It is currently Wed Aug 20, 2025 4:41 pm
PostPosted: Mon Nov 04, 2013 10:12 am
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Zip/Postal Code: 64081
Increasingly I am using fish an hide 192 an 350 on my cheapo chinese bristle brushes purchased from the hobby shop. I/ve been using ammonia from dollar store and vinegar 3% from grocery store . I notice that neither is doing such a good job of cleaning . I rinse with soap and warm water . yesterday I boiled my glue brushes on the stove with vinegar . That helped ,in the past I used mostly titebond and soaked them in cold vinegar. Now I use titebond infrequently. Any ideas for getting a cleaner brush . Thanks. ernie
PostPosted: Mon Nov 04, 2013 11:42 am
I just rinse mine with water after each glue-up. Every once in a while I forget and they dry out - then I just throw them away.
PostPosted: Mon Nov 04, 2013 11:59 am
I just pop them in a dish/jar of water (part of the glue-up preparation) after use, until I get round to cleaning them properly. I usually use hot water, don't usually need soap/chemicals.
Just part of the routine now.
Been using same set of brushes (Chinese artist's bristle) 5 years now, still perfectly useable.
PostPosted: Mon Nov 04, 2013 12:01 pm
City: chicagoland
State: illinois
as soon as i'm done with titebond, i dunk the brush in a glass of water and leave it there indefinitely (30 minutes, 2 weeks, whatever) until i get around to rinsing it. just water, nothing else necessary. hide glue ought to be exactly the same
PostPosted: Mon Nov 04, 2013 12:06 pm
Snap!! Musta posted about same time.
PostPosted: Mon Nov 04, 2013 12:07 pm
First name: duh
Last Name: Padma
soak in water,
clean with a brass or steel toothbrush....
http://www.leevalley.com/en/wood/page.aspx?p=20097&cat=1,190,43040
PostPosted: Mon Nov 04, 2013 12:27 pm
City: chicagoland
State: illinois
i guess what hasn't been mentioned, is: get it in water well before the glue hardens on the bristles. have a glass of water with you when you are gluing, if you must...
PostPosted: Mon Nov 04, 2013 1:16 pm
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Put a jar of soapy water and a steel brush on the work table Thanks everyone.
PostPosted: Mon Nov 04, 2013 1:31 pm
First name: Hugh
Last Name: Evans
Getting the brushes into water immediately after use is definitely the best practice. Hot/boiling water will clean it all off if given enough time. For PVA (such as TB or Gorilla wood glue) concentrated citric acid, which can be found in hardware stores as some variety of orange solvent, works wonders. Not only will your shop smell like an orange grove, you will also be able to clean the brush, tool, or surface. In both cases, start with a 30-60 minute soak. If that doesn't do it, leave them in overnight.
PostPosted: Mon Nov 04, 2013 2:57 pm
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Is there a name brand for the citric solvent ?? Can you get it anywhere else besides hardware stores?? thanks
PostPosted: Mon Nov 04, 2013 8:02 pm
First name: Victor
Last Name: Seal
City: Osseo
Zip/Postal Code: 49266
Warm water.
