It is currently Tue Aug 19, 2025 11:32 pm
Post new topic Reply to topic  [ 26 posts ]  Go to page Previous  1, 2
PostPosted: Mon Dec 16, 2013 5:43 pm
Goodin wrote:
Are you saying you are planning on using just acetone to glue the plastic binding? That's probably not a good idea, you need some glue in there. I have heard of people mixing acetone with Titebond for this glue up but haven't tried it myself. Try that or Duco cement. I didn't have good luck with the Weld-On cement that Stew Mac sells. I had complete glue joint failure when gluing celluloid binding to fiber purfling, and questionable adhesion to solid wood.
Don't worry about the binding when gluing the fretboard to the neck blank. You will have plenty of wood to wood glue surface. Just get a good glue joint binding to side of fretboard. As usual, test glue joints on scrap first.
Goodin, thanks. Acetone works great for attaching abs binding to wood.It's been done since the beginning on electric guitars, and I prefer it. I don't anticipate any problems in that regard. Check it out.
And thanks for the advice on the edges of the fretboard/binding joint. I've had several people give the same advice. Makes me feel good about that.
These users thanked the author Mike Baker for the post: Goodin (Tue Dec 17, 2013 9:06 am)
Users browsing this forum: DennisK and 28 guests
