It is currently Wed Aug 20, 2025 6:18 pm
PostPosted: Sun Oct 13, 2013 8:18 am
I just finished buffing the finish on my #27 acoustic, and was once again surprised at how long the sanding and buffing can take. I manage to expect it to take a couple of hours to sand the finish level (800 grit and 1000 or 1200 grit) then buff (using buffing arbor and two menzerna dry compounds,) but it always takes me closer to 4-5 hours. This made we curious as to how long it takes everyone else.
For me the time on most aspects of the build have gotten much shorter over the years, except the finishing of the finish. Granted the gloss on my guitars keeps looking better, but the time just won't shrink down like it has in the rest of the build.
So how long do you find it takes to go from the cured finish to the buffed and shiny surface on an acoustic neck and body?
Kent
PostPosted: Sun Oct 13, 2013 9:22 am
Online
And now we know why all the amateurs wash out of luthiery.... whole lotta elbow action going on.
Used to take me an 8 hour day to completely buff and polish a freshly cured finish.
PostPosted: Sun Oct 13, 2013 9:57 am
Last Name: Ensor
City: Springfield
State: Missouri
The higher you sand, the quicker it is. I sand up to 2500 and it takes me 2-3 hours to buff.
http://elevatelutherie.com
http://ensorguitars.com
PostPosted: Sun Oct 13, 2013 10:09 am
Are you guys buffing by hand or machine buffing?
PostPosted: Sun Oct 13, 2013 10:20 am
First name: Stuart
Last Name: Gort
My arms can't sand for eight hours straight. No way. :) I'm good for about two or three in a day. I've learned to seriously focus on the prep and spraying to keep the leveling and polishing to a minimum.
I can prep a guitar for spraying in a day or two....maybe up to four total hours of scrubbing. Mind you, these are set neck electrics so there are a lot of detail areas. There are only a few places to use power tools.
I spray polyester sanding sealer for pore fill...several coats...no sanding between them. After a few days curing, I can level with 220. That takes about three hours total.
Topcoats can be polyester, polyurethane, or nitro with a vinyl tie coat...if I don't mind waiting three weeks to level. My biggest battle in finishing was to learn to spray such that it laid down smooth and could be leveled with 1000 grit (600 at the very coarsest). So that takes about 2-3 hours followed by another hour with 1500. If poly is used as a topcoat another session with 2000 is required.
At the StewMac polishing wheel it's maybe an hour...maybe 1-1/2 hours to use the medium and fine compounds.
They are turning out very nice but I think maybe an additional last step with a handheld rotary buffer and a sponge wheel using the Fine Menzurna liquid compounds would add that final professional look to the large, flat surfaces. Advice from Saul Koll....a very good guy.
So...roughly 12 hours of scrubbing to get from raw wood to a polished finish...and yes...it gets on my nerves.
I'm doing one now with tung oil. It makes me LAUGH how stupid easy it is if you don't have to fill pores and have a glass finish.
StuMusic
PostPosted: Sun Oct 13, 2013 10:50 am
Online
Yup. Pretty easy to operate a rag.
PostPosted: Sun Oct 13, 2013 10:56 am
First name: Danny
Last Name: Vincent
3 -4 hours of sanding and maybe an hour to buff if all goes well. I think for me the largest portion of time for one task on a build goes to set up. But that's a whole other topic.
PostPosted: Sun Oct 13, 2013 11:50 am
First name: Rob
Last Name: McDougall
City: Cochrane
State: Alberta
Yup, 4-5 hours at least after the final last coats have cured....
PostPosted: Sun Oct 13, 2013 12:05 pm
First name: Stuart
Last Name: Gort
Someone should kill the guy that invented shiny.
StuMusic
PostPosted: Sun Oct 13, 2013 12:14 pm
4-5 hours sounds about right. From the moment I begin flat sanding the lacquer to the final buffing. That's on an electric, and doesn't include cleaning the polish out of the neck, pickup and control cavities. Or the final rub out by hand with a good swirl remover. Just the way it is.
PostPosted: Sun Oct 13, 2013 1:23 pm
Same time frame here. Even with Dynabrades and some serious industrial buffing wheels....
Skip right from anger/denial and jump straight to acceptance....;)
PostPosted: Sun Oct 13, 2013 1:40 pm
First name: Doug
Last Name: Balzer
City: Calgary
State: Alberta
Put on some good tunes. Have a great beverage on hand to slowly reward yourself at progressive milestones (personal fav: Leffe Blond or Bruin). A recipe for a nice afternoon.
Doug
PostPosted: Sun Oct 13, 2013 1:44 pm
Kent
If I'm brushing Shellac/Spirit varnish I can do a whole finish in that time, including pore filling. Although it's also true to say that I don't aim for a finish that is as glossy or as flat as some. I learnt a long time ago that when it came to finishing, I had to choose my poison carefully.
PostPosted: Sun Oct 13, 2013 1:51 pm
Online
Don't make me laugh! laughing6-hehe
PostPosted: Sun Oct 13, 2013 2:07 pm
Or at least wound him severely. :evil:
PostPosted: Sun Oct 13, 2013 3:11 pm
If I remain focused, I can level the body and neck in an hour but most likely it is a 1.5 hour task. I can buff the body and neck in one hour or even less sometimes. That includes four different wheels/compounds to get where I want to be. The early ones took me all day to buff. [uncle]
jw ( o)===:::
PostPosted: Sun Oct 13, 2013 7:09 pm
Joe, what menzerna numbers do you use?.
PostPosted: Sun Oct 13, 2013 8:24 pm
Do you ever read threads that make you think you've been doing it wrong all along? I've always taken a handful of passes with Menzerna medium, then fine. Never takes more than 20 minutes. What is it that you guys do?
PostPosted: Sun Oct 13, 2013 9:23 pm
More like, what is it that you do, James?
PostPosted: Sun Oct 13, 2013 10:27 pm
#W113 first wheel.
#P204 second wheel.
#W16 third wheel.
P175 final wheel.
Remember, I am buffing polyester. It's tough stuff to get a scratch out of but this four step procedure works well for me.
jw ( o)===:::
PostPosted: Sun Oct 13, 2013 10:29 pm
Last Name: Flindall
City: Peterborough
Geezzz..... you guys measure in hours? I'm currently measuring in days to sand and buff a guitar..... sigh.
Rob Flindall
Flindall Guitars
http://www.flindallguitars.com
https://www.facebook.com/FlindallGuitars
PostPosted: Sun Oct 13, 2013 10:33 pm
I've always leveled with 400 grit "Brilliant 2" on the Festool, then use their "Platin" pads at 500 and 1000 grit. The leveling is never fun, but it takes about an hour? Perhaps longer. The two Platin grades don't take too long, and then I buff with Medium and Fine Menzerna compounds with 14" canton flannel buffs on the Caswell Platings buffer.
My first guitar was finished with Poly. I never got it to a gloss. McFadden's nitro since then, and they've all seem to gloss up as soon as they've hit the buffs. I'm working through my first finish with Cardinal right now, so I wonder if things will change.
But where a room of guys and one pro say it takes them an hour or more, I'm inclined to wonder if I'm getting the same quality of gloss you are.
PostPosted: Sun Oct 13, 2013 11:47 pm
Hard to say without seeing it right up close. Looks good on the iPhone at least. :)
PostPosted: Mon Oct 14, 2013 4:14 am
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
Level sand and buff takes me about 2-1/2, maybe 3 hours. My process looks similar to Joe's. Recently changed my sanding schedule, now level with 400 dry followed by a few different scotch-brite. This was a real time saver.
Brian
PostPosted: Mon Oct 14, 2013 6:34 am
Going by those photo's it looks too glossy! But that's just my taste. I don't like the sheet of glass look and I think that there are better finishes that look a little easier on the eye.
That's partly the problem of using abrasives to polish. You are virtually compelled to go through all the grits and polishing compounds until all the scratches are gone. It's a one way street. It seems the devils out for the SS maker - it's super gloss or nothing, or it's considered bad workmanship.
Anyway, that's my take on it. I'm glad I don't feel compelled to do that type of finish or a finish that takes days to achieve.
These users thanked the author Michael.N. for the post: bcombs510 (Wed Feb 10, 2016 4:11 pm)
Users browsing this forum: DennisK and 15 guests
