in the wood, and it was easily cleanable with rag.
These users thanked the author Greg B for the post: Pmaj7 (Wed Mar 12, 2014 6:20 pm)
