It is currently Wed Aug 20, 2025 6:32 pm
PostPosted: Fri Nov 29, 2013 5:04 pm
First name: Tom
Last Name: West
State: Nova Scotia
Am doing a guitar with 2.250" string spacing at the bridge and 1.750" nut width. Am trying to figure the width at the 12th fret without doing a full size drawing. I think the rule of thumb is the size at the 12th fret is equal to the string spacing at the bridge. It got me thinking about what happens if the nut width changes. Wonder if anyone would care to clear this up for me? Life can be confusing when your not too bright.
Tom
PostPosted: Fri Nov 29, 2013 5:15 pm
First name: Charlton
Last Name: Wang
Isn't the 12th fret basically half way? I would assume it's 2" but someone with more knowledge can and probably should chime in.
Charlton
PostPosted: Fri Nov 29, 2013 5:44 pm
Last Name: Ensor
City: Springfield
State: Missouri
Whatever I am using for my saddle spacing, that is what I use for my 12th fret spacing as well.
http://elevatelutherie.com
http://ensorguitars.com
PostPosted: Fri Nov 29, 2013 5:56 pm
I was recently working on this, too, Tom. Same specs. I modelled the neck with http://www.ekips.org/tools/guitar/fretfind2d/ and printed it out.
PostPosted: Fri Nov 29, 2013 5:58 pm
Last Name: Thompson
City: Loyalhanna
State: PA
Zip/Postal Code: 15661
Anything that will accept a pencil mark, is as long as your scale length and at least 2.5" wide would allow you to scribble this out and then take any measurement that you want, anywhere along the FB. I do this sort of thing on my bench top all of the time and then just hit it with a scrap of 220 paper to erase it. It would actually take less time to draw it than it would for me to type this reply. If I were out in my shop, I would have sketched it out and have an answer for you but, I'm not.
Respectfully,
PostPosted: Fri Nov 29, 2013 7:09 pm
Tom,
Just measured one that I just finished, at the 12th fret, with a 1.75 nut and 2.25 string spacing, my fret board width is just 1/64" over 2.25" or 2 17/64". 2.25" would be fine.
Chuck
PostPosted: Fri Nov 29, 2013 7:33 pm
Last Name: Arnold
City: Newport
Zip/Postal Code: 37821
In the late-1930's, 14-fret Martins had a 1 3/4" nut and 2 5/16" spacing at the bridge. The width at the 12th was 2 1/4". With that in mind, 2 1/4" is plenty wide......and 1/32" narrower at the 12th (2 7/32") should also work.
The nut width is the width of the fingerboard, not the string spacing.
These users thanked the author John Arnold for the post: jack (Fri Nov 29, 2013 7:54 pm)
PostPosted: Fri Nov 29, 2013 8:01 pm
First name: Tom
Last Name: West
State: Nova Scotia
The consensus seems to be 2.25", so I'm going to fly with that. Thanks all.
Tom
PostPosted: Fri Nov 29, 2013 8:06 pm
First name: Alain
Last Name: Lambert
City: Trois-Rivieres
State: Quebec
2 17/64 (57.5 mm) is spot on for a 3/16 distance of the string to fingerbord edge at fret 12.
PostPosted: Fri Nov 29, 2013 8:39 pm
First name: duh
Last Name: Padma
Yo, Tom
Wood bees and should bees, spot ons, and half of this length is the bangle of the dange between this to that, is all a crock.
Besides the string spacing at the bridge, we would also need to know the string spacing that you will be using at the nut to answer your question.
Or the amt. of set back at the nut from the edges to the E stings.
And that's assuming your running them strings parallel to the edge.(Not advised)
So throw us one more number and we can throw you back the exact answer.
NOtE: Width of nut and width of string spacing at nut are two different things.
Think about it.
PostPosted: Fri Nov 29, 2013 8:51 pm
Last Name: Beaver
City: Lake Forest
I would just do the drawing then measure. Once you have the nut width and the bridge pin width, Just do the following.
Measure in 5/32" on the 6th and 1/8" on the 1st for the string location at the nut. Draw a line connecting them to the pin locations. That will be the string layout. Measure out about 3/16" at the 14th fret from the 1st and 6th sting. Draw a line from the outside of the nut at both ends going through the marks at the 14th fret. That will be the fingerboard. Then you can measure the width at the 12th fret.
Anyway, that's how I do it.
Joe Beaver
Maker of Sawdust
PostPosted: Fri Nov 29, 2013 9:13 pm
Last Name: Wang
Oh...duh. You're right! Fail on my part.
PostPosted: Sat Nov 30, 2013 3:51 am
PostPosted: Sat Nov 30, 2013 5:14 am
Last Name: Arnold
City: Newport
That is generally not done, because it can cause problems with pushing the outer strings off the edge of the fretboard. This is because the string is more flexible at its midpoint than it is near the nut.
The earliest 14-fret Martins (OM's mainly) had this combination:
1 3/4 nut
2 1/4 12th fret
2 3/8 or 2.4 bridge spacing
Those can sometimes exhibit the problem outlined above, particularly if the frets are severely beveled and if the spacing at the nut is widened to the max.
I do know that the alignment on these is more critical than the later guitars....so a neck reset must be spot on as far as center alignment is concerned.
PostPosted: Sat Nov 30, 2013 6:44 am
First name: Tom
Last Name: West
State: Nova Scotia
Lots of folks not aware of this unless they are players.There are players and those who play at the guitar. I'm in the latter group. I have seen a noted luthier who was not aware why this was done. I was educated about this quite a while ago by a player. Before I was informed I thought it was mainly for design purposes to give visual interest. For folks that don't know, John is a player. Thanks for jumping in John.
Tom
PostPosted: Sat Nov 30, 2013 8:10 am
First name: Murray
Last Name: MacLeod
City: Edinburgh
Country: UK
I would imagine that Larry Pattis is the player to whom you refer, Tom.
Larry posted very eloquently, in fact definitively, on the subject on this thread ...viewtopic.php?f=10101&t=30776. You can skip the first two pages if you want to get straight to his posts.
I am fairly certain that the relatively recent decision by Martin to list the 12th fret width as part of the guitar specs on their website is due solely to his airing of this issue over the years on various forums.
PostPosted: Sat Nov 30, 2013 9:56 am
First name: Tom
Last Name: West
State: Nova Scotia
Murray : No, not Larry. It was someone local to my area but it's so long ago I forget who it was. That's one of the subtle benefits of growing older. I have 5 books, 5 DVD movies and I'm set for entertainment .................................read, watch and then start over and swear you had never seen any of them before this time.
Tom
PostPosted: Sat Nov 30, 2013 12:28 pm
The width is whatever you or your client want it to be based on how much fret space you want outside the strings. The common rules of thumb are to match the bridge spacing at the 12th or 14th fret but there's nothing magic about that. Some people like more space. A few like a lot more. I haven't run into anyone who likes less yet.
http://www.chassonguitars.com
PostPosted: Sat Nov 30, 2013 4:51 pm
First name: duh
Last Name: Padma
Ya Kent, your right ...the only ones that didn't mind less were a few slide players, and the only place they wanted more was in the raised action...go figure eh. laughing6-hehe
PostPosted: Sat Nov 30, 2013 6:16 pm
First name: Murray
Last Name: MacLeod
City: Edinburgh
Country: UK
The thing that always puzzles me is the arcane discussions on how to offset the neck ever so slightly so that there is marginally more distance between the treble e and the edge of the fretboard compared to the bass E and the edge of the fretboard.
Just increase the width and the taper of the fretboard in the first place, so that there is sufficient clearance on both strings ...
PostPosted: Sat Nov 30, 2013 8:35 pm
Online
Last Name: Kincheloe
The idea behind that is to keep the bass side space as small as possible without falling off the edge so the thumb wrappers can have their fun, but also to have enough space on the treble side to do pull-vibrato without falling off there. Don't usually push the bass strings up to bend, so the edge space there can be smaller. You can do it either by tilting the neck toward the bass side, or simply marking the treble edge a bit farther away from the centerline on the neck and fingerboard when tapering them.
I use pretty much the same method as Joe Beaver described. Can be done mathematically or geometrically, and with any nut width, bridge spacing, and string-to-edge spacings you want. There are 4 string-to-edge spacings to decide on... low E at nut, low E at 12th fret, high E at nut, high E at 12th fret. The nut spacings can be about 1/32-1/16" less than the 12th fret spacings without falling off the edge, due to the previously mentioned fact that the strings stretch more easily in the middle.
My preference is 1/8" low E at nut, 5/32" low E at 12th, 5/32" high E at nut, 3/16" high E at 12th.
tl;dr, 12th fret width equal to bridge spacing is usually pretty much right.
PostPosted: Sun Dec 01, 2013 10:37 am
Last Name: Minch
City: Chestertown
Zip/Postal Code: 21620
My experience is that I want to bend the strings upward more than downward, so I like a little more clearance above the low E than below the high E. Anybody else have actual numbers they like?
PostPosted: Mon Dec 02, 2013 10:21 am
Using the string spacing at the bridge as the neck width at the 12 fret (midpoint) will keep the distance of the outer strings off the edge of the neck roughly the same all along the neck, because the distance the string is to the right at the nut is matched by the distance it is to the left at the bridge from a line passing through the midpoint of the string and parallel to the centerline of the guitar.
Users browsing this forum: DennisK and 14 guests
