It is currently Wed Aug 20, 2025 6:32 am
PostPosted: Fri Dec 20, 2013 2:56 pm
First name: Steven
Last Name: Bollman
City: Emeryville
Zip/Postal Code: 94608
I have been French polishing for about a week. Through a typical learning curve, I'm starting to see how this may end up looking quite nice. I see how repeated leveling/sanding cycles that the pesky few unfilled pores are starting to fill. I am wondering if there is a way to spot fill these "pin holes", or do I need to soldier on with more padding and leveling to get to the bottom of the holes. Thx!
PostPosted: Fri Dec 20, 2013 3:06 pm
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Zip/Postal Code: 64081
I would flatten the finish with a drop of baby oil/pumice and then buff out hard with straight alcohol inside the pad to clear the oil/pumice an start buffing if your at that final stage.??
PostPosted: Fri Dec 20, 2013 7:14 pm
First name: Steven
Last Name: Bollman
City: Emeryville
Thanks, Ernie. I think that's going to work. At least it looks like it helped after one round. Maybe two or three more….?
PostPosted: Fri Dec 20, 2013 10:07 pm
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
use a lot of pressure on your pad when using the alcohol only ,if it starts smearing add a touch of 1lb shellac inside the pad to remove the swirl marks. You will know when it/s done .It is one of those judgment calls.You just stop when you feel that there is enough FP on the wood . PS I/ve been using shellac for 30 yrs . But I luv the FP look.
