It is currently Tue Aug 19, 2025 5:02 pm
PostPosted: Fri Feb 28, 2014 7:45 pm
Last Name: Ensor
City: Springfield
State: Missouri
I use blue spring steel with my bending machine and they are rusting/curroding from the moist parchment I use. Is there any way to avoid this?
http://elevatelutherie.com
http://ensorguitars.com
PostPosted: Fri Feb 28, 2014 8:49 pm
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
Maybe wrap them in aluminum foil?
Alex
PostPosted: Fri Feb 28, 2014 9:37 pm
First name: Danny
Last Name: Vincent
Use stainless. It conforms a little to the bend and will stay that way somewhat, but it's not an issue. John Hall has them.
PostPosted: Fri Feb 28, 2014 9:54 pm
stainless
PostPosted: Fri Feb 28, 2014 10:09 pm
Last Name: Imbler
State: KS
Zip/Postal Code: 67204
Yes, that is what I use. Well worth the money. They take very little set, and no corrosion,
PostPosted: Sat Mar 01, 2014 12:39 am
Wrap the moisten wood in aluminum foil.
PostPosted: Sat Mar 01, 2014 1:01 am
You could try high temperature spray paint
PostPosted: Sat Mar 01, 2014 1:36 am
First name: Heath
Last Name: Blair
City: Visalia
Layer of aluminum foil for sure.
sweat the small stuff.
PostPosted: Sat Mar 01, 2014 2:18 am
City: chicagoland
State: illinois
and this: corrosion. corrode. corroded.
PostPosted: Sat Mar 01, 2014 3:00 am
Last Name: Beaver
City: Lake Forest
I usually put moist paper next to the wood then a layer of tin foil. no stains on the wood or slates.... all is good
Joe Beaver
Maker of Sawdust
PostPosted: Sat Mar 01, 2014 4:01 am
It;s not complicated.
Slat, foil, damp paper, side, damp paper, foil, slat, blanket, slat.
PostPosted: Sat Mar 01, 2014 8:18 am
I wrap the slats in foil, like gift wrap, and tape it on the backside. If I'm careful I can get 4 or 5 bends before it tears and needs ro be replaced.
Kent
PostPosted: Sat Mar 01, 2014 8:35 am
First name: Martin
Last Name: Kelly
City: Tampa
State: FL
Zip/Postal Code: 33634
Agree, I do what Colin and Joe recommend. No problems for me.
PostPosted: Sat Mar 01, 2014 12:00 pm
First name: Tim
Last Name: Lynch
City: Santa Cruz
Zip/Postal Code: 95060
I used to think the little bit of rust I had on my spring steel slats was bad until I saw the ones other people were using. If it bothers you you could wipe it off with as scotchbrite pad before using it, but with the combination of heat and water is just going to bring it back.
I also use foil between the slat and wood.
PostPosted: Sat Mar 01, 2014 3:14 pm
I've wrapped my blue tempered shim stock in foil for years. I can't remember the last time I re-wrapped it. Works fine. I personally don't like slats that take a set after bending but I know stainless works great for a lot of folks.
PostPosted: Sat Mar 01, 2014 4:35 pm
First name: Alex
Last Name: Kleon
City: Whitby
:idea: Foil duct tape :?:
Alex
PostPosted: Sat Mar 01, 2014 4:56 pm
Last Name: Beaver
City: Lake Forest
Alex's foil duct tape sounds like it might be a stroke of genius. I'll have to try it.
What's that rule? One years time and I can say it was my idea?
Joe Beaver
Maker of Sawdust
PostPosted: Sat Mar 01, 2014 5:56 pm
First name: Alex
Last Name: Kleon
City: Whitby
Sounds about right, Joe! Now, if you want to send me a nice bridge blank or something, you can say I stole the idea from you yesterday! laughing6-hehe
Alex
PostPosted: Sat Mar 01, 2014 7:24 pm
First name: Rob
Last Name: McDougall
City: Cochrane
State: Alberta
I wonder how the PSA on the foil tape would hold up under bending temps?
PostPosted: Sat Mar 01, 2014 7:47 pm
First name: Alex
Last Name: Kleon
City: Whitby
You can get high temp foil tape that is used for fireplace flues. I think the regular stuff is good up to about 300F.
Alex
PostPosted: Sun Mar 02, 2014 3:01 pm
Last Name: Shanklin
City: Windsor
State: ON
Stainless steel "Shim in a Can"
Bob
PostPosted: Tue Mar 04, 2014 12:51 pm
First name: Chuck
Last Name: Gilbert
City: Magnolia
Zip/Postal Code: 77355
Bostik Top Coat works great.
PostPosted: Tue Mar 04, 2014 5:54 pm
First name: Tom
Last Name: West
State: Nova Scotia
I use 6" wide aluminum flashing, not sure of thickness. Not near the shop. Works a treat for me.
Tom
PostPosted: Sun Mar 09, 2014 7:23 pm
Last Name: Russell
State: Michigan USA
You might want to look into Dupont Metal Prep.
http://pc.dupont.com/dpc/en/US/html/visitor/common/pdfs/b/product/dr/ChromaSystem/H-19298_5717S.pdf
Back when I worked in the body shop I would use this stuff on bare metal. It is a mild acid that mixes with water and you keep the metal wet for a specific period of time. Then rise it with water. It will inhibit rust and actually stop it. When it first came out we tested it by using a metal rod, coated one half with metal prep and did nothing on the other half. Hammered it in the ground and left it over winter. We also stripped an old fender and did the same thing. We watched have the fender rust while the other half did nothing. The next spring we pulled the rod out of the ground and the part that was metal prepped had no rust. I started using it on all bare metal from then on.
The only drawback is it smells like funky hot dogs... If it is the same formula I used back in the 70's then it works better than anything I have ever tired.
Maybe you don't want to mess with acid but it is just an idea I know works.
Cheers,
303
