It is currently Wed Aug 20, 2025 1:24 am
Post new topic Reply to topic  [ 54 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Tue Jan 14, 2014 1:15 am
I've come a long way with yours and Gerard's books, but there's still so far to go!
One day I'm going to try falcate, when I have time.
PostPosted: Tue Jan 14, 2014 2:16 am
Right. You've seen the Michael Moore bit where he tries to get anyone to explain derivitaves....
PostPosted: Tue Jan 14, 2014 4:50 am
First name: Trevor
Last Name: Gore
City: Sydney
Ah, the difference between a derivation and a derivative...sometimes it's subtle. But if it's being traded, probably a derivative...
http://www.goreguitars.com.au
PostPosted: Tue Jan 14, 2014 5:29 am
First name: joseph
Last Name: sallis
City: newcastle-upon-tyne
State: tyne and wear
Zip/Postal Code: ne46xe
Country: UK
Can we have some examples, I'm sure it would help medlingfool and me to understand as I suspect the maths is not really that hard.
I'll have a go, correct my mistakes or give me a gold star.
I'm going to make-up the numbers from the top of my head as I don't have any material at hand at it doesn't really matter anyway.
We have 2 pieces of spruce both 10mm x 20mm x 400mm that's a cubic area of 80,000mm
Piece 1 weighs 20 grams
piece 2 weighs 25 grams
If I divide weight into area that gives me (is it mass? density?):
piece 1 80,000mm3/ 20g= 4000 ?
piece 2 80,000mm3/ 25g = 3200?
I do a deflection test, deflection is
piece 1 3mm
piece 2 2mm
To get the magic number I divide deflection into density (? number)
piece 1 4000?/ 3mm =1,333.333
piece 2 3200/ 2mm= 1,600
So piece 2 has a better stiffness to weight ratio.
I wish I hadn't said the maths was easy I'm not sure I got things right.
Please help!
We are all in the gutter but some of us are looking at guitars.
PostPosted: Tue Jan 14, 2014 11:40 am
First name: Danny
Last Name: Vincent
piece 1 3mm
piece 2 2mm
Please help!
So is "E" in there somewhere? What is this E you speak of?
PostPosted: Tue Jan 14, 2014 11:51 am
First name: joseph
Last Name: sallis
Country: UK
Danny, I hope you're not asking me. I'm waiting for Trevor or Todd post.
PostPosted: Tue Jan 14, 2014 7:32 pm
First name: Jim
Last Name: Kirby
Todd Stock wrote:
LOL...through five years at university, I always went to the part of the text where it said something like "...and with the substitution for the partial integral of the appropriate values in Table 3, the temperature rise versus free stream temperature is: t = .189 x velocity..."
Worked right up until my final in Aero 3 was taken 1-on-1 with Dr. John Anderson (was deploying for the summer to somewhere fun)...
"As a warm-up from last semester, just derive the continuity, momentum, and energy equations from first principles...then we've apply them for some of the compressible flow stuff from early this year." Big room with black boards on all four walls...filled them up a couple times.
Keep the derivations in the second edition - always useful to someone.
Heh, that's why I always liked classical physics better than chemistry or biology. You can derive everything from scratch on the fly. You don't have to remember anything! Taxonomy? Phooey!
Jim Kirby
kirby@udel.edu
PostPosted: Wed Jan 15, 2014 2:19 am
First name: Trevor
Last Name: Gore
City: Sydney
Joe,
Density is mass per unit volume (see above). Also best to work in metres, kgs and seconds. (SI units)
So weigh the piece, say 20 grams which is 0.02 kgs
The volume is 0.01 x 0.02 x .4 = 0.00008 m^3
Divide the mass by the volume = 0.02/0.00008 = 250kg/m^3 which is the density (spruce typically has a density of ~ 400kg/m^3) Also look up mass, weight and density in Wikipaedia so that you'll understand the difference.
To measure stiffness, you're best off using E (Young's modulus) as the measure for stiffness. There's the deflection method of measuring E (also called the static method) and there's the vibration method, also called the dynamic method as discussed above. Full instructions for both methods are in the book or Google "beam deflections" and you'll find suitable formulae in Wikipaedia or similar. The advantage of using E is that your results will then be comparable with anybody else's, whereas if you use the deflection under the weight of a heavy spanner (for example) you can only compare your results with someone who has a similar spanner.
So if you use E, the ratio E/density is the stiffness-to-density ratio.
A less satisfactory alternative is to just measure the deflection. The load needs to be a standard size, also the span and the sectional dimensions. You are then using deflection as an analogue of stiffness, and the ratio becomes deflection (measured in whatever units you like) divided by the density as discussed earlier.
For Danny, E is Young's Modulus, a measure of material stiffness. Again Google/Wikipaedia is your friend.
PostPosted: Wed Jan 15, 2014 4:21 am
First name: joseph
Last Name: sallis
Country: UK
Trevor, as always, thanks for spending the time. I do understand now.
I got a bit confused earlier because mass was used in place of weight.
PostPosted: Wed Jan 15, 2014 4:57 am
First name: Tom
Last Name: West
State: Nova Scotia
Trevor: Everyone has a pipe wrench like me............!!! [:Y:] You started my day off with a smile. Thanks.
Tom
PostPosted: Wed Jan 15, 2014 1:22 pm
Last Name: Lloyd
Though I have indulged in and remain fascinated with scientific research I would think that apparatuses used here and the degree of significant in the number crunching that this data is almost meaningless except for the simple enjoyment in the exercise of data gathering.
I do such but only to measure deflection of the top before and after bracing.
Just what would be an your acceptable tolerance between similar braces to be used on the same instrument?
I’m sitting in Padma’s camp. ;)
The knowledge and process is indeed worth knowing.
Michael Lloyd
PostPosted: Thu Jan 16, 2014 4:01 am
First name: joseph
Last Name: sallis
Country: UK
I'm still wondering if my equations were right?
PostPosted: Thu Jan 16, 2014 7:56 am
First name: Trevor
Last Name: Gore
City: Sydney
If that's a serious question: No. The first was inverted.
For density you had volume/mass. Should be mass/volume. Referring back:
Trevor Gore wrote:
Joe,
Your second equation is also inverted compared to convention which usually looks at a stiffness to density ratio which is stiffness (however you want to measure that) divided by density.
If you lived in the southern hemisphere it would all be a lot easier.
PostPosted: Thu Jan 16, 2014 1:13 pm
What?
So equations written below the equator run counter clockwise too? No wonder they make no sense to me!
PostPosted: Thu Jan 16, 2014 5:37 pm
First name: Trevor
Last Name: Gore
City: Sydney
meddlingfool wrote:
What?
No, just upside down.
Because the equations themselves are concepts rather than physical entities, they don't have mass, so they aren't subject to Coriolis effects.
PostPosted: Mon Jan 20, 2014 7:48 am
First name: joseph
Last Name: sallis
Country: UK
Trevor Gore wrote:
Joe,
It was indeed a serious question and thanks for answering it.
This is why examples are so useful.
