It is currently Wed Aug 20, 2025 6:33 pm
PostPosted: Fri Nov 08, 2013 11:00 am
Hi all,
I'm about to make my first abalone rosette, and I'm not familiar with working with that material as I have always favored wood for my rosettes. Now my customer insisted, so...
Making and inlaying the rosette is not a problem, but I'm concerned with the leveling part, once the rosette will be inlayed. I don't have a drum sander large enough to allow me to level it this way, so I'm going to have to do it by hand. And maybe I'm mistaking, but I believe I've read in past threads that it can be tricky to hand level an abalone/MOP rosette, as the softer wood around the rosette gets sanded more that the actual rosette, thus making an uneven surface once the rosette is leveled. There were also concerns with sanding dust staining the spruce around it. Is that so? And if so are there any tricks to avoid that?
Thanks!
Alain Moisan
(Now building just for fun!)
PostPosted: Fri Nov 08, 2013 11:07 am
First name: duh
Last Name: Padma
Don't you go be sanding that balony,
Use a scraper to take it down flush.
PostPosted: Fri Nov 08, 2013 11:20 am
Ah, ok. Somehow I was convinced abalone couldn't be scraped... idunno
Alain Moisan
PostPosted: Fri Nov 08, 2013 12:49 pm
First name: Gene
Last Name: Zierdt
City: Sebastopol
Zip/Postal Code: 95472
I find it's best to try and leave a minimum of shell above the surrounding wood. If you remove too much depth,
you're likely to find the shell looking very different than the original surface. So I try and remove about .005" max.
And as above, don't try and sand the shell down, the surrounding wood will cut much faster than the shell. Final
sanding in finer grades to get ready for finishing is OK, but if the shell is inlaid into dark woods the white sanding
dust needs to be carefully removed.
Gene
PostPosted: Fri Nov 08, 2013 1:00 pm
First name: Rodger
Last Name: Knox
City: Baltimore
Zip/Postal Code: 21234
Good advice, both the scraper and the file.
Another approach is to leave the shell slightly lower and completely cover the surface with CA, then you don't have to remove any shell. It does alter the appearance slightly, you'll have to test it on scrap to see if you like it. I actually prefer the look.
I originally tried it because I had some abalone and the color layers were really thin, so I wanted to avoid scraping it and ruining the colors.
PostPosted: Fri Nov 08, 2013 1:16 pm
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Zip/Postal Code: 64081
Vy nice , cedar/purpleheart?
These users thanked the author ernie for the post: Rodger Knox (Mon Nov 11, 2013 11:35 am)
PostPosted: Fri Nov 08, 2013 1:40 pm
A hard scraper with a right angle edge, such as the ones StewMac sells, will hold up pretty well on shell. A harder steel than the D-2 they use on those works even better: my old scraper is M-2, steel and that holds the edge a lot longer, but it's more expensive and harder to heat treat. Or you can go tot he ultimate weapon: glass. Some folks like to keep a box of microscope slides around for this sort of thing. Big drawback: you can't sharpen them.
You do have to be careful when scraping shell not to 'washboard' or nick the surrounding wood when you get hung up in a joint. In practice, I'll scrape until I'm almost there, and then switch to a big hard block and 180 or 220 sandpaper. You do have to be sure that you're not falling off the edge of the shell and dishing the wood all around, but it's possible.
PostPosted: Fri Nov 08, 2013 2:13 pm
Thanks for your input guys!
Alain Moisan
PostPosted: Fri Nov 08, 2013 4:59 pm
Last Name: Denvir
City: Baltimore
State: ON
Zip/Postal Code: K0K 1C0
I'm confused by the resistance to sanding. Shouldn't a hard block, 6 inches or so, be able to maintain stability relatively easily, always kept in contact with 2 parts of the rosette?
Or perhaps I'm just confused :-)
PostPosted: Fri Nov 08, 2013 5:23 pm
I would simply hard block it as well if I had to do it by hand, with a piece of hard maple or baltic ply, big enough to hit half the rosette ... 150 grit and away you go
PostPosted: Fri Nov 08, 2013 5:57 pm
Last Name: Beaver
City: Lake Forest
I usually use sandpaper with a block of wood as backing. Works for me. On abalone purfling I usually use a scraper. That works also.
Joe Beaver
Maker of Sawdust
PostPosted: Fri Nov 08, 2013 6:58 pm
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
I use a scraper and just true it up and put a burr on it as needed. Sanding things like this level with a hard block usually leads to tearing up the surrounding top as the shell will pull the abrasives off the paper and it will now roll around freely under the block and mar the top.
Brian
PostPosted: Fri Nov 08, 2013 9:52 pm
First name: Mark
Last Name: Chinworth
City: Kirkwood
Zip/Postal Code: 63122
On the two I've done:
Double check routing depth to ensure the shell is close to level as possible, but on the proud side.
While scraping the rosette purfling flush, I notice a little powder from the shell. Then I switch to a ROS with 120. Works fine.
PostPosted: Fri Nov 08, 2013 10:31 pm
Online
Last Name: Kincheloe
Shellac the wood before inlaying... that will keep the dust out. Then scrape level. I use a card scraper, but shell does dull it pretty quickly. Just move to using a different part of the edge, until you've used up all of it and then re-burnish.
I usually use a sort of rotating motion to scrape. Anchor one corner of the scraper, and rotate around that, to keep from scuffing the surrounding wood. I have the corners of my scraper rounded over so they don't scratch the wood.
I've never tried a file, but were going to, I'd put masking tape over the ends as a sort of depth stop, to prevent scuffing of the surrounding wood. Seems risky of chipping the shell though, if the teeth ever snag on the 90 degree edge. Also probably more dust fluffed into the air than careful scraping.
I did do abrasive leveling on a headstock once and it worked fine, aside from the dust fluffage. I used my trusty extra-extra-coarse dia-sharp stone, so no abrasive particles falling off and scratching things up. I also used the masking tape depth stop trick with this, which worked well to keep the sanding on the shell and not the wood, until it was level. Then a quick pass with the scraper to take out the sanding scratches.
PostPosted: Sat Nov 09, 2013 4:56 am
First name: Trevor
Last Name: Gore
City: Sydney
A hard, large (1/2 sheet) sanding block works well for me on rosettes (shell and hardwood end grain into spruce and cedar). I have a wooden backed file (similar to a fret file) that I use on shell purling. The file wears pretty quickly though. I get about half a dozen guitars per file. An integral part of the process is the brush (or vacuum). Remove the debris after every stroke; don't "scrub".
http://www.goreguitars.com.au
PostPosted: Sat Nov 09, 2013 9:51 am
Scraper and file, here. I have a few files with a wood 'handle' glued to one side. Clean the file with a card scraper(why, oh why, is a little wire brush named a "card scraper"? after each stroke, and it'll last a long time. I sharpen my scraper with a file, but don't turn a hook on it for this use, and it will usually last for the duration of the job.
Why not sand? Because the shell is many times harder than the wood, and even with a hard sanding block, you'll sand away more wood than shell.
PostPosted: Sat Nov 09, 2013 10:32 am
First name: Tom
Last Name: West
State: Nova Scotia
Mario: In the machine shops I worked and frequented we called them "file cards", a flat wood body with Chinese bristle brush on one side and close cut steel wire brush on the other. Yours may look a bit different.
Tom
PostPosted: Sat Nov 09, 2013 12:49 pm
I tried hard blocking with 80 grit once. Bad idea. It scratched up the Spruce pretty bad. I had never considered that it was from dislodged abrasives, but that was probably it.
PostPosted: Sun Nov 10, 2013 5:13 am
First name: Trevor
Last Name: Gore
City: Sydney
Here's paua abalone and Aus. blackwood into a cedar top:
Flat as, no ripples, French polish finish, levelled with sand paper on a half sheet hard block.
Here's a better pic of the whole body:
Here's paua straight into spruce (and plenty more examples, all done the same way, if you care to click through them).
Must be a technique thing. I usually start at 120 grit, Klingspor papers.
PostPosted: Sun Nov 10, 2013 11:16 am
Tom, correct, "file card" is the term I wanted, but ye olde brain wasn't running at full song, I guess... ;)
But file card is a vague and misleading term, IMO.
PostPosted: Sun Nov 10, 2013 1:01 pm
Last Name: Bordeaux
City: Massena
State: New York
Zip/Postal Code: 13662
I've had great results with a hard maple block and quality sand paper,changing paper often and using good lighting.
Paul Bordeaux
http://www.bordeauxinlay.com
PostPosted: Sun Nov 10, 2013 2:28 pm
First name: Tom
Last Name: West
State: Nova Scotia
Mario: I think the name "file CARD" comes from carding brush that is used to card wool before it is spun into yard. I'm referring to the old time methods our ancestors used. I always thought it a bit strange myself. It would seem that " file brush" would be a more suitable name.
Tom
PostPosted: Mon Nov 11, 2013 11:37 am
First name: Rodger
Last Name: Knox
City: Baltimore
Redwood/Bloodwood, with spalted maple as the center of a 3 piece back.
Users browsing this forum: DennisK, nashrb and 16 guests
