It is currently Sun Aug 17, 2025 11:51 pm
Post new topic Reply to topic  [ 61 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Fri Jan 24, 2014 8:23 pm
First name: duh
Last Name: Padma
Filippo Morelli wrote:
You can't cleat that. Whomever suggested that should back.up with experience how a cleat will hold it.
Filippo
Oh Flipo...my role model...wish me had your tack and communication skills. But hey...me still gets the point across. laughing6-hehe
PostPosted: Fri Jan 24, 2014 8:43 pm
First name: Ringo
I've heard it said 'there are two types of woodworkers: those who understand how wood reacts to changes in humidity and those who soon will'
These users thanked the author James Ringelspaugh for the post: Alex Kleon (Fri Jan 24, 2014 9:10 pm)
PostPosted: Fri Jan 24, 2014 10:05 pm
First name: Aaron
Last Name: Thompson
City: Atlanta
State: Ga
Zip/Postal Code: 30308
Right. Hey... If it weren't for mistakes, what would we have to learn from?
"I'm not going to say that perfection has never been achieved. However, if it has, it probably went unnoticed due to it's lack of character."
PostPosted: Fri Jan 24, 2014 10:53 pm
Last Name: Russell
State: Michigan USA
Reading about other peoples mistakes on OLF... Eat Drink
These users thanked the author RusRob for the post: Tony_in_NYC (Sat Jan 25, 2014 10:52 am)
PostPosted: Fri Jan 24, 2014 11:04 pm
First name: duh
Last Name: Padma
Amen!
PostPosted: Fri Jan 24, 2014 11:51 pm
First name: Phil
Last Name: Hartline
City: Warrior
State: Alabama
My philosophy used to be that if I paid attention, I could learn from and avoid the mistakes of others. Turns out, I just made new and different mistakes!
Phil
http://www.oleninstruments.com
"Those who tilt at windmills are only considered insane by those who can't see the dragon."
PostPosted: Sat Jan 25, 2014 1:24 am
Last Name: Russell
State: Michigan USA
Isn't that how life is? I think that is where the saying "Live and Learn" came from.
It reminds me of a quote I heard once:
"Live and learn from others mistakes, you cant possibly live long enough to make them all yourself..."
Cheers,
Bob
PostPosted: Sat Jan 25, 2014 9:57 am
First name: Aaron
Last Name: Thompson
City: Atlanta
State: Ga
So... A light bulb is twitching a little bit. Now that I think about it, I ended up having to fix a couple side cracks in the same place (since they are booked matched). The middle wedge was a consecutive "slice" from the same slab of blood wood. I think this particular part of the board just had a plan to crack. I never can see these things until they happen. Are there any tests to find things like this before resawing, bending, etc.?
PostPosted: Sat Jan 25, 2014 10:40 am
Last Name: Russell
State: Michigan USA
I don't know first hand but I do a lot of reading about building and techniques and from what I understand you should stress test wood before using it. That ranges from just bending it with your hands to putting weights on a piece of the wood that is supported between 2 risers.
I am sure someone here knows what I am talking about so it would be better to get input from someone that does it.
Yea, If you had cracks that you already repaired and it was from the same piece of wood that probably is part of the reason you had such a large failure of the back. But the humidity issue is what caused it to pop.
Bob
PostPosted: Sat Jan 25, 2014 10:53 am
First name: Tony
Last Name: C
City: Brooklyn
There is nothing wrong with being original and creative in your work. Even if it is with the mistakes. laughing6-hehe
http://www.CostaGuitars.com
PMoMC
PostPosted: Sat Jan 25, 2014 12:56 pm
First name: Big
Last Name: Jim
Thats My Motto ! There not Mistakes they are Design Experiments !
Clean out that crack a little wider and bind it and you have a "Back Soundport " laughing6-hehe laughing6-hehe
PostPosted: Sat Jan 25, 2014 5:04 pm
First name: Phil
Last Name: Hartline
City: Warrior
State: Alabama
Wud, when you make it look intentional, that's when it changes from a "Design Experiment" to a "Design Feature!"
Yeah, plenty of experience there... :roll:
Phil
PostPosted: Sat Jan 25, 2014 6:00 pm
First name: Ringo
Bloodwood is simply brittle like that... like Indian or Gabon ebony, or a lot of Brazilian rosewood for that matter, it'll split along the grain if you give it any excuse to. Maple, rosewood, mahogany, etc are tougher to split and may have not cracked like that, but they would've been under the same stresses when the humidity dropped so low. If you're going to use brittle woods you simply have to build under controlled humidity and not expect the guitar to survive really dry conditions. If you need a guitar to survive those conditions, use a tougher wood that is really stable with changes in humidity (or plywood!), but know that every wood has its limits.
PostPosted: Sat Jan 25, 2014 6:23 pm
First name: duh
Last Name: Padma
Ok the other thing not being mentioned about building with Blood wood...and very very few do this is to lamb it up into ply. End of any splitting problem.
PostPosted: Sat Jan 25, 2014 8:29 pm
First name: Aaron
Last Name: Thompson
City: Atlanta
State: Ga
WudWerkr wrote:
Tony_in_NYC wrote:
That reminds me. What exactly is the purpose of a sound port?
PostPosted: Sat Jan 25, 2014 8:31 pm
First name: Aaron
Last Name: Thompson
City: Atlanta
State: Ga
Can you explain this process? I've never done this but I hear it's a useful technique. How thick are the plies? I'm assuming you laminate before you bend instead of after?
PostPosted: Sat Jan 25, 2014 9:10 pm
City: chicagoland
State: illinois
Filippo
just a reminder- the title of this thread asks, should the owner "smash" it? as an amature who has seen a few photos of cleats and not much else, anywhere, practicing this technique SEEMED like ONE POSSIBLE use of the cracked instrument, rather than flattening it outright. perhaps it would be more constructive to the forum to say something like, "Nyazzip, cleating a crack like this would be a lost cause because of A), B), and C)", rather than the condescending ego tripping and self congratulation.
you have time to type "no, terrible idea, go home", why don't you type a sentence explaining to me, Alex and Fillipo, why YOU THINK it cannot/shouldn't be cleated. in hindsight i can see that the back must be detached from the braces; is this why? is this one rerason why, or the entire reason? me and a whole lot of other amateurs wouldn't mind knowing.
PostPosted: Sat Jan 25, 2014 9:48 pm
Hi nyazzip,
If you re-humidify the wood and the crack closes up and can be closed with light to moderate pressure, then gluing and cleating the crack can work. If the guitar was built under high humidity conditions any time it experiences low humidity, stresses will occur that will want to make it crack again. If the guitar has been under unusually low humidity and cracked, then repairing it and insuring it never again experiences those conditions may make the repair successful.
If the two sides of the crack have shrunk and distorted and it can no longer be closed up, then a splint may be necessary to fill the void.
On a new instrument it may be better to just replace the cracked panel rather than repair it.
Some repair people can do amazing work making cracks disappear (i'm not one of them) and what some people say can't be done, others do.
PostPosted: Sat Jan 25, 2014 10:27 pm
City: chicagoland
State: illinois
fillipo, my initial, original word-for-word response was: "rather than smashing it, you could probably practice some cleat-laying techniques on it if you can get the gap squeezed shut, no?"
key words/phrases: "you could probably"; "if you can"; and finally the non-assertive: "no"?
...what exactly is wrong with "conjecture and hearsay"? are you a robot? how did you ever learn anything, without inviting discussion and entertaining possibilities?
when someone is considering "smashing" something that most of the world couldn't afford to have, i feel at liberty to make polite suggestions. your arrogance amazes me.
PostPosted: Sat Jan 25, 2014 11:38 pm
City: chicagoland
State: illinois
Quote:
Your politeness is clearly evident in your response, that's for sure!
sorry man, my apologies. i truly respect your work and a good 90% of what you say. cheers.
PostPosted: Sun Jan 26, 2014 8:17 am
First name: Aaron
Last Name: Thompson
City: Atlanta
State: Ga
And the thread is officially hijacked
PostPosted: Sun Jan 26, 2014 12:14 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
I have fixed big cracks before. I removed the back, and removed all braces, closed the crack (after that back has had time to acclimate to 45% RH), reglue the brace, and cleat it if necessary. That was on an old Stella copy (Not Stella, possibly Galliano or something)
If you want to save the wood, you will need to remove the back and acclimate it to a standard RH (45%) and brace it under that condition, after fixing the crack of course. The back will most likely have shrunk and it will NOT grow back (it was said wood that shrunk due to low RH doesn't really grow back) so you will have to trim your braces to fit before gluing that back on. If you are unable to close the crack after removing the back, you will have to fill the void by inlaying the same wood into it.
Typhoon Guitars
 Post subject: Back Crack - Smash it?
PostPosted: Tue Aug 05, 2014 8:47 am
First name: Aaron
Last Name: Thompson
City: Atlanta
State: Ga
So, I finally got around to fixing this thing. I was dreading it (no pun intended), but I had a little time and figured it had been long enough. The back came off without too much trouble.
I found a piece of bloodwood that had really straight grain. Since I currently only have a bandsaw that will barely resaw a 6 inch piece of wood I made a three piece back out of it. Because the joints are so tight, it almost looks like a one piece.
Glued up the same way I did the original.
When I first got the new back on I wondered if it was as good as the old back in sound. When I first tapped the instrument it didn't have a very inspiring sound to it. After attaching the bindings and getting everything sealed up so I didn't have a bunch of tiny little vent holes from the kerfing, it started to sound right.
This whole build has been a great lesson not only in relative humidity while building but also in the role the back plays in the overall sound of the instrument. I got to hear it when it was first put together, with that nasty crack all the way up the back, without a back, with a back and a bunch of little holes from the kerfing, and finally sealed up with bindings and all.
Thanks to everyone for all your help. On to the next one.
PostPosted: Wed Aug 06, 2014 2:31 pm
Last Name: Vallandigham
City: Martinez
Sweet. I love seeing a follow up post to a problem like this. Thanks for updating us. It gives courage to the next guy who has a boo-boo that needs some major re-doing.
Your finished guitar looks great. Cheers!
PostPosted: Wed Aug 06, 2014 3:06 pm
Yeah closing the little binding holes makes all the difference in the world doesn't it. That back looks great. So did the original one but oh well that's the way it goes.
Users browsing this forum: No registered users and 43 guests
